Results 1 to 40 of 61
    Mar 13 2011
    2004 bmw325xi, 1998 ford f150
    moscow, PA
    Can I run regular gas in my 2.0t b7
    Hey I love my car but hate the gas milage. Does anyone know if it will hurt ne thing if I put regular gas in my b7 a4.
    Veteran Member Four Rings Ed Gein's Avatar
    Sep 21 2011
    '10 GTI, '08 Scion tC, '01 CBR 600
    Maine
    i wouldnt
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Better gas will give you better gas milage, besides, if you love your car you wouldn't be wanting to fill it with cheap shit
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jun 27 2011
    Exsqueeze me?
    The 2.0t SHOULD get 20+ MPGs city. Close to 30 highway.
    You really think putting regular in and saving <$2 is going to make having the car retard timing and generally run less efficiently than normal acceptable? You'll get marginally worse MPGs with regular than with premium.
    You won't hurt anything, but long term use of crappy gas isn't good for the engine. Search, this topic comes up all the time. If you're going to cut corners don't do it at the gas pump.
    If you had the 4.2 I could understand your MPG woes, but you've got a small, high efficiency, 4-cylinder turbo. If you are upset over the MPGs your car is returning your money is best spent on maintenance...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Seriously what 3 dollars more a tank?
    Yes it will run FINE with 87, cheaper, and less power, but completely fine.
    The money you save at the tank will be negated with crappier MPGs.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    I know people who put shit gas in the 1.8T. Is it worth it though? However, The engine is made for 91 so that is what I would use.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Veteran Member Three Rings cheemn's Avatar
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    Agreed .........I would say use 91 if it is available in your area and not to go to lower octane than that.
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    X3 never go lower than 91 if possible
    New Build, 2010 Tiguan. Details to com
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    I wouldn't think of it as 'shit' gas, but rather gas that simply doesn't match what your engine expects to see. Nonetheless...as advised, don't do it. One other reason...burning the fuel less efficiently will ruin your catalytic converters more quickly. Bottom line...the $0.20/gal you save today just isn't worth it.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Veteran Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Established Member Two Rings ryandoka10's Avatar
    May 11 2009
    00 stage 3 s4
    MY GARAGE
    Probably need an Intake Valve cleaning!
    Established Member Two Rings B7PhiGam's Avatar
    May 06 2009
    1940%20Ford%20Pickup%2C%201965%20Ford%20Pickup%2C%202012%20Chevy%20Silveradro%20LTZ%20Crew%20Cab
    Oregon
    Sell the car and buy a 1995 honda civic. Problem solved.
    2006 Audi A4 Quattro 6MT - Deep Sea Blue
    ST Coilovers / RS4 Sway Bar / Forged DV / Hawk Pads /APR Stage I 91,93,100 Octane / 35% Tint / Custom Calipers
    "So wird Dich meine Liebe auf ewig umschließen"
    Established Member Two Rings QuattroCan's Avatar
    Sep 10 2011
    Quote Originally Posted by B7PhiGam View Post
    X2
    Veteran Member Three Rings funky_snowman's Avatar
    Dec 31 2010
    US
    you will end up paying more to run the car on regular or midgrade (assuming it's less than 91 or so) than you do to run the car on premium. the cost difference between premium and regular is what, 2-4 dollars per tank? let me put it this way, our b6 on premium gets about 20-21 in the city, and 32ish on the highway. however, with midgrade it gets about 16 in the city, and 24 on the highway.
    additionally, the car doesn't know what kind of fuel you are filling it with. all the car knows is whether it sees any knock or not. personally, i wouldn't want to be constantly bouncing up against the knock sensor, nothing good can come of that.
    moral of the story, using a lower octane than what the car calls for will NOT save you money, but rather actually likely cost you more.
    Senior Member Three Rings nan07's Avatar
    Jul 07 2011
    Frisco, Texas
    get a stage 1 tune, you'll get better MPG. not at first mind you
    Jun 27 2011
    Quote Originally Posted by nan07 View Post
    This is actually true. As long as you keep your foot out of it, haha.
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    i just bought a $200 bottle of scotch, but it's really expensive, so i dumped a bunch of water and brown food coloring in it so that it lasts longer.
    Oct 14 2009
    Okinawa Japan
    Go BT, I get 34 Mpg highway
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Established Member Three Rings jmarch1122's Avatar
    Mar 13 2011
    MA, USA
    Quote Originally Posted by DRAKLORE View Post
    If I stay out of boost, I can drive 90 highway miles and get 34mpg, I have done the calculations several times.
    Oct 14 2009
    Okinawa Japan
    The power and benefeits of a GT30!!!!
    -Shane Drake-
    >DRAKLOREs Build<
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    my car got filled with 87 once because here in nj idiots pump your gas. i didnt realize till it was 3/4 full. got noticeably worse mileage and the car just felt off.
    the only way id go any lower on octane is when i install my vast meth kit then i might consider running 91.
    Sep 21 2011
    Maine
    all we have in maine is 91
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    Quote Originally Posted by Ed Gein View Post
    That's all you need!
