Results 1 to 22 of 22
    Established Member Two Rings black2.7t's Avatar
    Mar 07 2012
    2003 Audi A4 1.8T - traded 2005 Cobalt SS - DD
    knoxville
    Lightbulb Looking to buy a torx socket set, what are common torx sizes for b6
    Ok guys i'm in the market to buy some torx sockets as I'm tired of borrowing when I need to get work done. what are common torx sizes for the b6? like the brake caliper bolts are T45, just shoot me some sizes that you guys have had to use on your Audi so I can buy a set to be used later down the road
    03 A4 1.8T, silver/black, 5speed, Stage 1+ APR, gutted cat, APR Injectors, 6puck ACT unsprung clutch disc, light weight clutch masters flywheel, 034 street density tranny mount.
    Jul 31 2008
    lifted 96 Jeep Grnd Cherokee
    South of Boston
    Harbor Freight has an inexpensive set which I purchased several years ago and they have held up and have all the necessary sizes included. In other words I haven't run into a torx bolt that the set couldn't take care of.
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    ^x2
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    Quote Originally Posted by black2.7t View Post
    Which brake caliper bolts are T45? I did a B5 S4 caliper upgrade myself and never had to use and torx bits.
    On a side note, get a long T30 from sears, makes taking out the headlights a breeze every time. Also T27 for transmission pan bolts.
    Senior Member Three Rings Low-n-Slow A4's Avatar
    Jun 11 2011
    Bay Area, California
    Get a good set, should include T8, T10, T15, T20, T25, T27, T30, T40, T45, T47, T50, T55. My snap on set came with all of these and I use them on a daily, Benz and Audi. My though, just cover the spectrum, lol
    Mar 07 2012
    knoxville
    Thanks! and my front pads on my 03 a4 used a t45 to get calipers off.
    Quote Originally Posted by Low-n-Slow A4 View Post
    Mar 07 2012
    knoxville
    If you could post up a link of the one you purchased that would be great! I want to make sure I dont order a crappy set lol
    Quote Originally Posted by jackitorslamit View Post
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    i've had these for years. T25, T27, and T30 seam to get used the most.
    Mar 07 2012
    knoxville
    thanks you guys, I ended up ordering these gear wrench branded ones
    for 12$ Includes 1/4" drive bit sockets (T-10, T-15, T-20, T-25, T-27 and T-30) and 3/8" drive bit sockets (T-40, T-45, T-50 and T-55)
    Sep 06 2009
    Bay Area
    I would still get the T27 in 3/8, same with the T30 or like I stated above, the long T30 driver.
    Mar 07 2012
    knoxville
    Ill have to order those individually
    Quote Originally Posted by Kwarner View Post
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Guys, please don't make the same mistake I did and buy a cheapo torx head set (Powerbuilt from Autozone). Years ago, it was one of the 1st Audi specific tools I bought. Didn't think much of it and while they worked fine for a while, eventually one of them broke. Wouldn't have been such a big deal except it was during my CCT job and the chunk dropped into the open VC area. Luckily I was able to fish it out of the goooo with a magnet. Yeah, tools can break over time but this one shouldn't have... I mean, we're talkin about 10-15ft/lbs of pressure here.
    The more technical bits like torx / hex etc have finer tolerances and therefore must be of higher quality. While I can't speak to any other set, including those listed above which I'll certainly check out, do be mindful. Good torx FTW.
    Somewhat related note, a few months ago Jace pointed me in the direction of this awesome little set. While I'm not usually prone to impromptu tool purchases, this one was a no brainer... and surprisingly enough it's still available. Craftsman might have fallen off a tad over the years but these look and feel pretty solid IMO. Certainly worth the $40.
    Craftsman 19pc Universal Max Axess Socket and Ratchet Set, 3/8” Drive
    Senior Member Three Rings nazisled's Avatar
    Feb 21 2012
    Detroitish
    Quote Originally Posted by a4darkness View Post
    sooooo sick. and if it breaks, you can replace it for free, no receipt or questions asked.
    my dad has been buying craftsman forever and so will i.
    2003 A4 1.8TQA - 6 cans of plasti dip - Febreze air freshener - iPhone charger - filled coin holder
    Jun 11 2011
    I have a few gear wrench ratcheting wrenches and they have held up well. I would say they are the same quality as craftsman tools. Just dont impact them (heavy duty air tools) and they should be fine.
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Thats a nice little set, won't solve the torx issue though. Unless we are talking external.
    Sep 10 2011
    None
    You'll still need torx screwdrivers for those really small areas.
    Like the back seat of a Volkswagen?
    No. like the underside of the steering column.
    Dec 01 2007
    San Jose CA
    Yeah, wouldn't ever use em with air and good to know about Gear Wrench. Thx
    Quote Originally Posted by Kittrell View Post
    Wow, ya think?
    Quote Originally Posted by CrazyCal View Post
    A schooner IS a sailboat stupid head!
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Wow, ya think?
    Well considering thats not what this thread was about I didn't think it bears mention.
    Sep 10 2011
    None
    Play nice you two.
    Dec 01 2007
    San Jose CA
    Do I really have to parse out my sentences? Don't be that guy. Hence why I said, "Somewhat related note" as in 'hey look at this other kick ass tool that is very Audi specific... just like a torx set.'
    Mar 07 2012
    knoxville
    Well the torx set I picked out was normally +$30. I got lucky because advanced auto was running an online promotion, but hey for 12$ you can't complain on the deal I made :)
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Get this too! Great for headlight stuff, and anything else that might be a security screw/bolt.
    http://www.harborfreight.com/33-piec...set-93388.html
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
