Some things to note for the rear all you have to do is remove the two upper 13mm bolts on the shock and then the lower big shock bolt I used a 13/16th on this fit tighter then the mm equivlent.
Then lower or remove the 2 subframe bolts and with a pry bar nudge out the spring it's really simple just make sure you do one side at a time.
I had people tell me to remove the headlight sensor on the driver side but I saw no need to do that as the whole assem moves with the sub frame I was also told to remove the rear lower control arm bolt this is also not needed.
For the vogtland coilovers it's also help for adjusting the rear's to trim off some off the inner fender well lining I have a picture of this posted below I just used straight cut tin snips but you could probably just use some good scissors.
Now on the front all you do is unbolt coolant resvoir on the driver side and remove the whole plastic cover assem over the battery and brake resvoir this all done to gain access to the six upper strut bolts 3 per side.
Unbolt these then unbolt your pinch bolt for the upper control arms
And then unbolt your sway bar from both side then pull the mofo out.
I was told to unbolt the steering intially but this is not needed.
Here are just some random pictures I took during and after the install note the picture that shows the trimmed fender well to ease in adjusting the rear vogtland coilovers I basically trimmed it so it a little above the perch.
