Results 1 to 20 of 20
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    Car shakes while braking on the highway...suggst?
    Recently replaced the torn CV boot on my driver side. I thought that would fix the issue however during highway driving the car tend the shake a lot but if I'm local driving I have no issues. Any idea what it could be?
    TIA
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2000 S4 Nogaro Sedan Stage 3 WMS-Current
    2001 S4 Sil Sedan ASP Stage 3-SOLD
    2002 S4 Pearl White Avant Stock-SOLD
    2000 S4 Nogaro Sedan EPL Stage III-SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III-SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s-SOLD
    2001.5 Nogaro Sedan AWE Stage III-SOLD (x2)
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast-SOLD
    Senior Member Three Rings kjr7888's Avatar
    Nov 23 2006
    NH
    warped rotor
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    Quote Originally Posted by kjr7888 View Post
    warped rotor
    This^^
    Garage: 2001 A6 2.8 FWD 5AT & 2002 A6 2.7T 5AT
    Aug 05 2011
    Memphis, TN for now!
    Does it shake during braking or all the time?
    If during braking it is a rotor problem. You could try to rebed them.
    If it shakes all the time it is a balance issue. I had a bad shake because at some point a tire was very low on air and was driven that way(by mechanic) and that cause the rubber inside to shed. At highway speeds the rubber would go and wobble intensely. I had the tire remounted and that got rid of the horrible wobble. Fix-a-flat can also do that.
    Feb 14 2005
    It has fresh rotors and pads and the shaking is coming from the driver side and not from the passenger.
    It doesn't shake all the time only when I'm break on the highway if I'm at low speeds city driving there isn't a problem.
    Tires are new and were balanced.
    Based on that do you guys still think it could be the rotors/pads?
    TIA
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Your arms and tie rods in good shape?
    Feb 14 2005
    The arms and rods were replaced 40K +/- miles ago
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    warped rotor
    Not always true. Often times people mistake brake dust deposits as 'warped' The brake dust can build up in certain places on the rotor more than others, thus giving it the 'warped' feel. OP, could be something with your steering rack.
    ..also check to make sure your wheels are balanced properly.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Aug 27 2011
    niles, il
    i too have this problem. i have the stoptech bbk with two piece rotors and i get violent shaking when i'm braking at high speeds down to about 30mph. regular city driving has practically no issues. also seems to get worse the warmer the brakes get.
    Nov 16 2010
    WetSide, WA
    Might take a quick look to rule them out. The rubber bushings dont last long if not tightened at ride height.
    Aug 05 2011
    I had some strong vibrations at around 40mph. Drove me crazy...I ended up changing the pads to ceramics and bedding them. I then happened to notice that one of my brake hoses had a strong kink in it. Seemed that previous owner replaced the passenger side one with a steel braided one and it developed a kink to the point where it looked like it was going to pop. By hand it flexed a lot at that point. So I replaced that hose with a stock rubber one and my vibrations are now dramatically reduced.
    I can't say for sure it is from the hose since I also rebedded and am using different pads but a vibrating hose may be a source of vibrations?
    Jul 28 2007
    RS5
    gta, ontario
    Get your rotors checked if they aren't warped or improperly machined from new.
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    hey man - I doubt this is a brake problem - I currently have a vibration coming from my passenger side, and it is actually a bad tie rod. But, I have noticed a slight clunk noise coming from that side when I go over small bumps at slow speed (and no, its not an engine mount or anything, I checked) - it is definitely the tie rod. Do you have any slight clunking noises coming from your drivers side? When I drive around town, the car is fine, but i noticed that it will start to shake a little at higher speeds (highway).
    2001.5 Nogaro Sport b5 s4
    Veteran Member Three Rings zrider91r's Avatar
    Jan 06 2012
    California
    My sisters Benz did this and a sway bar(or the cross brace [idk what they are called exactly]) was loose...
    possibly look into that?..
    Veteran Member Four Rings 99ebpsi24's Avatar
    May 04 2008
    10 S4 prestige, 12 A4 S-Line, 00 Stg3+ S4, 74 VW Thing, 74 Z28 camaro (32k original miles) 74 Z28 Ca
    Cincinnati
    I'm still putting my money on a warped rotor even though you said they're new. It's possible you got one that still needs turned from the factory. I'd check the rotors before you go spending any money on buying other parts.
    Current:
    19’ Ara Blue RS3 UniFlex stg1+, stg2 tcu, midpipes & IE intake
    21’ VW Atlas SEL Prem. R-Line
    15’ Sepang Blue S3 Prestige
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Senior Member Three Rings ontheedge56's Avatar
    Sep 13 2011
    01 S4 Avant
    Ithaca, NY
    my money's on a bad tie rod. jack the car up on that side with the wheel on and try to shake the wheel left to right (quick shakes) if its any of your suspension ball joints you should be able to feel it sort of pop back and forth.
    my 2c's
    Ever need help with your Audi in Ithaca. Hit me up.
    -Dan
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Quote Originally Posted by Yuppie View Post
    TIA
    Bed in your new rotors and pads properly and it will go away.
    http://www.zeckhausen.com/bedding_in_brakes.htm
    Oct 02 2006
    Wadsworth,OH
    Usually when you experience vibrations while applying the brakes it's from inconsistencies of pad material built up across the face of the rotor. This in turn creates a pulsating sensation in the steering wheel and brake pedal. This is often referred to as a "warped" rotor. The rotor isn't really warped it just needs to be turned and re-bedded.
    Usually you can have rotors turned for about less than $20 a rotor.
    Jason
    May 01 2010
    Atlanta
    Jason
    This x1000. So many people think rotors are warped when it's just uneven pad deposits. It's very, very difficult to warp a rotor.
    Jul 28 2007
    RS5
    gta, ontario
    He mentions fresh rotors, so check to see if they were improperly machined from the get go. While you've got the wheel off might as well check all the suspension components for play or wear.
