Page 47 of 66 FirstFirst ... 37454647484957 ... LastLast
Results 1,841 to 1,880 of 2601
  1. #1841
    Jul 04 2017
    Whittier, Ca
    Quote Originally Posted by dux ducis View Post
    what does a ceramic coating do? make it easier to clean? and would i want it on a polished lip?
    where do i get it done at?
    Yes to all! I'm a detailer/ppf installer. I ceramic coat wheels daily and the easy with which they clean up is amazing. Usually only soap and a pressure washer are needed. I don't use wheel cleaners or acid once the wheels have been coated. Depending on where you live I can refer you.
    Sent from my SM-N910T using Audizine mobile app
  2. #1842
    Established Member Two Rings CG3D's Avatar
    Feb 28 2011
    Kenosha, WI
    Gotcha. I did the same on mine regarding the trims. They'll not look small in black at all. Larger if anything, as the tire/wheel contrast is not hard like silver/black tire. With ceramic, you're good. But I still prefer satin black. Wheel and car body contrast nicely. Here is my old A5 with satin black and glossy silver...
    IMG_2775 by Audiyos, on Flickr
    IMG_2691 by Audiyos, on Flickr
    These pictures should be legally required viewing when anyone purchases an A5/S5...
    2009 Audi S5 | Meteor Gray | Magma Red | H&R Sport | BBS CH-R 20x10.5 | AWE Track | Drive Select | Side Assist
    Past: E55 AMG, 1970 Nova
    IG: @CG_3D
  3. #1843
    Jul 04 2017
    Whittier, Ca
    How much drop is on the car mops?
  4. #1844
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by CCS View Post
    IMG_2089 by Audiyos, on
    IMG_2090 by Audiyos, on Flickr
  5. #1845
    Jul 04 2017
    Whittier, Ca
    OK better yet, what did you use to achieve that drop?
  6. #1846
    Jul 05 2015
    West TX
    I'm in El Paso, TX...formerly Fayetteville, NC.
    How much does this process usually cost?
  7. #1847
    Aug 16 2017
    Killeen, Tx
    What's the best offset on a 20x10 to sit flush? The wheels I am looking at comes in 33. Or if I go to 20x11 I can get it with a 35 offset.
  8. #1848
    Established Member Two Rings Marc Idon NoYu's Avatar
    May 19 2016
    United Kingdom
    Judd T204
    20x10.5 275/30 ET15
  9. #1849
    Veteran Member Four Rings gqambitions's Avatar
    May 27 2015
    Atlanta,GA
    Quote Originally Posted by Terrance38 View Post
    I am running 20x11 with 35 offset. I am pretty flush. Have plenty of pictures on my IG @gqambitions or on the pics of your car now thread as well. Hope this helps.
    APR Sponsored
    Current- 2021 S6 Premium Plus on Arras red/ My build thread --> https://www.audizine.com/forum/showt...(Build-thread)
    Past-
    2018 B9 A4 (s line) Mythos Black metallic
    2008 VW Passat Wagon- Stage 1 Giac
    2010 B8 s5
    IG/TikTok/Youtube:@ikelifestyles
  10. #1850
    Jan 06 2008
    Dacia Sandero
    Arizona
    Don't think I've posted the new setup here, so here goes:
    BBS CH-R, custom Gold powder; 20x10.5, et25
    [/url]image1-26 by Audiyos, on Flickr
    IMG_7612-2 by Audiyos, on Flickr
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
  11. #1851
    Mar 11 2017
    Oregon
    Hey guys I'm Getting Ag M510 20x10 et 25 in satin black soon and It seems like 275/30/20 tires is the way to go after reading through a lot of these posts and looking at the pictures. I'm deciding between Continental dws06 Or the Michelin pilot as3 plus. the dws06 comes in 275/30/20 but I think I prefer the Michelins. If I'm not mistaken the michelins don't come in that size. They do come in 275/35ZR20 though. I'm a noob with tires so whats the difference between the 275/30/20 and 275/35ZR20. I live in Oregon so I need the Ultra high performance all seasons. Which would you guys go with?? I'm also gonna get HR street coilovers and lower it a little bit.
  12. #1852
    Established Member Two Rings Twotonicnite's Avatar
    Mar 21 2016
    NW Indiana
    Quote Originally Posted by 4RingRook View Post
    Wow, that looks incredible. Beautiful car and setup 4RingRook!
    Twotonicnite
    *2015 S5 Prestige, black optic, manual, GIAC Stage II Tune, Vorsteiner V-FF 104s, Bilstein B16 w/ IRC Ride Control coilovers, Milltek exhaust, 034 rear swaybar, endlinks, differential, & transmission mounts, ECS carbon intake
    *2016 Q5 Premium Plus 3.0T, S-Line, Exclusive Derby Green Pearl
    *2019 A6 Prestige, Mythos Black, Night Vision
    *2008 Toyota Tundra SR5, bone stock
  13. #1853
    Jan 06 2008
    Dacia Sandero
    Arizona
    Quote Originally Posted by Twotonicnite View Post
    Thank you
  14. #1854
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    Quote Originally Posted by CascadeReigns View Post
    my preference is the A/S 3+ or Pirelli P Zero All Season Plus Ultra for wet/snow conditions, while also providing great dry performance.
    go to tirerack & look at the spider chart test comparisons for the tire.
    do not go with the 35% sidewall aspect ratio, too large a dia, it will mess up the ABS, speedo, etc.
    jmho ymmv
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
  15. #1855
    Mar 11 2017
    Oregon
    Quote Originally Posted by wkhanna View Post
    jmho ymmv
    i want the Michelin A/S 3+ but it doesn't come in 275/30/20. They do come in 285/30/20 though. whats your opinion on that?
