Results 1 to 40 of 42
    Veteran Member Four Rings gcoy's Avatar
    Apr 06 2009
    2005 B6 S4 6mt Avant & 2001 B5 S4 6mt Avant (Sold) & 2007 VW Passat 3.6 4Mo wagon
    Boise Id
    Keep running out of gas w 1/4 still on the gas gauge
    The strange thing is that when I fill after the car runs out the tank fills up around 14/15 gallons. The tank holds 17.4.
    Has anyone else had a similar issue? & yes I try to fill before I hit 1/4 but our cars go through gas so fast that sometimes I get caught off guard...
    Thanks
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    Really really bad for fuel pump and fuel filter to do that all the time. I would change your filter every 10k if you run it to empty over and over again.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Apr 06 2009
    Boise Id
    Yes, I should clarify. This is the third time in two years. Car has 104k miles & I changed the fuel filter about 3k miles ago. The fuel pump has never been changed that I know of. I bought the car w 68k on it...
    Feb 19 2012
    Draper, Utah
    Oh ok. You had me worried.
    ...BBK coming soon
    Established Member Two Rings P_Diako's Avatar
    Oct 08 2011
    04 Audi S4
    Probably your sending unit is bad and it's giving a faulty reading to your fuel gauge...
    Apr 15 2009
    Chi
    it's a faulty fuel gauge. I had the same problem, and learned never to trust it. Instead I reset my trip odometer on each refuel, and start looking for shell when it hit 100. You can get it replace of course, it doesn't cost too much and doesn't seem too difficult from the guide i had read (never done it though)
    Aug 08 2010
    Alaska
    Both my '05 B6 S4s would bury the needle past E before running out. I never did run it dry, but many times filled up with 16.5+ gallons. I also do believe there are dual tanks, one on each side of the drive line.
    Established Member Two Rings mountainsnbirds's Avatar
    Nov 25 2008
    05' S4 Avant 77' Puch Maxi
    WVU, Morgantown, WV
    I had the same problem and it took me forever to pin point the problem. My problem started the week after i had a new fuel pump and filter installed. At 1/4 tank of gas the car begins to sputter and turns off.
    And every time after that i was out of gas at 1/4 tank. But the mystery continued because i could only ever put 11.5-12 gallons of fuel in when it was "out"
    To make a long story short.....I believe(at least in my avant) the gas tank is a Saddle tank, and the hose connecting the two sides broke or stopped transferring fuel to the pump side. So there was always about 5 gallons remaining in the tank even when the car was "out" of gas.
    Unfortunately, to fix this would require a tank removal.
    My fuel gauge was not broken and the fuel sending unit(my first thought) was not bad either.
    I hope this helps, good luck!
    Active Member Three Rings tylerS's Avatar
    Aug 02 2009
    nw
    start with cleaning off the fuel level sensor in each tank. easiest, cheapest, and will probably fix your problem
    Veteran Member Four Rings 0000 V8's Avatar
    Feb 19 2010
    Porsche Cayenne Turbo, B6 S4, C5 Allroad, B5 A4, Prius C
    Sacramento, CA
    I have the same problem. It cuts out around 1/4 tank, but the computer display also shows about 90 miles till empty. Super annoying.
    Senior Member Three Rings dr.evil's Avatar
    Nov 27 2005
    Sparks, NV
    Quote Originally Posted by 0000 V8 View Post
    Same here. I just fill up with 200 on the trip odometer. Its harder to watch that than the gauge / DTE meter on the dash, and I've ran out a few times.
    Anyone has a how-to on sender replacement?
    2014 SQ5 Prestige - Glacier White
    1970 Mustang BOSS 529
    Veteran Member Three Rings Lefthook's Avatar
    Jun 09 2008
    Cummins Ram, 1967 Cougar XR7G, CB750k3
    Newberg, OR
    Quote Originally Posted by mountainsnbirds View Post
    hmmmmmm.
    My 04 Avant only ever takes about 14-15 gallons. I don't think I've ever gotten close to 16 gallons even when the DTE was showing zero.
    B6 S4 Avant 6MT|| Brilliant Black|Silver
    JHM 93 Tune|JHM LWCP|JHM Stg 3+LWFW|Full Piggies|2.5 Magnaflow
    Apikol Snub+034 ZC Bracket|Apikol Diff|034 Trans|Stern Motor|034 Density CA
    B5 spring perches|19 Matte Black VMR710|Ventus V12|Stoptech Pads+SS lines|AR track rotors
    Black e-codes|20% Tint|Plasti-dip|Hydrographic CF print mirrors+roof rails+bumper trim
    Sold.
    Jan 24 2008
    West Coast
    Quote Originally Posted by tylerS View Post
    It's not often that Tyler and I see eye to eye, but I'm 100% in agreement. This is the best and cheapest option - and will likely fix what's wrong.
    Moderator
    Sep 15 2007
    Tacoma, WA
    When I bought my car, it did the exact same thing. I took it to the dealership and they found a pinched fuel line in the back. Evidently someone was back there before.
