Results 1 to 17 of 17
    Veteran Member Four Rings bigdo26's Avatar
    Jul 21 2009
    Stoptech ST40 - initial track review
    Starting the post here, will update with more details tomorrow after day 2 at the track. But in short, the Stoptech kit is absolutely phenomenal. Using PFC-01 pads up front, Hawk HP Plus rears, I can engage ABS at 110mph+ with absolutely NO hint of fade after driving for a 20 minute session. Pedal feel is excellent, very firm and takes a bit of pressure (right amount of pressure) to modulate brakes, but it's quite easy to brake at threshold or lower. For the first time at the track, I've reached the limit of the tires (Goodyear Eagle F1 assymetric 240 treadwear rating) under hard braking.
    The difference between this setup and stock absolutely blew my mind today - exceeded all expectations. The PFC-01's are pretty easy to work as well. Good initial bit and quickly increasing power, but very solid and with the stiff pedal feel with the Stoptechs, I could get exactly the amount of braking needed at any speed. Heel toeing is far easier and consistent with these brakes, as they are firm and the pressure required to get threshold braking lines up the brake pedal perfectly with the gas. And with zero fade, every stop is exactly the same as the last.
    I wish I had bought these as my very first upgrade to the S4.
    For street driving - they are good, but not necessary at all. For the track - an absolute must!
    Videos and more pics to come tomorrow!!!
    2014 Mustang GT w/track pack and Recaros
    Sold: B5 S4
    Track videos: Watkins Glen
    Track videos: Limerock Park
    May 13 2011
    2015 BMW F30
    Cool, I want this kit.
    | Autospeed | JHM | Pure MS
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    brake fluid used?
    Veteran Member Three Rings papuc14369's Avatar
    Apr 06 2008
    NorCal
    Quote Originally Posted by S4 00 2.7 View Post
    I have a set of rotors and brackets for sale. Calipers need to be repainted otherwise in great condition. Send me a PM if you're interested.
    2001.5 Audi S4 - Santorin Blue - Stage 1 & dearly missed - RIP
    2000 Audi S4 - Nogaro Blue - Tial 770r - SOLD
    2001.5 Audi S4 - Black Avant - Bone Stock - SOLD
    2001.5 Audi S4 - Nogaro Blue Avant - Stage 3 RS6 Turbo - Daily Driven
    2000 Audi S4 - Laser Red - Sold
    Veteran Member Three Rings Number54's Avatar
    Dec 04 2007
    Switzerland
    I ran a front ST-40 kit kit during 4 years for track duty. No problems, except the red calipers were stained black after a while. I recommend black calipers for track ppl now:)
    • Audi A3 3.2 Quattro (8P)
    • Porsche 911 GT3 (996)
    • Audi RS4 (B5)
    Jul 21 2009
    Quote Originally Posted by Sales@DriveAuto View Post
    brake fluid used?
    Motul RF600. Been great for me over the past 3 years
    Sold: B5 S4
    Jul 21 2009
    Quote Originally Posted by Number54 View Post
    I second that - only reason I got red is cause they were on clearance and I got the kit for a fantastic deal. Other option was yellow... I like red better. Black is best
    Sold: B5 S4
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Would st40's fit under 17s?
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Quote Originally Posted by Peter1.8t View Post
    Word on the street is they will. In OP's first thread on the st40 he has then fitting behind the stock 17 avus wheels and I don't believe he ran a spacer either. Scroll a few pages back and have a look, should be easy to find. I'm on my phone otherwise I would check and link it for you.
    BTW I bought this exact same kit but have yet to install and the only wheels I have are stockers
    Apr 06 2008
    NorCal
    ST-40s will fit behind the stock 17' Avus wheel but the clearance is very minimal - but it will work.
    Dec 04 2007
    Switzerland
    ^^^ 2nd.
    Clearance is really minimal, 1mm or so. You can't have wheel weights there so have to get a static tire balance. I also ran RBF600 all the time.
    • Audi RS4 (B5)
    Jul 21 2009
    I've fit the ST40's under my stock Avus 17's without spacers, and under another set of 17's with a 5mm spacer. I need a 2mm min spacer for the 18's due to the offset. Guess I"m starting to collect wheel setups :)
    Back from day 2 at the track and the slight shuddering I had yesterday was completely gone - nice smooth, strong braking all day long. I have a little too much rear brake power now, as I was engaging ABS in the rears first and "wiggling" in the braking zone (which the officials didn't like all that much... was completely controlled though). I should have some videos up shortly. Got a great one following then passing an E39 M5 - real nice guy driving it.
    But in short, 100% satisfied with the brakes. I gave them a hell of a workout the past 2 days, slowing from ~122-123 to about 50 lap after lap on the main straight, and then from ~95-100 to about 70 in a couple other braking zones. Not a HINT of fade all day. Well worth the $1400 I paid for them!!!!
    Sold: B5 S4
    Jul 21 2009
    ^^^ 2nd.
    Can move wheel weights inboard on wheels to gain clearance...
    Sold: B5 S4
    Apr 13 2012
    the 332mm kit should clear the 17".
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    i see that you're running PFC-01 pads when i searched them i noticed they dont come with abs sensors, how/what did you do to make the abs still work and keep the light off?
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    ^also curious... My Hawk Blues don't have sensors either, so I just have the OEM pigtail taped back to the wheel speed sensor cable. ABS light is on, but my pixels are almost gone so I don't really notice it
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by bigdo26 View Post
    I must have missed this thread somehow, but good to know you like the kit. Keep us updated on your subsequent impressions
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
