Results 1 to 11 of 11
    Jan 20 2010
    Texas
    Almost DIY - Rearview Mirror Upgrade
    MY A4 came with the bare-bones, no frills rear view mirror. I wanted a mirror with a compass and the ability to add the rain sensor. Here is what I did to get there... My primary goal was to get the mirror and compass in place. I will add the rain sensor later. This is not for the faint-of-heart. Additionally, you will need lots of patience to complete this project. Its not too hard, but it still took me 6 weeks to source the key parts. Sorry in advance for the long post.
    Tools:
    • Small ratchet with 10mm socket
    • Soldering iron and solder
    • T20 Torx driver
    • wire clippers
    • Painters tape
    • Glass marker (a permanent marker will work and should come off the windshield)
    • X-acto knife
    • Flat razor
    • Fine-point needle (to remove wire pins from a plastic connector)
    • Electrical tape (or friction tape)
    Parts:
    • Replacement Mirror. There are many to choose from. Some have 6 pins some have 8 pins. The 6-pin mirror is for a single -zone AC system with NO climate sensor. My mirror was from an older A6. It was: 4F0857511A.
    • Wiring Track: 4F0857593G. Find something similar. Other models have similar part numbers.
    • Wire Cover: 4F0857593F. Find something similar. Other models have similar part numbers.
    • Audi Wire: 000979009E
    • Plug for new wires: 8E0971833
    • New Mount (no Audi part number... see below). NOT 701845543
    • 10" of wire (cut a piece from one of those extra network cables in your drawer)
    Process
    The most important thing to know about this is that the mounting bracket for the new mirror is not the same as the mount for the basic mirror. Unfortunately, the new mirror mount is NOT a part that can be ordered from Audi. It has no part number. The only way to get this part is used. The best way to do this is call up 2 or 3 local dealers and ask them who they contract their glass-work out to (they often do not do glass themselves). Get the names and phone numbers. Call them up directly and explain that you are looking for the mounting bracket from the compass-mirror. Explain that it looks like a large teardrop or U, not a small quarter-sized circle. If they have ever done any glass-work, they will know what you are talking about. Ask them to take your name and phone number, and call you when a cracked windshield comes in. Check with them every couple weeks. Eventually, they will get one (it took me 6 weeks). Ask them to break it off the glass, but keep it intact. They may tell you that your plans won't work. Just tell them they are probably right, but you want to try. Incidentally, they are wrong, but be nice so you get the part.
    When I got my part, it had little pieces of glass still glued on it. I took it to a trusted glass guy. My glass guy used a box-cutter to scrape the glass off. It turns out that the "glue" Audi uses from the factory is like black caulk. Use a razor and scrape off as much as possible.
    The next major hurdle is to remove the existing mirror. This is where most panic sets in. Warning here: do NOT try this yourself. Be prepared for the risk that this process may crack your windshield. If it does, order the proper glass for the new mirror. The glass guy should use his hand to twist the stem coming from the mirror. This will leave a quarter-sized mount to the window. He will need to take a blow torch to the thing to heat up the glue underneath. While he is doing that, he will need to TWIST (not pull) until it comes off. When it does, that little mount will be hot as hell. While the windshield is still hot, he needs to take a straight-edge razor and scrape off the glue. Clean it, cool it, and move on. Hopefully, your glass is still intact.
    Mounting the new bracket is not too difficult. First of all, do not use any of the cheap mounting glue from the local auto store. All of the glass guys I spoke with said that the store-bought stuff was useless. At least the guy that did my work had that same black-caulk like stuff and used it. I did buy the glue kit that is listed in ETKA and we did not use it. Don't waste your money on it. The next step in this process is to push the plastic wire track into place in the headliner. Run your finger along the headliner in front of the over-head controls. You will feel a small cut-out in the middle. That is where you need to push the wire-track into.
    Now, slide the mount onto the wire-track. Line everything up to the center of the glass, tape it to the glass. Go outside and look at it from the front center of the car and re-align as needed. Repeat until you are happy. Now, use the marker on the outside of the glass to mark where it should line up. When you do all this, keep in mind that the hole in the middle of the new mount will overlay that black dot inside the glass. That hole is for the rain sensor. If you have any desire to eventually put the sensor in, you need to move the bracket upward so the hole is not covered by the dot. There is plenty of space and you only need about .5 cm. Keep in mind, if you do this, you will do a little cutting on the wire cover later.
