Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 361 to 400 of 591
  1. #361
    Feb 26 2009
    00' S4 Stage 3, 2012 S5, 06 E55, 2016 Monster 1200R
    East Bay, CA
    Having trouble deciding between H&R OE and the Sport springs for a 2012 S5 4.2L.
    I have the OEM 19" peelers on 20mm/25mm spacers, will the sport spring cause rubbing?
    Are people still able to get over most speed bumps with the Sport springs, or are the OEs the definite way to go with spacers this large?
    All opinions welcome, thanks.
  2. #362
    Veteran Member Four Rings mozman68's Avatar
    Nov 09 2014
    2019 VW Atlas SEL R-Line
    South Carolina
    Quote Originally Posted by GKTS4 View Post
    I went with the coil overs...and am on 20's and have them lowered really tight. Speed bumps aren't an issue and rubs only when going to fast and hit a dip in the road.
    I run the stock 19's in the winter and don't even raise the car.
    2009 S5 in Bottle Green / 20x10.5 BBS CH-R in satin black (check with Mops) / AWE Tuning Track Exhaust (Mops again!) / H&R Street Coilovers (Mops...again) / Ecodes (ECS Tuning) / Rear LED retrofit (Europrice) / RS5 blackout grill (MrCarCar)
    MozMan's Build Thread
  3. #363
    Feb 26 2009
    East Bay, CA
    Quote Originally Posted by mozman68 View Post
    Thanks for your input. So you're probably lowered more than the 1.2-1.3" average the sport springs provide?
    Anyone able to share experience specifically with spacers as wide as I'm running on the sport springs?
  4. #364
    Nov 09 2014
    South Carolina
    ....and I'm running that wide as well.
  5. #365
    Feb 26 2009
    East Bay, CA
    Oh, that wasn't specified in your original response. Thank you for clarifying.
  6. #366
    Nov 09 2014
    South Carolina
    Yeah...sorry...my summer wheels have back spacing to match those dimensions and I run those spacers with the stock wheels in the winter.
    Plenty of pics in my thread...I think...
  7. #367
    Feb 26 2009
    East Bay, CA
    I'll look your thread up, thank you sir.
  8. #368
    Established Member Two Rings thrill23's Avatar
    Apr 30 2016
    OEM Parts
    Miami, FL
    Is there a aftermarket suspension that works with Audi drive select? Budget is $2000, maybe a little more.
  9. #369
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Post Deleted
  10. #370
    Apr 05 2016
    Brentwood, TN
    2014 Audi A5 with H&R Coilvers, 20" BO+ wheels with 265/30r20 rubber, and AWE dual outlet exhaust.
  11. #371
    Established Member Two Rings Linksman72's Avatar
    Jun 23 2015
    Orland Park IL
    I want to lower my 2010 A5 2.0, with 55,000 miles on it. What is the best option for springs or coilovers for my car? I am on a slight budget. Also anyone know any Chicago guys that can help me do a DIY with the suspension?
    2010 Audi A5 Prestige 2.0t, Brilliant Black, APR Ko4, AWE Touring catback exhaust, AWE downpipe, 034 HFC, Kohlefaser Luft-Technik Intake System, Wagner competition intercooler, RS5 Grille, H&R Coilovers, Vorstiener vff 104 20x10, interior LED upgrade, 034 drivetrain mount inserts, Basslink subwoofer, VAG-COM mods
  12. #372
    Junior Member Two Rings
    Mar 27 2016
    Ayrshire. Scotland
    Hi Folks, looking for some advice if possible.
    Fitted Bilstein b16 PSS10's to my Fl A5, dampers set at 6 all round, ( Scottish roads are terrible )my issue is: when the car has a full tank of fuel or luggage in the boot, the steering feels quite wooly and the car seems less planted to the road.
    Anyone know how to cure this, I'm usually in the car myself or with one passenger, doesn't really make a difference though. Once the weight on the rear has gone the car returns to feeling fine.
    Should I adjust the front or rear to make it a bit stiffer/softer?
    JG
  13. #373
    Feb 27 2014
    Dubai
    Post Deleted
  14. #374
    Mar 27 2016
    Ayrshire. Scotland
    Quote Originally Posted by JamesRS5 View Post
    Yes, you'll need to increase the damping with a fully loaded car. The Spring is under more preload with it being compressed so a little extra damping rate will help control the spring and bring back a better feeling car.
    Thanks James, I'll set rear to 7 and see how that works out.
    JG
  15. #375
    Jun 29 2016
    Is anyone one using the H&R OE springs along with Koni yellow adjustables? Would like to know what the ride quality is like. Will be goin on a 2011 S5 for the record.
  16. #376
    Established Member Two Rings Marc Idon NoYu's Avatar
    May 19 2016
    United Kingdom
    FK AK coilovers - cheap temporary ones for now
    about 60-70mm down but 30-40mm still left to go down
    sitting on 20x10.5 ET30
  17. #377
    Aug 28 2015
    Illinois
    GMG Springs + 10mm spacers = No rubbing, no bottoming, great stance, and feels more planted on the road
    Prism Silver RS5
  18. #378
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    2014 S5 with OEM 9*20 ET29 on 265/30 R20 and Bilstein B16 PSS10 Coilovers:
  19. #379
    Senior Member Two Rings pw-sherman's Avatar
    Aug 04 2013
    '20 Ram 1500, '18 Wrangler JK, '18 Impreza
    UT
    OEM Y-Spokes (19x8.5 ET 32) with 20mm & 25mm spacers on H&R Coilovers.
