G.I.A.C. versus the piggyback module
We had the opportunity to pit G.I.A.C. Software against a main stream, highly popular piggyback module. The results are worth a read. As always, don’t hesitate to reach out to us with any questions at all.
The car
Multiple tests were conducted on a 2010 Panamera Turbo w/Sport Chrono Package. AWE Tuning Track Edition Exhaust. 93 octane pump fuel. And just so this isn’t only about power… the car also had 22” ADV.1 wheels.
How it works
A piggyback module is able to produce power increases by bypassing the factory DME. Let’s take a closer look at what this means: In order to make the factory DME increase boost output, the piggyback module intercepts the boost signal going to the DME and makes it look lower than it actually is. The factory DME then increases boost output in an attempt to compensate for the “under boost” condition it is sensing. However, because the DME never sees the true boost amount going to the engine, and only an artificially lower value, the DME modes designed to protect the engine in the case of an abnormal overboost condition are rendered useless.
Since piggyback modules alter the sensor voltage outputs going to the DME by use of resistors, complete 3D map recalibration/reshaping impossible. Things like air/fuel ratio and boost can only be rescaled, they cannot be re-curved. Re-curving is especially critical on the Panamera Turbo as it has a boost related Exhaust Gas Temperature (EGT) protection dip, richening the air/fuel ratio (AFR) only at high rpms. If the piggyback module is programmed to richen the AFR, in addition to increasing boost, it does so linearly throughout the entire power band, including at high rpms, and consequently the AFR becomes excessively rich as the rpms climb. Conversely, if the piggyback module does not address AFR, then AFR becomes dangerously lean at high rpms as the DME never enters the EGT protection mode, since it is receiving an artificially low boost signal due to the piggyback module manipulation. Additionally, ignition timing maps are not directly adjustable when using a piggyback module, and fuel injector duty cycles, and High Pressure Fuel Pump duty cycles are at the mercy of what the DME can accommodate based on the manipulated sensor signals it receives.
In contrast: G.I.A.C. programs the DME directly, ensuring all systems will function as the factory intended. The G.I.A.C. Software has a clear performance advantage due to the fact that boost, AFR, and ignition maps are individually reshaped, while all protection systems are left intact.
For the record, relative reliability evidence has been anecdotal, found in the public domain and not studied in a controlled environment . We recommend that you do your own research on reliability before making the decision to modify your Panamera.
The outcome
You can make power with the piggyback module. You can make much more power with G.I.A.C. software.
The horsepower advantage
Piggyback module: 568HP/490WHP over the stock 508HP/438WHP
Giving you 60HP/52WHP over stock.
G.I.A.C. Software: 614HP/529WHP over the stock 508HP/438WHP
Giving you 106HP/91WHP over stock, and 46HP/39WHP over the piggyback module.
The torque advantage
Piggyback module: 582TQ/502WTQ over the stock 546TQ/471WTQ
Giving you 36TQ/31WTQ over stock.
G.I.A.C. Software: 604TQ/521WTQ over the stock 546TQ/471WTQ
Giving you 58TQ/50WTQ over stock, and 22TQ/19WTQ over the piggyback module.
Below are the dyno sheets of the G.I.A.C. Software versus the piggyback module
G.I.A.C. Software has produced
Power to the crank
106HP over stock, and 46HP over the piggyback module along with 58TQ over stock, and 22TQ over the piggyback module.
Power to the wheels
91WHP over stock, and 39WHP over the piggyback module along with 50WTQ over stock, and 19WTQ over the piggyback module.
