Results 1 to 27 of 27
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Forged rods and balancing of the V6 ...
    I have been thinking alot on the above and heared several different opinions and have also been told it's NOT easy to balance an S4 V6 engine !
    It comes down to this : I have a crate bottom end (new AGB short block) that I want rods in. So I went to the machine shop where alot of my friends had engine work done and the dude is 60yrs old and had the shop since the 70's and does alot of rally and race engines
    So I say , I have an S4 2.7 Biturbo V6 crate engine blablabla.... And I wanna put aftermarket rods in there with ARP bolts. He says no problem I can do that. Then I ask him can you balance the whole rotation assembly too ?
    He says I can't do that V6 engine cause I don't have the contraweights (don't know what it's called in US) to balance a V6 cause this get's asked maybe once in 10 yrs and I can't make molds just for one engine but since your engine is brand new and tolerances from Audi are very good from the factory I can just balance the rods and pistons on their own and you will be perfectly fine we have done this a dozen times and it will be ok.
    What's everyones opinion this ???
    (please no opinion if you don't know what your talking about let's keep this an informative thread, thanks!)
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Established Member Two Rings force fed's Avatar
    Mar 20 2011
    Albany
    Maybe explain to the guy what kind of horsepower your looking to achieve, and what kind of rpm the engine is goin to see, then maybe he'll have an idea of if balancing just the rods and pistons will work. Im sure someone with a little more in-depth knowledge of this will chime in...
    Apr 18 2007
    ny
    Just find another machine shop. This guy is obviously not tooled for your type of motor, but if you did only new rods you could get away without balancing.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Feb 20 2008
    belgium
    I told him 7500rpm rev limiter and 500whp
    He said since it's only 250-300rpm more then a stocker and OEM tolerances are pretty damn good on these engines I would be more then fine.
    To be honest it's not buying the parts and spending the € on these cars that makes my brain hurt but it's all the shit like this , he says this ,he says that .... in the end who is right ?
    Feb 20 2008
    belgium
    Quote Originally Posted by A62TURBO View Post
    Just find another machine shop. This guy is obviously not tooled for your type of motor.
    I allready went to another shop that said it is indeed needed and also Loba motorsport confirmed it was needed but there also lot's of guys putting rods in these engines in their own garages at home and are perfectly fine so I ask myself if they are waiting for the granade to go pop?
    Apr 18 2007
    ny
    If you were doing rods and pistons I would say balance, but you'll be fine without a balance if your only doing rods.
    SOLD
    Greg
    C5UNION
    Feb 20 2008
    belgium
    That's what I've been told by many but I have no first hand experience with this so I want to be sure I do it right
    Senior Member Two Rings IgofastS4's Avatar
    Feb 23 2010
    2000 S4
    Earth
    It does not have counter weights on the outside side of the motor, due to the fact it is internaly balnced not externaly, Externaly balanced motors have conter weights on the flywheel and balancer. the s4 2.7 is all Internal. the diffrence in rod weight will throw off the ballance from going to aftermarket rods from stock due to the grams in weight (of the rods). when they ballance it they calulate the (Bob) weight and make the diffrences to change the balance.
    Feb 20 2008
    belgium
    Quote Originally Posted by IgofastS4 View Post
    That's some nice info. So what your saying is that he doesn't have a clue about the V6 TT
    Feb 23 2010
    2000 S4
    Earth
    Quote Originally Posted by Audi_S4 View Post
    To put it nicely yes
    Jan 11 2007
    Salt Lake City, Utah
    I had to call around to like 4 shops (even the ones with the best reputations in the area) before finding a referral to a machine shop that had the bob weights for the V6. You might have to make some calls.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Feb 23 2010
    2000 S4
    Earth
    Quote Originally Posted by jibberjive View Post
    Who did you end up having do the balance for you ? My Machinest right? I just remeber seeing your IE rods, stock Pistons, crank
    (Basicly your whole rotationg assembly) at his shop at one time long ago.
    Sep 11 2009
    NE
    You have to balance V motors since they are not "symmetrical" as I engines are where pistons/rods move in on plane. Changing weight of piston/rod assembly throws everything off in V engine. The rotating assembly needs to be balanced outside of engine with bob weights. Expect new welds/holes on you crank weights after said and done!