    We have 87, 89, & 93 around here. I wish we had 91. It would probably be a good 10 cents cheaper. It adds up after time. We're only tuned for 91 anyways.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Jul 19 2011
    Northern Minneapolis, MN
    91 is what they are built and tuned for. If it is cold, you can go lower though.
    Knowing that, I always stay at 93 :-)
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    No less than 91 octane. Drive less or buy a different car. We knew the octane requirements when we purchased. If you think yours is bad, I have a 3.2L. Premium is only 7-10% more than 87 octane.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Established Member Two Rings parki3n's Avatar
    Nov 03 2008
    Norwalk, CT
    My experiences with 87 gas: I have a 2.0 T (B7) and a 1.8 T Jetta. I've tried 87 octane in both at various times. The 1.8 T seems to drive quite happily on 87, but I still put 91 or better in it because I think it's worth the small cost increase. The 2.0 T was very unhappy with 87. The engine seemed to "bog down" during acceleration and idle was very rough. I tried this with Shell and BP gas in Connecticut and I've stopped experimenting. It's just not worth the risk of having an unhappy engine, in my opinion.
    2006 A4 Avant 2.0T Tip | Dolphin Gray | Stock | Sport + Premium Package | Quattro
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    on a basic average, premium to low gas the difference is about 30 cents, for a 16 gallon tank that adds up to a total of $4.80 if you fill up the ENTIRE tank....if you are sweating about swinging $5 every week or so then i would wager a guess that you have bigger problems in your life that need more attention at the moment
    don't be cheap, when you are cheap you end up filling up with sub grade gas, when you end up filling up with sub grade gas you get carbon build up much faster, when you get carbon build up much faster you get upset, when you get upset, you lose your job, when you lose your job you start to prostitute, when you start to prostitute you get stabbed by a crack head.
    don't get stabbed by a crack head.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Established Member Two Rings JeremySWE's Avatar
    Jan 03 2012
    Stockholm
    On the inside of my petrol flap it states that no less than 95 should be used, we don't have less than that here in Sweden anyhow.
    A6 3.2 FSI Avant Quattro 2006, 255bhp
    RS6 18" Summer wheels, RS4 17" winter wheels.
    Grey Volterra leather interior
    Silver
    *SOLD*
    Jul 08 2010
    tucson
    danbury
    european octane ratings differ from US ratings....too lazy to look it up but 95 european rating = 91 US rating....someone smarter then me is going to correct what i just wrote
    [CENTER]Scott
    2011 S4
    Jun 27 2011
    Quote Originally Posted by JeremySWE View Post
    Europe uses RON measurements though. Different than how we measure octane in the US.
    -CP
    2017 Q7 3.0t
    Sep 21 2011
    Maine
    Quote Originally Posted by mr shickadance View Post
    yes.
    Established Member Two Rings JohnnyTooBad's Avatar
    Aug 14 2009
    NoVA
    Seriously? I've considered doing something to get more power out of it but was afraid of the MPGs when doing the normal day2day crap like commuting. On the highway, during the summer, with 91 octane, I've been able to get 36mpg out of it on a pretty regular basis (going 80-85 and following minivans, pickups or larger, and probably closer than I should). How do you get better mpg with a stage 1? It is just that the boost doesn't kick in as soon, so you end up not using the turbo as much in city driving? Is the turbo lage worse?
    (wrong thread, I know, but I've asked before and got zero responses)
    (DEAD) 2006 B7 A4 Avant 2.0T. Blue/Tan, Auto. 100% Stock, except for some window tint
    Replaced with a unicorn.... 2011 A6 Avant 3.0T, also Blue/Tan. Premium Plus, S-Line, Cold Weather Package.
    Sep 21 2011
    Maine
    the engine is running more efficiently
    Jul 08 2010
    tucson
    danbury
    it runs your car a little bit leaner then it comes from the factory, less gas, more mileage
    [CENTER]Scott
    2011 S4
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    LOL. That was hilarious.
    One time the gas guy put in regular, I didn't see till he was taking it out -_- It ran like shit, felt strange as hell. Don't do it. Sell the car if your gonna be cheap and get a honda.
    RIP QG TI B7 A4
    Sep 21 2011
    Maine
    really? less gas but more boost?
    Jul 08 2010
    tucson
    danbury
    the oem fueling on our cars is on the rich side, which essentially makes the car run a bit cooler, and is a little bit less stressful on the engine
    a tune basically leans out the fueling, and brings up the boost, the upping of the boost does not really do anything for gas mileage, but the leaning of the fuel certainly does.
    [CENTER]Scott
    2011 S4
    Jun 27 2011
    ^^ This. When tuners tweak the fuel maps they lean it out some which uses a bit less fuel.
    -CP
    2017 Q7 3.0t
    Jan 03 2012
    Stockholm
    Might have guessed that the Americans measure in a different way to Europe ;-) Cheers for the info.
    Silver
    *SOLD*
    Established Member Two Rings coletrain's Avatar
    Jan 25 2012
    NC
    uhm no...its recommended to run on that gas for a reason.. and the little price difference sure isnt worth the chance