    When you have found the right place, put the black-caulk glue on the back of the mount, slide it onto the wire track and put it in place. Line it all up, double check, tape it in place and wait 24 hours. No touching, just wait. Do not worry about any glue that has leaked out the side. The wire track may get glued to the windshield as well. Don't worry about that. Once the 24 hours are up, gently wiggle free and move the wire track out of the way. It comes loose very easily. You do not need to take it off completely , just turn it a little to the side. Use the X-acto knife to trim off any excess glue. You can also scrape it off the windshield with a flat-razor.
    Now comes the electrical work... If you are only worried about the compass, you only need to focus on power to the mirror--pins 1 and 2 of the mirror jack. Since that was my goal, and I am not worried about doing a full, Audi-like wiring process, I will describe what I did. You could buy the proper plug and wire the plug, I decided not to go that route. It looks like it would not be to hard to remove the A-pillar cover and run the wire to the fuse box, but for me there was no real need. If you plan to install the rain sensor, you will need to run the wire.
    First, I cut the Audi wire to size. Do NOT cut the wire in half. Cut the wire into about one-third/two-thirds. Solder the 10" wire to the one-third part. When done, both wires should be about the same length. Strip off the ends of the wires.
    Second, take note what color pins 1 and 2 are, and the remove all the pins from the connector on the mirror. My mirror had 6 pins, pin 1 was black (ground) and pin 2 was white (hot). Put one wire onto one pin and tape it together with electrical tape (or possibly friction tape). Repeat with the other wire/pin. Since I only wanted the compass to work, I ignored the other pins...for now. If you plan to use the pin-jack, put the wires into slots 1 and 2. Still make note of the wire color so you can connect it properly. Time to mount the mirror.
    Remove the cover to the over-head lights and sunroof. This is very easy--open the glasses compartment, remove the one torx screw, and pull the cover downward gently. It will hang there with two wires holding it up.
    With the wire track still out of place, gently twist the new mirror onto the new bracket. Once in place, put the mirror track in place. Line the wires upward into the track, and fish the two new long lines into the over-head lighting area. The easiest way to tap the power line it so slide it into the same space as pin 1 on the Homelink buttons. This works out well because those buttons only have power when the car is on. Tape the wire to the bundles to keep it from moving or coming out. Find one of the screws in the roof that is tucked under the edges of the hole (sorry, no picture). Tap the ground wire to one of those. Done. When you power the car on, the mirror compass should light up. If not, check your wire connections. DON'T reattach the over-head light buttons just yet...
    Its time to put the wire cover on. A couple tricks and hints here... First, if you did move the mount upward so you could install the rain sensor, you will need to cut the tip of the cover off. Use a box-cutter and take your time. When you put it in place, it is easiest to tilt the mirror down and go straight over it and snap it in place. I would also recommend putting the cover on BEFORE you re-attach the over-head light buttons. It will go on easier and will not scratch the front plastic lip on the button frame. Once the cover is cut down to the right size, put it in place, make sure all the wires are hidden. If it looks good, NOW, reattach the over-head light buttons. You are done.
    TODAY, this is where I am at. I have other plans... From the outside, the mounting does not look bad, but not great either. I am currently investigating putting a piece of vinyl over it. You know that stuff you see on car windows that looks like an advertisement from the outside, but tint from the inside. I am investigating putting a piece of that on the outside of the glass. Below is a template I am working with for the shape of the vinyl piece. I still need to re-size it, and confirm it is a good shape. My only concern will be the impact to the wipers once it is in place. I will let you know as I learn more.
    Hope this was helpful.
    UPDATE: Don't use vinyl. I ended up taking a permanent marker and outlining the black plastic track on the window ON THE OUTSIDE of the car. I took the track off the window and then painted the inside with Testers brand model paint bought at a local hobby store. I tried 4 different shades of black and they were all the same. The marker on the outside gave me a template on how much to paint. I let the paint dry and did a second coat. I also got underneath the mount with the paintbrush. Once it dried, I reinstalled the track. I then used a straight-edge razor and scraped off the excess paint. Put it all together and it looks outstanding. You cannot even tell I did anything. Oh, a little glass cleaner will take that permanent marker right off, too.
