Results 1 to 28 of 28
    Veteran Member Four Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    Non fouler o2 spacer
    So here's the thing, I've searched, I've looked, I've asked. Someone on here put up their own little DIY about how to use the non foulers from Autozone or wherever as o2 spacers. I need to know the part number to use. Anyone?
    2001 A4 1.8TQM. Custom catless turbo back, GTRS turbo, 440 green giants, FMIC, custom tune, ECS RA4 clutch + LWFW, short throw, ST coils, 235-40-18 tires
    ^RIP^
    Jun 10 2010
    This?
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    If you don't find out, just go to Autozone, buy all ~4 that they have and return the three.
    Mar 17 2011
    THAT'S IT! Thanks guy
    ^RIP^
    Dec 05 2007
    You will need 2 non-foulers with a test pipe.
    Jun 30 2008
    Erie, Pennsylvania
    If you are stacking them, the trick is not to drill out the second one at all (usually the first one needs drilled out just for O2 sensor fitment). If you get "no activity" codes or similar, then drill out the hole a bit and try it again. That hole size is how you adjust the sensor's exposure to the exhaust gases.
    You can see the RAI spacer uses the same principle - it comes with different pieces so you can adjust the exposure.
    http://www.raimotorsport.com/RAI-J-P...p/11621vib.htm
    As you can imagine, with these spacers (especially with a test pipe) you are more or less riding the line between "bank 1 sensor 2 - no activity" and "bank 1 catalyst - efficiency below threshold".
    Mar 17 2011
    Yeah it's gonna be a pain in the dick. Would it be more efficient/effective to buy an actual o2 spacer from 034 or something?
    And as for stacking, you mean the one that screws into the cat, don't drill at all, and the next one that the sensor is in needs to be drilled?
    ^RIP^
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by TConklin821 View Post
    Yes. For my 98, I bought 2 of the small spacers from Auto Zone, drilled one completely out for the O2 sensor to thread into, left the other one untouched, and placed it in the downpipe. No cel for it.
    1998.5 A4 1.8TQM My Build
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    It takes about 10 minutes, and costs 3 bucks our you can buy a spacer for about $30
    Veteran Member Three Rings Scientist's Avatar
    Sep 08 2011
    2001.5 A4 Avant
    Troy, NY
    I've seen spacers go between $10 and $38. Google them bad boys and take your pick.
    Veteran Member Three Rings Saskwatch's Avatar
    Sep 14 2008
    05 RL, 01 Avant
    Westy, CO
    Quote Originally Posted by xdewaynex View Post
    This.. Did the same, no cel with test pipe since, stock ecu.
    Rip, "SID" stg2 b5 1.8t
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    Same here, I've the anti-foulers for 15k on my gutted cat, not a single problem, passed emissions flawlessly
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    I tried this and couldn't fit the O2 sensor in when drilled to 1/2 inch.
    So, tried drilling to 5/8ths and drilled the threads off.
    Then I procrastinated for two years, and now I need to pass emissions in the next two days...
    So, I cleared my codes (P0420, P1114, and strangely a P1654), drove at least 10 miles for 15 to 20 minutes to get emissions tested, all the time hoping the CEL wouldn't come back on, only to get there and FAIL because it wasn't reporting ready yet.
    What does it take to get it to report ready?
    didnt your flash already have the deletes? or are you not running that flash anymore?
    contact via email please.
    Jan 17 2007
    Quote Originally Posted by k0mpresd View Post
    If you are referring to me, I have APR but without the deletes for cat efficiency.
    I didn't start throwing the cat efficiency code until a year or two after the initial APR flash and six months after getting the 3" exhaust and HFC.
    Now I'm tempted to go pay the $50 rip off reflashing fee to get the deletes...
    Mar 17 2011
    Mine? No I told you to not delete the rear one (and you didn't, lol). Just deleting it from the ECU will cause a monitor to not clear which is no bueno in NY. I have a friend who will pass me with no cat as long as I have no CEL and good monitors.
    ^RIP^
    oh ok. i wasnt sure. i didnt think so but for some reason i thought you did ask for it.
    Jan 17 2007
    k0mpresd, what's the "hexedit mod" you mentioned in this old thread?
    Dec 05 2007
    ^The sensor won't seat "completely" in the non-fouler. It's no big deal, though. Been riding like that for years till I just changed out my setup with rear o2 sensor delete on my tune. I always passed yearly inspection with no issue.
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Yo dumb ass.. Just do it. Screw the first one to the cat, drill the second so the O2 sensor fits... Gut the cat and you are good to go you PUSSY! When you rolling to Ithaca?
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Mar 17 2011
    I have no cat, test pipe, yo. lol. I'll grab some from work today and do it later or tomorrow.
    ^RIP^
    Sep 05 2008
    Pittsford, NY
    Put any extras you may have up your pooper
    Best regards,
    Sean.
    May 09 2009
    Syracuse, NY
    Quote Originally Posted by DND View Post
    It's not really a "mod", but rather reprogramming the ECU using a hex editor. Basically, you can make it so no CELs (or any CELs of your choice) never show up.
    Veteran Member Three Rings CCA4's Avatar
    Oct 25 2009
    Ford Raptor
    Erie, PA
    I'm running an eBay special that's almost identical to the 034 spacer but 1/3 the cost and way less of a pain in the ass than stacking non-foulers. Works great, no CEL on my AWM with a test pipe.
    http://www.ebay.com/itm/O2-Oxygen-se...#ht_500wt_1314
    Jan 17 2007
    Quote Originally Posted by turbo_bootin View Post
    Ah, I should have known (I do software development for a living), I just didn't think we had that much direct access to mess with the ECU programming... guess I never looked into it.
    I did the spark plug non-fouler mod again and this time it seems to be working, it is pretty easy if you have the right drill bit and don't drill too far (I did 5/8 instead of 1/2 but didn't drill through the lower threads at that size this time).
    My problem now is my sensor seems to be wearing out and throwing P1114 regularly so I still can't pass emissions...
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    Dam <3 florida, no inspections. Getting the RAI testpipe, that comes a J pipe welded on already. I have the AWM as well. Hoping i don't have to do this....
    May 09 2009
    Syracuse, NY
    If you feel like delving into it, check out NefMoto
    Mar 17 2011
    I'm all spaced out. 2 non foulers for 3 dollars. Let's see how it works.
    ^RIP^