  16. #1856
    May 12 2017
    depends on your wheel rim width......
    Billy
    Avatar Chart
  17. #1857
    Mar 11 2017
    Oregon
    ill be getting ag m510 20x10 et25
  18. #1858
    May 12 2017
    sorry, you already mentioned the wheel size...i missed that.....
    afa fitment, i am not sure about the et25
    let us call in the expert ; ) @mpos
    Billy
    Avatar Chart
  19. #1859
    Sep 28 2010
    NW NC / DE
    285/30 works just fine on 20x10
    BuffDavid runs that spec
    Mops on the move
  20. #1860
    Mar 11 2017
    Oregon
    Mops on the move
    thanks for the help mops and wkhanna. I'm gonna go Satin Black AG M510 20x10 et25 With Michelin Pilot A/S 3+ 285/30/20
  21. #1861
    May 12 2017
    nize...
    but only valid w/ pics......
    anxious to see.....
    Billy
    Avatar Chart
  22. #1862
    Mar 11 2017
    Oregon
    Lol I will definitely post when I get them on. I just got this car a month and a half ago. So far only have an AWE track exhaust and the ECS carbon fiber intake(sounds amazing). I got a front lip and rear diffuser sitting in my garage that will get installed after the wheels and coilovers.
    B8.5 Misano Red Pearl S5
  23. #1863
    May 27 2015
    Atlanta,GA
    Varrstoen Es1 20x11 on Michelin 4S tires
    APR Sponsored
    Past-
    2010 B8 s5
  24. #1864
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    For reference:
    Satin CH-R 10.5x20J 285/30-20
    Chrome curb guards removed
    ET 20 rear
    ET 12.5 front
    KW H.A.S. Full drop in front and 90% drop in rear. No rubbing. No hardware removed.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
  25. #1865
    Established Member Two Rings vw754's Avatar
    Jan 18 2008
    stoke on trent
    hi guys...........i really need some advice.........i have A5 CONVERTIBLE S-LINE 2.0 TDI 20MM lower than standard with it having sports suspension.
    i want a perfect drop level ALL round............what mm h&r springs should i get........am i right in saying...if i get 35mm springs i will drop it 15mm as its already 20mm from standard?
    any advice info appreciated.
    running on 19 inch wheels.
  26. #1866
    Jul 04 2017
    Redding CA
    Vossen
  27. #1867
    Established Member Two Rings Linksman72's Avatar
    Jun 23 2015
    Orland Park IL
    These getting put on today
    2010 Audi A5 Prestige 2.0t, Brilliant Black, APR Ko4, AWE Touring catback exhaust, AWE downpipe, 034 HFC, Kohlefaser Luft-Technik Intake System, Wagner competition intercooler, RS5 Grille, H&R Coilovers, Vorstiener vff 104 20x10, interior LED upgrade, 034 drivetrain mount inserts, Basslink subwoofer, VAG-COM mods
  28. #1868
    Jun 23 2015
    Orland Park IL
    *** Official B8 A5/S5/RS5 Aftermarket Wheel Gallery ***
    Quote Originally Posted by Linksman72 View Post
    20x10, 275 30 20 tires, no spacers
  29. #1869
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    Are those Vorsteiner VFF-104's? I want them for my S5! I see you're sitting pretty low, with that size do you rub at all? Also, did you notice any difference in acceleration or deceleration/braking? Perhaps handling?
  30. #1870
    Sep 28 2010
    NW NC / DE
    They look fantastic Martin!
    Quote Originally Posted by Sazexa View Post
    Yep! I have a killer deal on an identical set.
  31. #1871
    Jun 23 2015
    Orland Park IL
    I wasn't sure what to expect. Completely changes the look of the car and gives it sex appeal. I get no rubbing. Can't really say I feel a difference in performance but they are lighter than my 19s. I think I can add some 5mm spacers to finish them off
  32. #1872
    Dec 10 2006
    Midwest
    Satin BBS CH-R with ring removed. ET 25 with 285/30-20" on 10.5x20. 5mm rear spacer and 12.5mm front.
    Wings
    Carbs
    Titaniums
  33. #1873
    Veteran Member Four Rings greenturbo's Avatar
    Apr 20 2007
    S5, A6, Q7, SQ5
    Boston, MA
    Quote Originally Posted by s vier View Post
    Love your car
    Sent from Note5
  34. #1874
    Active Member One Ring Mistah_A5_'s Avatar
    Jul 01 2016
    Wisconsin
    Old setup, 20x8.5 TSW Donington (matte black) et35, 15mm spacers in the front 20mm spacers in the back
    Delinte 275/30's all around
    Sent from my XT1650 using Audizine mobile app
  35. #1875
    Jul 01 2016
    Wisconsin
    New setup, 20x10.5 all around XO Luxury Athens (gloss black) et30, same tires as old setup Delinte 275/30
  36. #1876
    Veteran Member Four Rings Cloudg8's Avatar
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Quote Originally Posted by lsondubz View Post
    Looks great whats your setup
    Wheels/tires/ offset / Suspension
  37. #1877
    Jul 04 2017
    Redding CA
    Ag m632
  38. #1878
    Oct 05 2017
    Poland
    20x10 et33
    265/30 michelin 4s
    What spacer I need to fit well over the wheel?
  39. #1879
    Established Member Two Rings jagata's Avatar
    Apr 14 2014
    So. Cal
    20x11 et28
    295/25/20 all around
    Rohana rc7
    Sent from my SM-N920T using Audizine mobile app
  40. #1880
    Jul 15 2017
    Colorado
    Do you have any rubbing issues with that wide of a tire and being that low?