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    also keep in mind that when people like me 'throw in' pistons or rods, they are typically already balanced builds and replacements... at that, we plastigauge the installs to check bearings and if we aren't within thousands, something is up. If it's anything beyond replacing pistons or rods... it goes to a machine shop no question... so throwing rods in a car will work fine... issue is that most guys that throw stuff together never have cars that last years to see the outcome of their decisions. People that take shortcuts are rebuilding motors 2:1 than guys that do not.
    in the end, i would never ever go to a machinist that doesnt' know the most elementary design of said motor... not knowing that S4's are internally balanced is really crazy for a machinist... I would not take his suggestions as gold seals.
    Latest mod - JHM rebuild kit :swoll:
    Jan 11 2007
    Yeah, I had Jarl balance the rotating assembly. He was literally the only one in the valley with the bob-weights (that's not to necessarily say that he was my last choice.)
    LOOKING FOR:
    Feb 23 2010
    2000 S4
    Earth
    I am so glad he was able to do your with your balancing job.(Your trust is worth alot.) I have been doing buiness with him for 17 plus years and he has always been good. too bad we could not do anything to help the OP. (Due to the fact he is another country.)
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Geez guys, bob weights are weights you build up to mimic the weight of the rod/piston on each journal since you can't spin the crank on the balancer with those parts attached. They are installed on the rod journals, crank spun, and counterweights either drilled to reduce weight or Mallory metal (heavy metal) added to balance out the crank.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Feb 23 2010
    2000 S4
    Earth
    Really
    Deactivated Four Rings
    Oct 16 2010
    DavidhogAJ
    https://t.me/pump_upp
    I heard that the stock rods can hold up around 500hp.
    Feb 20 2008
    belgium
    Quote Originally Posted by slow ride View Post
    Well this was something we allready knew but thanks for the tip
    Apr 20 2005
    New Hartford, IA
    Just making sure :) Some didn't seem to have it down or I figured it would help others not up on this stuff.
    I'd measure the new rods big and small end and compare to the stockers. If it's sort of close it might be just fine or you can remove enough weight to make them close, etc. Just wouldn't want any crazy differences. It's crazy what they want for aftermarket china rods for these engines thougth. Price you pay for not dealing in large volume I guess.
    02' Tundra
    Feb 20 2008
    belgium
    The balancing thing is quite a PITA as NOBODY around here can do it. I'm getting quite frustrated about it. There's LOBA in Germany and one place in Holland that does it. Loba is good but downside is , it's 500€ for balancing rotation parts only and sending my block is 200€ and getting it back is another 200€ so around 900€ for ONLY balancing the engine without assembling anything back together. Nothing wrong with there price offcourse it is what it is but the fact that they are over 600km's away and a short block weighs 81kg is quite a downside as I can't/won't assemble it myself I want the short block returned to me fully put together and balanced.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    mine in the process of balancing.. not sure why any engine builder WOULDNT have the skills/knowledge
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jan 11 2007
    I think it's more that they don't have the hardware/weights than they don't have the knowledge. The machine shop with the literal best reputation in the valley simply didn't have the bob weights for my engine, as it's probably not worth the investment to do one engine every couple of years or whatever.
    LOOKING FOR:
    May 16 2008
    South Texas
    Wow that's a chunk of change.. There is one shop local I trust with my machine work and it's $310.00 for balancing a V8.. About $250.00 for a V6.
    Sep 11 2009
    NE
    You guys need to keep in mind that while US is the land of V6/V8 engines and as such with option for shops that do know what they are doing and have the equipment, europe is not. That's a land of I4 engines and finding a shop that can balance V6 could be problematic, at best.
    Feb 20 2008
    belgium
    Quote Originally Posted by Scotty@Advanced View Post
    The shop in Holland quoted me 386€ ex btw (+21%) so around the same and that shop is also a good trip away from me so costs will rise with sending the block there + I have NO idea if they can be trusted so.... I'm not keen on having the most critical parts of my engine balanced by a place that I don't know if they are really up to the task concidering your build stands or falls because of this and if they should F up I'm seriously fooked
