Results 1 to 40 of 46
    Apr 07 2012
    Miami
    sequential manual b5 rs4
    are there any sequential gearboxes for this car?
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    no
    Sep 25 2010
    Adelaide, Australia
    but there is a sequential shifter setup for the 01E
    http://www.sqsracing.com/produkt/354...di-quattro-01e
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, GT30r, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    Quote Originally Posted by cosworthsti View Post
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    Sick!
    WTB - Electric high flow fan kit - FORGE 007 DVs
    Apr 07 2012
    Miami
    I only ask since I'm starting the B5 project I want a good gearbox to efficiently handle the power and provide accurate shifts and a more reliable platform. I though maybe something like this existed for the B5 S4/RS4.
    http://www.youtube.com/watch?v=ipC8Ire-cNg
    May 16 2008
    South Texas
    Gearbox efficiency has nothing to do with a sequential shifter. Straight cut gears are required as they are more efficient than helical gears. As far as reliable, once built an 01E can be pretty solid, but plan on spending some serious money, which will still be cheaper compared to a $20k-$30K motorsports gearbox.
    Apr 07 2012
    Miami
    Quote Originally Posted by Scotty@Advanced View Post
    Yes I understand that bit what I ment by efficiency is the shift speed and accuracy. With a high power car a sequential can be very beneficial to performance. Just look at the way that Z06 up shifts and downshifts.
    Veteran Member Three Rings Taloras's Avatar
    Jan 19 2011
    PDX
    It's efficiency on the order of a handful of milliseconds in either direction. With enough money, anything's possible, but on our cars, you'll get more speed over a given distance with a built 01E and more engine mods for more power than in dropping thousands and thousands of dollars on a gearbox that'll only save you like 100ms on a couple of gear changes over a quarter mile. MUCH better places you can spend money to shave time off than some flappy paddles.
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Ad an other 12 to 14 k to your 30k engine...
    7k tranny
    3.5k shifter box
    1k Quaife
    Is't a TT, but Par dogbox with SQS seqshift will give you this...
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    May 16 2008
    South Texas
    A sequential shifter is significantly slower in shift speed when skipping gears. IMHO the 3+ grand spent on one can be better applied elsewhere and get more gain.
    Apr 07 2012
    Miami
    Quote Originally Posted by GURUMAN View Post
    7k tranny
    3.5k shifter box
    1k Quaife
    So this can be used on the B5? It looks amazing, very simple to use. I love a H pattern stick shift but there's a reason sequential are used in race cars and that's simplicity and speed which is what I want. The cost though OUCH. My SL55 cost me less than 9k to get into the low 11s (crappy launches, it has high 10s potential) and it's a heavy heavy car so this is definitely an expensive build.
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    friend of mine has a sequential in his corrado VR6 turbo's, it's pretty sick shit :-)
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Jan 19 2011
    PDX
    Even with a LOT of money (15k+ for a build), X dollars put in to power, handling, and weight reduction will yield a MUCH faster time around a track than X dollars put in to a fancy gearbox that only takes a few milliseconds off of shift times. Racers use sequential boxes in conjunction with all those other things to eke as much out of the car wherever possible.
    Apr 18 2007
    ny
    Fuck that, who want's to drive a built S4 without a clutch?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    May 16 2008
    South Texas
    Add on sequential shifters are neither simple nor fast.
    Aug 13 2008
    Indiana
    Quote Originally Posted by A62TURBO View Post
    It still has a clutch.
    -Nic
    Apr 18 2007
    ny
    Quote Originally Posted by somebody5788 View Post
    You know what I mean.
    SOLD
    Greg
    C5UNION
    Aug 13 2008
    Indiana
    Sequential gearboxes are just a different form of switching gears. It's just like a motorcycle.
    -Nic
    Established Member Two Rings 04/01-s4's Avatar
    Jul 28 2009
    01 s4,03 1500hd,2006 FXSTI
    Bloomsburg PA
    Obviously they exist but the average b5 owner doesn't have the money or "willpower" to drop 15+k on a dogbox... Do we all secretly want one? probably
    2006 HD FXSTI
    2003 silverado 1500hd 4x4 (DD)
    2001.5 s4 / 034 STK conversion in process
    TIA certified
    Mar 13 2007
    Montreal
    Ok but you've asked for a specific 800 whp, try this with a SL55 engine, I dont think you would achieve this without spending 40k
    11 to high 10's coul be achieved with stock tranny and 600whp
    You have to compare apples to apples
    You should start a thread about clutches now, I think we are ready to answer !
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    May 16 2008
    South Texas
    Quote Originally Posted by 04/01-s4 View Post
    Dog boxes themselves run from $7-9K excluding the sequential shifter.
    Apr 18 2007
    ny
    I was under the impression that the SMG's don't use a manual clutch but rather an automatic one.
    SOLD
    Greg
    C5UNION
    May 16 2008
    South Texas
    It really depends on what kind of sequential box your talking about. Sequential in itself does not imply any particular type of clutch, however most motorsports style of sequential boxes are computer controlled and have an automatic clutch shifted via paddles on the steering wheel (a much more advanced SMG BMW used) . Drag race sequential transmissions are shifted with high pressure air solenoids and may or may not have a clutch. Dragsters don't even have a transmission they just have a series of clutch disks.