    2004 S4 Avant
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    If you have a vag-com then I would try running and output diagnostic check in the 17-Instruments. It should sweep the gauges from all the way left to all the way right then stop in the middle. If the fuel gauge goes too far to one side, doesn't go far enough to another side, or doesn't finish its travel correctly then you need a new instrument cluster. That is something easy to check and you don't get fuel on you because everything else will require basically opening the tank from openings under the rear seat.
    Quote Originally Posted by Lefthook
    hmmmmmm.
    My 04 Sedan is and past 04 Convertible was the same way.
    Apr 06 2009
    Boise Id
    Great info, How do I get to and clean the fuel level sensors? One on each side of the tank? Thanks g
    Veteran Member Three Rings Rico750's Avatar
    May 19 2007
    B7 S4| 07' R1 | 08' R6 | 09 X6 |
    Tennessee
    Quote Originally Posted by gcoy View Post
    yeah i'd like to know this too, i got same problem... at 1/4 tank (by the gauge) i run out of gas
    2004 S4 | 18" RS6 rep Rims | Valentine 1 | BOSE + Blaupunkt sound | K&N | H&R sport 1.2" lowering | KONI | 30% tint | FI down-pipes | FI catback 2.5" | JHM tune |
    Apr 06 2009
    Boise Id
    Anyone??? have info on cleaning fuel level sensors? Thanks
    Aug 02 2009
    nw
    there's a diy on here if you search. you need to pull the rear bench, remove the two covers to access the tank. take a hammer and screw driver and hit the locking ring in a counter clockwise motion. remove the lids, then the senders. take a clean pencil eraser and clean the metal contact track.
    Apr 06 2009
    Boise Id
    Apr 06 2009
    Boise Id
    I pulled the bench and accessed the tank. My car only has one float and sensor, on the drivers side. I cleaned the contact and put things back together. Now I'll see if i run out of gas on the next 1/4 point on the guage... (05 Avant)
    Veteran Member Three Rings blackedoutt's Avatar
    Sep 16 2007
    B7 S4, MK1 TT, Tacoma
    Southern Indiana
    Bumping this old thread. Was it sending units or pinched/cracked line? I found the OEM p/n for the lines from one side to the other of the saddle tank and don't think it would require removal of the tank to complete. Anyone else ever change those?
    YEAH BUDDY!
    Active Member Two Rings Zhek18's Avatar
    Jan 18 2014
    Tualatin OR
    Hey I'm about 2 years behind but I'm just wondering what was the problem with your gauge, cuz I have a Quattro b7 and I'm having the same issue running out of gas at 1/4, I've been reading lots of post but nobody finishes lol, so what fixed your problem?
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    you have 2 (two) sending units and one and/or both are bad... search and you will find how to test which one if not both you need to replace...
    you will have a sending unit on both drivers and passenger sides, fuel pump is located on passenger side (for both B6 and B7) ...
    idk what ^.^ is talking about :/
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Apr 06 2009
    Boise Id
    Cleaning the float sensor worked for me. I have run my tank lower than 1/4 tank a couple times with no problems.
    So, I guess I have fixed the issue, but just to be safe I always try and fill at 1/4 tank....
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by Zhek18 View Post
    ** EVAP purge valve
    ** Fuel Level Sensor
    I've had my Avant run out of gas on me several times when the gauge hits 1/8th tank. My first experience of this was quite horrible because I've never personally run out of gas and the symptoms led me to think of a completely different catastrophic outcome (you can seaRch for it). This is my theory on the 1/8th gas thing and how it related to the EVAP purge (feel free to dispute it):
    Our engines are known for getting hot so what if by some off chance, the EVAP is affected, causing it to malfunction and not effectively purge a bloated fuel system of its gas fumes when the tank is half full or almost empty? All that pressure within your fuel tank might mess with your fuel level sensors. (If you don't believe there is a negative pressure in your fuel tank, open it up after a long hot drive, you'll here a hiss)
    The EVAP purge sensors have also been known to go bad in B6 A4s; I would personally look at this $55 component before jumping on the $250 sending unit.
    Reason why I don't think it's a faulty fuel level sensor: the gauge is working because it reads how much fuel you have from F to 1/8th before E. It also gives you a guesstimate of how many miles you have until empty via the ECU....FYI this doesn't necessarily mean the number is accurate but it gives you an idea of how far you can go before empty.
    EDiT:
    Haha, I haven't tried this yet. I just ordered myself a new EVAP from ECS too; wish I saw this earlier.
    2015 B8 SQ5
    Click Here
    Past
    Sep 16 2007
    Southern Indiana
    Hot or cold, long or short drive, I still had this issue. I had a friend recommend to me to open the fuel cap to equalize tank pressure but that did not help. Still hoping some one can figure this out. In my case, new pump, lines checked (1 replaced), both senders cleaned and ohmed out fine. There is still the potential for the senders to be bad but I have not replaced them because I have no comfirmation that if sensor output doesn't match actual tank level it will cause the pump to suck air, I don't think it cares what the senders say if should still suck all the gas from the tank. I've popped the covers off the tank when it "ran out" still looked to be half full.
