Results 1 to 40 of 41
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Real skinny on Shell Rotella T6 Synthetic 5-40
    Hey so whats the skinny on this oil. I am reading a lot of stuff online howgood it is, how it its PROVEN to be fine in our VAG Turbos, blah blah.
    Its a high quality oil no doubt.
    Anyone been using it for a long time? Any issues?
    Only $21.99 for 5 qts!
    Jun 23 2010
    Athens, PA
    Someone in the B5 A4 section I think just posted a Blackstone analysis report on the oil. They ran it for 5K miles and the report came back that they could have ran it for longer if they wanted and wear and tear was completely normal.
    Sep 12 2008
    South Central PA
    T6 is the fucking shit.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I run it in all my diesels, ran it in my CBR1000RR, my wife's CBR600RR, the Mazda Protege5, and yes, in the A4 2.0T. I go 5,000k in the gassers and with bypass filters run it for 10,000 in the diesels.
    BTW, where are you picking up 5 quarts for $21.99?
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I search for Rotella, but all i found is diesel oil. Are diesel oil good for our engine?
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    AFAIK it comes in jugs of 4 quarts/1 gallon, but yes, you can usually find it on sale for about $20 at Autozone. I've heard walmart sells it too.
    Anyone else have oil temp issues? My temp usually sits right about 200*F once it's warmed up. I noticed it went all the way up to 225*F at highway speeds.. I also noticed that it takes a lot longer to warm up to 200*F. Weird..
    Quote Originally Posted by Mister W View Post
    http://shop.advanceautoparts.com/web...ku=#fragment-1
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Oil temp issues with the Rotella?
    I hope it doesn't cause issues because I have been using it for the past 20k after reading all the glowing reviews and analysis on Bobistheoilguy... Definately thicker, and therefore I guess it takes longer to warm up. But I don't have an oil temp gauge so I couldn't tell you. All I can say is that with the T6 I only add half a quart between oil changes (5k intervals). I use it in the Crossfire and the Touareg..
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Jul 31 2011
    Correct. It is technically engineered originally for diesel engines but has proven to be not only compatible but also a top oil choice for numerous gas engines. In a motorcycle the oil is not just for the engine, but the transmission as well, where it is subjected to much higher shear forces from the gears, but it still not only holds up to it, but excels at doing it's job even in that environment.
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    About to change my second batch of T6, ran it for 10k kms (~8k miles), no issues, gonna see if I can get a sample into the CAT shop at my work here.
    I think it's on for under 30$ at Canadian walmarts.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Jan 29 2011
    Otterburn Park, QC
    So the T6 should be VW 502 00, 505 00, and 505 01 approved?
    Someone mentioned that it is thicker, any issue running it in cold winter in Canuckistan?
    Oct 29 2005
    10speed
    San Francisco, CA
    Don't think it is but its better than most of them
    - Clint
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    T6 is NOT VAG approved, but bobistheoilguy and blackstone reports show it meets or exceeds all expectations, the TDI guys (and many others) love it.
    This is the first extreme Alberta winter i've had to live through, and it started the few times I had to fire it up at -28*C no prob.
    I did pose this question myself though and received this answer on vortex, so during winter I top off with GC 0w30 to give it some better cold start circulation.
    Quote Originally Posted by BsickPassat
    For product markets... Mobil 1 0w40 isn't a Heavy Duty Diesel Oil focused like the Rotella T6. This is why Rotella T6, as well as Mobil Delvac 1 makes their comparisons against conventional 15w40.
    Not everyone lists the same information, and your standard viscosity measurements are not tested at extreme cold conditions.
    At the extreme -45°C temperatures, one of the concerns is wax crystallization--- you see this issue pop up on diesel fuels (aka gelling). Having a PAO basestock (M1 0w40 or Delvac 1 5w40) versus a group III basestock (T6) minimizes that concern. There are additives that can be used for Group III basestocks that mitigates that issue.
    IMO, you might want to compare "Pour Point" (ASTM D97) Temperature is probably one of the key things to look at. M1 0w40 would probably be a better choice, as the pour point is at -54°C vs. -42° (T6).
    The thread; http://forums.vwvortex.com/showthrea...=shell+rotella
    Jul 19 2011
    Northern Minneapolis, MN
    Quote Originally Posted by papadelogan View Post
    I like your style.
    I run it in my 03 CBR600rr (revs to 15.5k and at 35000+ miles), run it in my 97 Ram Diesel (pushing some HP and almost 300000miles) and love it.
    That being said, I ran it for the first time this last oil change and two days ago I did a change and found a lot of it to be burned up and it was super black. So... I am not running it in my car anymore. I am trying Castrol Syn this time, but did Moble 1 before that and was pretty happy with it.
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    I have been running it for about 30k in my A4 and 15k in my jetta 2.5, Ran it on my Rabbit 2.5L as well. I have yet to see any sort of issue at 5k intervals.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    just wanted to say that i have just had my first oil change with Rotella T6 and compared to what i was using before (Quartz Total 9000) it is much quieter than i've ever heard my engine before and just feels smoother overall. Personal experience so far with T6 is great. I read about the 'gelling' concern, but that is more targeting the diesel fuel and not necessarily the oil.