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    Apr 07 2012
    Miami
    haha no you misunderstood I didn't compare the SL to the B5 I was just saying in relation to modification prices that's all ;)
    Apr 07 2012
    Miami
    ok even though i tend to ignore any negative comments or irrelevant ones I'm curious to know how I offended you. I mean the way you talk for example "average S5 owner" or "no one is willing" I mean why don't you think it's possible someone actually wants to, god forbid, do something different. at the end of the day isn't it nice to see different builds and what not. it's not like this thread is insulting anybody or being useless and off topic. if it was me and i was offended by a thread id just not visit it and waste my time because the OP of the thread is obviously an idiot who is asking stupid questions about fictional gearboxes...
    Apr 07 2012
    Miami
    Quote Originally Posted by nthusiastt View Post
    thanks for the link
    Jul 28 2009
    Bloomsburg PA
    First things first you didn't offend me at all I was just poking fun. Its not s5 its B5, its our cars chassis code. That's part of why you're getting mixed results on here about your question.
    Of course at the end of the day its awesome to see new builds and ideas, I'm all about that, that's why I'm here. How long have you had your s4? I'm not knocking your ideas at all you just have to understand there's a reason THIS exists.
    http://www.034motorsport.com/chassis...4-p-20003.html
    Obviously that's a joke but have you even begun tinkering around with your s4? Is this something you plan to have a shop do from start to finish? I'm sure there's vendors on here that will gladly take your inquiries if your serious about it. I never said its not possible either I actually said the exact opposite of that. Good luck anyway.
    2006 HD FXSTI
    TIA certified
    Apr 07 2012
    Miami
    "S5" :D Typo. As for having the B5 S4 I haven't even bought one yet so I'm even more behind in the build than you think but that's just the way I like to approach things, gather the info and the cost estimates and what not before going into it, it's just smarter that way since this isn't going to be a DD. I don't want to build this car progressively but rather all at once because after all it's a project car and about enjoying in and having fun with it ;)
    Now I'm yet to receive a PM from the owner of that "turn key" 700whp built motor but it looks to be a good option and cheaper too. What attracted me to the B5 was the fact that it was AWD, was a major sleeper and has alot of potential and isn't too expensive to build considering what you get after you're done, a car that can absolutely walk exotics and supercars. I actually saw this video and fell in love with it.
    http://www.youtube.com/watch?v=q5xrZ_xqVxY
    Apr 07 2012
    Miami
    By the way thanks for the link on the shift deleter. I can't believe I want to waste money on a sequential gearbox when I could get that for $1000...............and best of all my wife can change the diapers in the area the shift lever used to be. Now I can talk on cell phone, eat or even sleep without having to worry about stupid gear changes :D xD
    Nice link by the way haha I know this is gonna sound bad but for a second, a very brief second :D, I took it seriously but after the first 2 sentences I was about to pass out from laughing ;)
    Aug 13 2008
    Indiana
    There are some that do but in a B5 I think that it would typically still have the clutch petal and just have the shifter change for quicker shifts. Potentially combined with a hand clutch (it's amazing the kind of shift times you can get on a bike with a hand clutch and sequential gearbox)
    -Nic
    Nov 30 2010
    saint louis , MO
    If you can afford to drop money on a sequential tranny you should probably invest in a better platform from the get go.
    Apr 07 2012
    Miami
    Quote Originally Posted by bgzs4 View Post
    ...and why is this such a bad platform? In fact I think it's the only platform that's a complete sleeper with this potential. All other cars are either not sleeper and too expensive or too flash or not sleepers.
    Dec 03 2009
    PNW, Washington
    I like your attitude dude. Fuck all the guys saying you can't or shouldn't. Build the car the way you want it, besides its your money, you can do whatever you want with it.
    Oct 27 2008
    B5 S4 Avant
    cosworth just ignore the mass of sheeple on this board. Do what you want/can. I think the questions your asking and the interest your seeking is awesome whether or not you can do it doesn't really matter. It's a fucking way cooler topic than the mass of "my car squeeks, my window doesn't roll down, my boost tapers off, I've got a clicking noise, my spider hose is annoying, my camber bolt is rusted, what do I do!?!?!?"
    Senior Member Three Rings Matador's Avatar
    Apr 30 2009
    2004 R32
    Virginia Beach
    I wish you well in this endeavor, but please do some serious research into the end goal and purpose of this transmission and build. The money you're going to throw just into the transmission alone, combined with built engine and whatnot, you could have a fully built 996 which is even faster and lighter. Heck, throw in a few more bones (just money, right?) and you have yourself a Ariel Atom; a car that would destroy almost anything you could turn the S4 into. Is this just a plaything or serious track beast? Is there a specific racing class you're trying to achieve?
    Feb 26 2011
    las vegas
    post up pics of your car!
    Nov 30 2010
    saint louis , MO
    Lets see....
    Heavy? Check
    Poor weight distribution? Check
    Limited powerband? Check
    I love these cars but let's face it, not the greatest platform for all out speed. There is no such thing as a sleeper on the racetrack, just cars that are faster than expected. I can understand trying to be different or have a sleeper on the streets. But the racetrack isnt the place to show off originality. The point is to be as fast as you can. A c5 or 996 would make
    Much more sense. You could have a very built c5 track car for the price of the $30k engine you are talking about. I guess if you have unlimited money do whatever, I'll believe it when I see it.
    Dec 03 2009
    PNW, Washington
    Mr. Negative has entered the building ^^^^
    I'll just leave this here
