Welll I'll just list everything worthwhile
-Cabin Filter
-Air Filter
-Coil Packs
-Spark Plugs
-Fuel Filter
-Mounts (Engine/Tranny, for better ride and better for engine power)
-Oil change with filter change, maybe a few flushes
-Coolant flush
-Transmission Fluid (if TIP, if 6speed then consider a new clutch, hell why not)
-Rear Diff fluid change
-Engine bay cleaning+ cleaning of ypipe, pressure pipes, throttle body boot
-POssibly gaskets? if you need to.
EDIT :
Oh yeah and a full TBelt kit. Def. Do this while having all this other work done and put it. Get the one with the belt, acessory belt, water pump, thermostat, pulleys, coolant, the whole 9 yards. A nice running engine wont be so nice with a broken tbelt and bent valves, messed up cylinders.... just get the kit before anything else.
