Originally Posted by
PKmode
That noise is not from the pump. I believe it to be the rack. Sorry for the bad news. It's probably fine to drive for a long time though.
Racks do not make noise when they go bad... they leak from the output seals, its just a simple hydraulic system.
Its your pump but its pretty normal, when you turn the wheels at a stand still, the steering system is at its maximum pressure. This plus the engine being at idle causes the pump to be overworked. The squeal that you hear is an increased radial load on the pumps internal bearings from it being overworked. The squeal can also come from improper lubrication of the pump do to low fluid. So check your fluid, but if you rev up the engine while turning the wheel I would expect the noise to decrease if not disappear.
