Results 1 to 38 of 38
    Established Member Two Rings brianB7's Avatar
    Apr 24 2011
    Pennsylvania
    Gas pedal not working VW (no one in general talk has answered)
    I know this is supposed to go in general car talk and i tried but nobody seems to respond there so please help here
    My buddy owns a 2001 vw jetta and recently called me to help him out.
    He was driving down the road when his gas pedal stopped working. I went down to check it out and saw that his 02 sensor harness wires had drug on the ground and snapped. He had it towed and the shop replaced the 02 harness but the gas pedal still isn't working and this shop can't figure out why. Any ideas on what else I can tell these expert mechanics to check...TIA
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    perhaps other electronics got ripped out as well as the 02 sensor?
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Can you get a list of faults? Might help a little. Is it a 1.8t?
    New Build, 2010 Tiguan. Details to com
    May 21 2007
    Florida
    i believe these cars have a throttle position sensor which sounds like it could have failed. i believe you have to get the whole pedal to replace the sensor. fyi, the 02 sensor wiring has nothing to do with this issue as it is just there for emissions purposes.
    2018 Navarro Blue Q5
    Sep 06 2011
    Harrisburg, Pa
    There are 4 sensors, 2 in the throttle body and 2 in the pedal.
    OP where in PA are you? I may be able to offer you some assistance in person
    Apr 24 2011
    Pennsylvania
    thanks guys, its a 2.0 but the shop didn't give him the codes they got he said he'll call tomorrow I told him to let them know about the throttle position sensor it sounds like the shop he took it to doesn't really know much about german cars so i appreciate the feedback
    May 21 2007
    Florida
    Quote Originally Posted by bman005 View Post
    stand corrected. i would still suspect one of these sensors however.
    Sep 06 2011
    Harrisburg, Pa
    There is a "chance" that it only needs throttle adaptation then
    Apr 24 2011
    Pennsylvania
    I am in Philly , my buddy lives in scranton
    Veteran Member Three Rings rarak69's Avatar
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    The ecu is fried, get a new one.
    The internal circuits on the ECU are tied together (throttle drive and rear O2 sensor) The rear O2 sensor shorted thus frying the throttle drive circuit.
    Jun 27 2011
    ^^^^ Not sure if serious? Get a new ECU??? That sounds a bit drastic for what is most likely a failed Throttle Position sensor... Easy to test for in VCDS by the way...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    Dead serious mate.
    I have been tuning these ecu's for 7 years almost, and i have seen this many times, if you dragged the O2 harness, or it was split and you get a non functioning throttle, this is always what happened in my situation.
    easy test with VCDS like said, watch the throttle position sensors and watch them not do anything :)
    BTW, ecu uses only one of those sensors(the 0 - 100%) for normal use, the other is a 100-0% percent sensor, its used as the backup, and for plausibility checks of the DBW system.
    Sep 06 2011
    Harrisburg, Pa
    Unplug the MAF and see if throttle comes back. If not then I'd have to say that rarak69 is absolutely correct. I've run into O2 issues in the past that have in turn crapped out the MAF to the point where it bogs down and stalls out the car once you try to give it any throttle. That being said, none of those cars had the O2 harness rubbed through. And I have to agree that if the O2 wires touch together that it would most likely cause an ECM failure
    Established Member Two Rings NODO-GT's Avatar
    Jul 30 2010
    Audi A4 B7 2.0T Quattro 6MT
    Tbilisi
    I had the same problem with my previous car passat b5.5, It left it at night outside in the rain and the ECU got wet, and gas pedal was not working.
    I took it to VW dealer and they cleaned & dried ECU and everything started to work :)
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    OP please make sure that you post solution for others to find! biggest mistake i see on forums, people ask help, 800 idea's are popped up, they get car working but never report solution! Help many others down the line please!
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Quote Originally Posted by brianB7 View Post
    Roflmao, my friend(s) are in philly/scranton U.
    Sorry bout your buddies car, good luck!
    RIP QG TI B7 A4
    Apr 24 2011
    Pennsylvania
    Thanks for all the responses guys, Ive let him know what to tell the shop and once they figure out what the problem is ill post it here...sucks that he might have to get a new ECU ...I told him to just buy an Audi
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    ecu should be pretty cheap for that car, 75-100 then take the immobilizer off or match it over, 2001 probably immo2 so easier to swap in.
    Sep 06 2011
    Harrisburg, Pa
    Too bad it isn't a 1.8t, I have a couple layin around
    Jun 27 2011
    Quote Originally Posted by rarak69 View Post
    Dead serious mate.
    Damn! I stand corrected then. Is that an issue isolated to VW models or could it potentially affect our Audis as well?
    -CP
    2017 Q7 3.0t
    Apr 25 2013
    Rochester, NY
    I think I've got this exact same problem with a 2003 VW GTI, 1.8L turbo.
    The throttle is dead with corresponding error codes after O2 sensors were replaced.
    Anyone have additional details on the ECU damage ? I'm wondering if it might be possible to repair by replacing a component or something on the board. The ECU otherwise seems to be good since the engine runs and there are no other error codes.
    It seems really strange that shorting the O2 sensors would damage the throttle circuit and leave everything else working.
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    check all fuses 1st. you just shorted a bunch of wires together... and of course scan the ecm. if it even communicates (IE power to it)
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    Wondering if this might be the issue with my car. I was driving along Friday night when all of a sudden I get a flashing CEL and the gas pedal stopped working, so I pulled over thinking I'd check the fault code with my APR Mobile but it won't pick it up. Car starts, idles, and runs just fine but when I push the gas pedal the tack blips but the engine has no response. At first I thought it is probably just a bad throttle position sensor or bad throttle body but I talked to a buddy of mine who owns a VW/Audi performance shop and he thinks it may be a fried ECU as he said he's had 3 or 4 B7's come in recently with fried ECU's.