    YEAH BUDDY!
    Veteran Member Three Rings vacsimile's Avatar
    Nov 15 2008
    2004 Audi S4, 1991 Nissan D21, 2001 GTi VR6
    Outer Space
    Tank routing, especially on the driver's side tank access (2nd sending unit and siphon pump side). It's either one of the lines getting knocked loose or the routing of the lines being wrong (likely due to one being disconnected) which causes the float to hang on the lines instead of dropping all the way down.
    Apr 06 2009
    Boise Id
    Quote Originally Posted by vacsimile View Post
    Very good point
    I had a hell of a time preventing the lines from hitting the float, & holding the seal in place, while closing the tank
    Apr 06 2009
    Boise Id
    Very good point
    Come to think about it,,, This may have been my problem all along.
    Cleaning my fuel level sensors maybe didn't fix my problem, but I'm sure it didn't hurt
    Sep 16 2007
    Southern Indiana
    It is quite difficult to keep all those lines out of the way, but still that will only make the level read wrong. How could that make it so that it runs out of fuel with a lot left in the tank? Maybe I still have a line loose or routing wrong, any routing diagrams? It was all unhooked the first time I got in there so I made my best guess based on where things fit together.
    YEAH BUDDY!
    Nov 15 2008
    Outer Space
    Quote Originally Posted by blackedoutt View Post
    True, if the float is just hanging up it doesn't explain it running out of fuel when there is fuel. I've had this happen a few times and from what I can remember it's one of the suction lines that doesn't stay connected and that's what the float hangs up on. This also keeps fuel from being transferred to the passenger side where the pump is. The line connects to the bottom of the driver's side siphon pump at the bottom, and it's on a pivoted connection. It's easy to knock it loose when you install it. If all the lines are hooked up there shouldn't be interference with the level float, just make sure it can move freely without snagging on wires or lines. There are diagrams for the lines inside the tank but they're more of a schematic than a routing diagram.
    Dec 02 2007
    DC/MD/(VA)
    ...well since I last posted in here, my fuel gauge has gone completely nuts. I filled up last night and on my way home (about 5mi from gas station), I went from Full down to half a tank. I'm currently looking at the fuel pumps and sending units but want to hold off for simple fixes like cleaning the sender sensors or as posted above, untangling lines. Like blacked out states, is there a diagram for these parts?
    EDiT:
    Nvm, found some useful links:
    clean/test fuel senders -> http://www.audizine.com/forum/showth...l-sending-unit
    checking the fuel return line -> http://www.audizine.com/forum/showth...-acting-stupid
    better follow up to this thread by another member -> http://www.audizine.com/forum/showth...2C+fuel+sender
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Logic would say, that if you run it down to a quarter tank and it runs out, it should also then stay at the full mark and not move the needle for well over 50 miles of driving after filling to the full mark. Id pay attention to that just as much if I had this issue
    Sep 16 2007
    Southern Indiana
    Argreed. Mine stays on full for over 50 miles for sure and " runs out" around half on the gauge with a true quarter left in the tank. I'm guessing something came unhooked and is both skewing my sender and not sucking fuel from the left side. Time to crack into the tank yet again.
    YEAH BUDDY!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Read post #3 in this thread: Clicky click
    Dec 02 2007
    DC/MD/(VA)
    EDiT:
    Performing these checks today; will report back later
    2015 B8 SQ5
    Click Here
    Past
    Dec 02 2007
    DC/MD/(VA)
    As promised here's the update:
    The fuel sending unit on the pump side seems to be running ok, put a DMM to it and it read 46.6/300 (per the link above).
    The fuel pump looks to be in tact but I'm not sure if it's on it's way out or not. When I turn the ignition to ACC, fuel pump doesn't sound like it's cold priming, like it did during the winter; I got three repeating "putters" before it stops and I start the car.
    The driver side fuel sending/fuel guage sensor was the one that sh*t the bed. When I opened the top, I saw the actual unit floating in the gas tank, on it's side.
    How it's suppose to look:
    2015 B8 SQ5
    Click Here
    Past
    Sep 16 2007
    Southern Indiana
    Well, looks like you found your problem lol. Can you please take a picture of how the lines are connected to the "Y" piece on the driver side sending unit/suction pump pick up? Mine has a brown piece that snaps to the bottom of the sending unit and I'm not entirely sure my lines are connected properly and the brown piece is snapped into the bottom of the sending unit right side up.
    YEAH BUDDY!
    Dec 02 2007
    DC/MD/(VA)
    [QUOTE=blackedoutt;9667251Can you please take a picture of how the lines are connected to the "Y" piece on the driver side sending unit/suction pump pick up? Mine has a brown piece that snaps to the bottom of the sending unit and I'm not entirely sure my lines are connected properly and the brown piece is snapped into the bottom of the sending unit right side up.[/QUOTE]
    It's suppose to be right side up if I'm understanding you correctly. The entire sending unit on the driverside is suppose to hang at an angle.
    It's why my gauge reading was completely off because it was floating in the tank versus suspending above the tank.
    2015 B8 SQ5
    Click Here
    Past