    Installed: Grocery Hooks, BLESK Plate bulbs, iPhone Extension, VAG-Com, Luminics JDM Yellow Fogs, Chrome Grille Inserts, Rear 12v power, Underseat Storage, Folding Side Mirrors, B&O Tweeters, E-Codes with BLESK 5000K, Audi Hill Hold, S-Line Rear Bumper, Warning Triangle, DIS Stalk, Full-Function Rear Power Locks, ADS, Mirror with Compass, Q5 Wheels
    Veteran Member Four Rings jbradle7's Avatar
    Jan 09 2010
    GX460; MK7.5 GTI; WK2 Grand Cherokee; 73 Triumph TR5T
    St. Louis
    Great write-up, wow! I'm just gonna live w/ my no-frills basic mirror, but do appreciate all that effort.
    Apr 16 2012
    2009 Audi A4 Quattro, 2010 Evo X MR-Touring, 2012 Nissan GT-R
    Hollywood, CA, USA
    cool. but the bare bone looking of the bracket from the outside doesnt look good. you could cut out a block plate and only leave the rain sensor expose.
    Jan 20 2010
    Texas
    Quote Originally Posted by charlievoviii View Post
    Agreed. This is why I am looking into the vinyl solution and posted my template. I hope to have that figured out soon. If it matters, that last picture makes it look a lot worse than it is. Unless you are looking for it, it is not very noticeable right now.
    Apr 16 2012
    Hollywood, CA, USA
    Quote Originally Posted by TexasEric View Post
    Long as you're happy, thats all it matters. I will do this also eventually. People where I live have bright ass HID. Sometime it annoys my wife lol
    Veteran Member Three Rings haroulli's Avatar
    Mar 06 2007
    Audi A6 C7 - BMW X5 F15
    East Coast
    Eric FYI I have my mirror working as far as dimming. It doesn't have a compass since its the headlight assist version. I will be getting a new windshield one I have the rain/light sensor figured out.
    Moonlight Blue 2018 C7.5 A6 2.0T S-Line Black Optics
    DEAD - Quartz Grey 2010 B8 A4 2.0T
    Jan 20 2010
    Texas
    Minor update... The vinyl idea will not work as the windshield wipers will tear it off. I am going to "undo" a little bit and use some black paint on the inside, underneath the mirror mount to make it look better. It will not be perfect, but it will be less noticeable.
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Is the self dim mirror w/ the rain sensor a different mirror (I am assuming)? The reason I did not go this route was for the very reason our P- cars don't have the built in tinting to hide the mirror base for the rain sensor mirror on our windscreens.
    Your idea with the black vinyl (or limo tint) is great however, you need to apply it to the inside of the windshield. Then only the round bracket and rain sensor will show.
    Still also not clear. Is the rain sensor built into your mirror where once you connect it to power and ground the rain sensor automatically works? I must have missed something. Somehow it must have to be wired to the windshield wipers??
    Jan 20 2010
    Texas
    Quote Originally Posted by B G 8er View Post
    From the looks of it, the mirrors may be different, but the mounts are the same.
    The vinyl on the inside could be hard just because the "glue" holding the new mount is in the way. If you put it on first, the mirror mount may not
    The rain sensor is not built into the mirror. It goes inside the hole in the mount. The wire connects to the same wire that provides power to the mirror itself. If you properly wire the mirror (and not just tap power like I did), you need to run two wires down toward a module by the drivers legs.
    May 19 2013
    Utrecht, the Netherlands
    Great write-up and very inspiring. After reading your article I scraped all the required parts together. But I just can't figure out where to get that glue for the mounting bracket. The "black-caulk like stuff"... All the glass-guys over here cant' help or they don't believe that their glues will hold... Do you by any chance know what kind of glue it is? Maybe the brand name? Much appreciated!
    Jan 20 2010
    Texas
    Quote Originally Posted by Edster View Post
    No clue. My glass guy made it seem like it was "normal" glass glue--nothing special. I also did have that same "its not going to work" comment from other glass guys in town.
    Minor update, too... I ended up taking the mirror and cover off and painting the inside of the glass with Testers brand model paint. I let it dry, put it all back together and used a flat-razor to scrape of the excess on the glass. It came out great and looks outstanding from the outside... except... I dripped some paint on the back of the mirror itself. I tried a VERY little paint thinner on a cotton ball and it took off the paint--no discoloring! Then, I realized I missed a spot and did it again. The second time, I used a much more liberal amount of thinner. BAD IDEA. I now have a very discolored mirror. Lesson learned... I will now hunt for a new mirror... But at least the outside looks great!