    I'll be getting the car vag-com'd in a couple hours here so hopefully that points me in the right direction.
    DTM_B7_S4
    Previous car: APR_Stage_II+_B7_A4
    Established Member Two Rings lesurfman's Avatar
    Mar 03 2010
    montréal, Canada
    Do you have APR anti-theft?
    If so read this thread
    http://www.audizine.com/forum/showth...ar-Please-help!
    SPRINT BLUE 2007 A4 2.0T MT6 Quattro S-Line Titanium
    APR Stage II Tune (Stock, 91, 93, and valet modes) - APR Carbonio CAI - APR Snub Mount - 034 Motorsports Motor Mounts - 034 Motorsports Turbo Inlet Hose - RAI 3" HFC - OEM "D rev" DV - RS4 Rear Sway Bar - RS4 Pedals - New South Performance Vent Boost Gauge.
    Nov 08 2010
    Quote Originally Posted by lesurfman View Post
    I don't have anti-theft. Just security lock out as far as I know. These symptoms are eerily similar to mine though. I'll try entering my security code (since it is locked out currently to prevent changing tunes accidentally) and changing tunes and then locking it out again tonight.
    Otherwise I've heard it's possible I have a bad relay. I had the car vag-com'd last night with no fault codes found.
    DTM_B7_S4
    Nov 08 2010
    So as it turns out APR Anti-theft somehow enabled itself while I was driving. I have no idea how, because emcs was locked out and the APR mobile dongle wasn't even plugged into the obd2 port. It didn't help that I didn't know I had anti- theft because before APR mobile I never had it but now I have it via the APR mobile app.
    At least it was a cheap (free) fix! Hopefully it doesn't happen again. I guess even a product as polished as APR's has it's bugs.
    DTM_B7_S4
    Sep 25 2018
    Galv
    Just general info.
    Check gas pedal on vcds. Think my 2002 passat 1.8t is 054 in measuring block. I bought this car for 850.00. They bottomed it out tore off turbo rubber. I bend the clamp reconnected. Put synthetic oil. Sunroof leaked in back so it looked like a mold farm. Anyway, the throttle slowly failed listing epc codes. It fully failed I replaced it bolted it on wrong in dark tightened it down messed it up. Took entire thing apart used old case with new parts it drove got to a no code state. But these systems are sensitive and I bought a cheap one bosch 138.00 and I torqued it good with motor on a bolt leaving a quarter inch gap. 😄 so the new internal were probably compromised. However I'll order a new one and go from there. Highly recommend shop for some if these repairs especially if you don't have the patience and equipment but have money. It'll pull to 100mph guick. 108,000 miles.
    Sep 25 2018
    Galv
    Just saw the anti theft comment 👍
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Pretty sure they got it fixed by now or scrapped the car. This thread is from 2012. 6 years ago.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Sep 25 2018
    Galv
    Yeah just adding in case anyone searches it. Plus I took mine apart to help understand these systems it's basically a vacuum cleaner motor with brushes kinda made me a little ill. [Img]https://pbs.twimg.com/media/DoIYGcWU0AAu_xg?format=jpg
    Sep 25 2018
    Galv
    Sep 25 2018
    Galv
    For intermittent throttle body electrical failure on 1.8t passat. Water had corroded controller connector cleaning with fine bristle brush and wd40.
    Sep 25 2018
    Galv
    Just basic info ecm fried from water in connector. (Long story) nice girl bad mechanic I think... anyhow vag commander and vcds on separate laptops windows 10. I could not interchange cables. Used ecm accessed pins adapted via vcds much easier, immobilizer good. Battery now dead it was acting flaky I'll prob get new batt to be safe but it holds at 12.20 too low. Throttle adaptation after battery then throrough testing in driveway first. May pull ecm pin apart and clean completely. Codes are good except throttle. Used ecm 74.00. It's rained so much here its unbelievable. Roads been flooded bout a week.
    Apr 04 2012
    Calgary/ Alberta/ Canada
    Dead serious mate.
    I’ve rallied my golf, broke the down pipe and burnt through the rear o2 wiring. Check the fuses there is one that kept blowing when the wire was burnt through and arcing
    Sep 25 2018
    Galv
    Basic update to my water infused ecu. charged battery to 12.20 it dropped to 11.40 after install. Replacing battery. Believe water shorted throttle body or wire connectors. Checking after battery install.
    Sep 25 2018
    Galv
    Electronic throttle body motor. I tested two throttle body motors using a twelve volt adapter. Remove gear before testing. Both work good I believe tps was shorted by ecu before it toasted. Used ecu shows good ground and five volts at connector. So now I have three good throttle body motors. Used throttle body in route. Also sealed and unplugged sunroof/switch.
    Sep 25 2018
    Galv
    On vcds if you unplug the accelerator pedal or the throttle body it gives same errors. It runs now. My opinion nonconductive water placed in an electrical connector (ecu) won't fail immediately. I can't place blame on how it got there but I think I know. They knew this girl could afford work and that's what I believe. The water corrodes pins and the green rust shorts over time causing multiple vehicle codes and failures.
    Sep 25 2018
    Galv
    Finished her just now. Took pedal off opened it put it back on. Started. Plugged in throttle started pedal response came back. Deleted codes ran throttle adaptation it took. However a clicking relay felt odd replacing it and used pedal in route will replace old one. Simplification off drive by wire 1.8t. All wires from schematic go into ecu from pedal and throttle they interact in the ecu. Unless wiring is burned or broken three thing could be wrong throttle, ecu or pedal. In my case I believe it was all of them. 😀