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    If anyone wants the blackstone anylasis that I had done on my car while running T6 I can post it up. Pretty much Blackstone said I could run my oil changes to 7500 or 10000 if I wanted to with how MY car was running with the oil.
    I only went to 7500. I still change out every 5k.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Yep, I used T6 as my oil choice to fill the engine after my rods went in.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    It has high zinc, so a good choice for post break in, and everything I have read says it is very good stuff for normal all the time use too. :)
    Eric
    Epy
    Aug 05 2011
    CO
    Quote Originally Posted by ericpaulyoung View Post
    Eric
    I can prove it is good for normal use lol. I have 2-3 reports that say so ha ha
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Just bought mine, hopefully changing the oil this weekend
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Established Member Two Rings Sweir1171's Avatar
    Nov 02 2012
    B8 S-line Monza silver, B7 S-line Titanium stage 2+, Ducati M900, Suzuki RMX250
    Cleveland, OH
    Not a big Walmart fan but they sell 5qt Mobil 1 0-40 502/505 spec for $22. Great deal
    Sep 29 2009
    B7 A4 6spd quattro
    New England
    Would this oil have any effects on cam follower life?
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by carguy138 View Post
    I hope it does
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    I'm due for an oil change. I think I will give T6 a shot. I'm sure it will run smooth as butter in the AZ heat. I will report back at 5k and let you know my thoughts.
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
    Established Member Two Rings QuattroCan's Avatar
    Sep 10 2011
    Question, popular oil at $21.99 but would it be the oil of choice if it were priced at say $49.99?
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by QuattroCan View Post
    Its just oil, not gold
    Veteran Member Three Rings mightemouce's Avatar
    Mar 12 2007
    01 S4
    I've used this in all my 2.7ts and friends 1.8ts with great results. One of my good friends sends his oil out almost every other oil change to blackstone and his report always comes back great using T6
    07 - RS4
    05.5 - 2.7t B7 -Sold
    Insta-Ste3v3_0
    Veteran Member Three Rings RAGING_BEAST's Avatar
    Mar 10 2012
    Audi A4 2.0T B7, K8 Suzuki GSX-R600, Yamaha Raptor 660
    NorCal
    Tried T6 my previous and first oil change with this car in Nov and to date have not had one issue with this car. But then again ive only owned it since March/April 2012. Its been 3k since the change so ill be changing it soon.
    Sep 10 2011
    Quote Originally Posted by vvenom800tt View Post
    Some of the other brands range from $40 to even $70 for a jug. I just wonder how much the low price point has an influence, or if it is simply an excellent oil regardless of the price.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Not sure where in Canada you are, but in Ontario here it only goes on sale to $37, I usually buy it at $42 or so.
    Not that cheap, not like what the Americans can get it for. But that isn't why I use it
    2008 A4 S-line 2.0T
    JHM Stage 2
    Dec 04 2011
    Kansas City, KS
    Some brands like Motul and Redline or amsoil run closer to $10 a quart, but for us normal people (stage 2+ and under) who just drive our cars any reputable off the shelf synthetic is fine.
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Have been using it for 2 changes in my a4 and one change in the wife's a3 use it in my mk2 also . This stuff does the job
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Anyone using this stuff as their manual transmission lube? I've been using it in two other 5-speed applications (M5R2 & T5), both transmissions which spec ATF as the fluid of choice. Thinking about using it in my 01A 5-speed (B6 1.8T).
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Dec 04 2011
    Kansas City, KS
    I wouldnt use engine oil in an automatic. Maybe as a last resort in a manual. But gear oil have special properties and friction modifiers
    Oct 02 2012
    Austin TX
    I've been running Rotella T6 for ~25k miles now. No issues, the price is right, and it tends to be readily available.
    Jul 03 2010
    New York
    I only own manual transmission vehicles (save for my Yamaha ATV), so that's my focus here. If you read about why this oil is widely used by the motorcycle community, it is because of the anti-shear properties it has. I guess the thing in question vs. a typical gear oil might be longevity.
    Established Member Two Rings DarkHelmet's Avatar
    Jan 15 2012
    Renton
    FYI, I just picked up two gallons of rotella 5-40 at the autozone in Renton, WA for 5$ a gallon. I got the last two on the shelf. Price mistake? the receipt says the right description and for 1 gallon....
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by DarkHelmet View Post
    There's plain Rotella T, Triple, T3, T5 and T6, sure you got the right one?
    T6 = Full synth
    The others are dino or blends.
    Jan 15 2012
    Renton
    Yes t6.
    Nov 04 2011
    Yep, you want the synthetic T6 only.
    For the record, I use it in my car since I bought it. I did around 50,000kms. I don't burn any oil at all since then.
    I also have read on here a guys you did more than 250,000 miles on is car, 150,000 with the Rotella T6.
    My friend run it in is turbo '86 GTS and other car too, he buy it in barrel .
    I also got a friend who did a doctorate in Combustion engine. Told me to use that in the 2.0T and that is what I am doing.
    Change my follower only once since, last time I checked, it was ok still, just some of the coating was out in the middle. But it isn't magic, that cam follower is still a wear part.
    My car has 130,000kms now, unitronic stage 1.
    The only bad thing about it, I can't ask any garage to use that oil in my car and do a oil change for me. They all tell me it's some tractor oil shit lol.
