Results 1 to 6 of 6
    Established Member Two Rings NewB7's Avatar
    Nov 15 2011
    Bay Area, Ca
    Proper brake bedding procedure?
    I recently installed zimmerman cross drilled rotors and hawk pads up front. When it came time to do the brake bedding procedure I was rather confused as the Hawk pads stated:
    After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop.When completed with this process, park the vehicle and allow the brakes to cool completely before driving on them again. Do not engage the parking brake until after this cooling process is compete.
    Then while reading the zimmerman instructions it stated: Avoid hard braking for 300-500 km.
    Ibis S-line, APR Stage II, 034 HFC, Carbonio CAI, 034 mounts, Apikol Snub, 034 CC, STaSIS exhaust, Zimmerman cross drilled rotors/Hawk HPS pads
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    Quote Originally Posted by NewB7 View Post
    Usually they say avoid hard braking AFTER the bedding procedure for x number of miles/km.
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    I followed a procedure similar to the above for my BBK, with the exception of parking the car and allowing the brakes to cool completely before driving on them again. I repeated the above process a total of 3 times. Brakes seated well, no issues to date.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Nov 15 2011
    Bay Area, Ca
    Quote Originally Posted by JPT View Post
    I see. It didn't state AFTER the bedding procedure so I was a bit confused. Thanks for clarifying.
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    my method (which may be different from others but has always worked for me)
    4 cycles of 80mph with a hard stop 60mph then after those 4 cycles are done i do...
    3 cycles of 80mph with a hard stop to 30mph then after that is done i drive for at least 30 minutes and do not touch the brake pedal once.
    this is hard to do in a heavily traveled area, i am very lucky to live very close to a 2 mile long straight on ramp to a major highway so i can get most of the braking done by the time i enter the actual highway. I also do this at about 2 in the morning to make sure there is zero traffic
    Oct 02 2006
    Wadsworth,OH
    I've always followed the instructions the link below provides. Haven't ran into any issues either.
    Click HERE
    I hope this helps!
    Jason