    B8.5 Audi RS 5
    2015, Daytona Gray Pearl Effect, Black Nappa Interior
  20. #380
    Aug 28 2015
    Illinois
    Better pic: GMG Springs + 10mm spacers
    Prism Silver RS5
  21. #381
    May 18 2016
    Orlando
    thanks to Mops for all his help. my car wouldnt be he car that it is without his assistance
  22. #382
    Aug 09 2016
    San Antonio, TX
    What wheels are those?
  23. #383
    Aug 09 2016
    San Antonio, TX
    Anyone else get scraping on their front plastic flaps right by your front tires?
    I notice I've scrapped a few time when taking sharp turns.
    Guess I might have to go higher.
    -cW
    Anyone know what wheels these are..
  24. #384
    Jul 23 2016
    2006 Lincoln Navigator
    Tacoma, WA
    Quote Originally Posted by Marc Idon NoYu View Post
    Do you rub at all?
  25. #385
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by Sportunage View Post
    https://n4sm.com/mrr-design-gf9-hyper-silver-machined
    19x10 et25. Had room for another 5mm. Was running 275 tires.
    -cW
    Sent from my SM-G935V using Tapatalk
    2023 X3 M40i Alpine White
  26. #386
    Jun 23 2015
    Orland Park IL
    H&R street coilovers with 15 and 20 mm spacers. Current ftg height is 26.25 inches. I may lower it another 1/2 inch at most
  27. #387
    Veteran Member Three Rings Munster_Paul's Avatar
    Aug 14 2015
    Awaiting delivery R-Dynamic RR Velar
    Medfield, MA
    Quote Originally Posted by PedroRS5 View Post
    I like your set up dude- any positives and negatives you could share- what year is your 5?
    2021 C8 RS6 Avant - Daytona Grey Prism-
    2013 IRS5 Gone but not forgotton
    [/COLOR]
  28. #388
    Senior Member Three Rings BuffDavid's Avatar
    Aug 15 2016
    2015 Jeep Grand Cherokee Limited 2012 Hyundai Genesis Sedan 5.0
    Jacksonville, Florida
    Quote Originally Posted by pw-sherman View Post
    Beautiful Car, but I'm more in love with that HOUSE! Glorious!
  29. #389
    Established Member Two Rings jmcdermott's Avatar
    Jul 21 2014
    Canal Winchester, Ohio
    Just purchased a 2010 S5 w/Audi Drive Select. Looking to install H&R OE springs with DRA spacers. I have installed coilovers on my B6 S4 but the DRC system is new to me. Do I need to depressurize system or does a shop need to perform this install? Any info would be appreciated. thank you
  30. #390
    Feb 27 2014
    Dubai
    Post Deleted
  31. #391
    Aug 28 2015
    Illinois
    Quote Originally Posted by Munster_Paul View Post
    PM sent
    Prism Silver RS5
  32. #392
    Aug 09 2016
    San Antonio, TX
    Is anyone running koni shocks/struts with H&R sport springs? Looking for some feedback on ride quality. I recently bought sport springs from a board member and have been reading some post about people having buyers remorse after installing these with stock shocks. I prefer a set it and forget it set up of shocks and springs as I won't be adjusting the height or dampening once installed. Looking for a tight sporty ride and was wondering if the combination of the sport springs and koni's will provide that.
  33. #393
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Quote Originally Posted by BlkS5 View Post
    Before
    Phase 1 - HR OE Spings over ADS 1.25"
    and this is why you need spacers
    Phase 2 - Megan Racing Adjustable Coil Overs no ADS 1.5"
    Phase 3 - KW Adustable Coils over ADS 1.25" (went back up a litlle)
    By far the best ride!
    reviving a post from 4 years ago lol, how were the megan racing coils?? they look amazing but i hear build quality is shit.
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
  34. #394
    Established Member Two Rings sandjunky's Avatar
    Sep 12 2016
    Push mower and RC cars
    Lincoln/ca
    Can anybody make recommendations on how many turns i should make for b16 coilovers? Looking for 1.3 to 1.5 of drop.
  35. #395
    Senior Member Two Rings Tomieg's Avatar
    Aug 20 2016
    Thumbs up
    Lowered on Stasis Ohlins SL 26" FTG + 20/25mm H&R spacers.
  36. #396
    Sep 28 2010
    NW NC / DE
    Perfect!! @Tomieg
  37. #397
    Sep 11 2014
    Australia
    BC Racing Coilovers with 10/15 spacers
  38. #398
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    Quote Originally Posted by dejangcool View Post
    How wide are your wheels and ET?
    Instagram: donomoko
    - 2014 S5 3.0T Prestige - : Plain ole S5 w/ a few cosmetic mods...
  39. #399
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Winter setup:
    Bilstein PSS10
    OEM S4 Double 7-spokes
    19x8.5 ET 43
    H&R Spacers 15mm Front/20mm Rear
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
  40. #400
    Nov 19 2016
    dmv
    hi all i just recently upgraded my stock springs with h&r sport and my question is if i need to replace the shocks/struts too? i have 35k miles
