Results 1 to 9 of 9
    Veteran Member Three Rings beejohn's Avatar
    Jan 24 2005
    Pennsylvania
    how often do you have to change copper spark plugs?
    i was told "normal" spark plugs usually have to be changed between 20,000-30,000 miles.
    but, copper plugs need to be changed every 5,000 miles with oil changes. is this correct?
    --beejohn
    2001 A4 1.8TQMS
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    I think the OEM platinums last longer than 20,000-30,000 I just changed mine for the first time about 6 months ago on my 2001.
    Veteran Member Four Rings chunkyckn's Avatar
    Bay Area
    Actually, when I had NGK copper plugs, i changed them every 3500 miles.
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    that sounds like a bit much. Did you read the plugs when you pulled them out? Did they look like the were shot? I'm curious to see what a plug looks like after only 3500 miles(Assuming good conditions)
    The harder I practice, the luckier I get.
    - Gary Player
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    check the plugs every 3k for signs of wear.
    2017 Toyota 86
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    I check w/ every oil change in addition to anytime I'm tuning. I find a lot of insulator jumping so I usually replace quite often. As a regular interval I'd say anywhere from 5-8k. They'll be fine for much longer than that and won't make that much of a difference on a k03. I guess at 1.0bar you might see a dense enough charge to show gap changes.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Jan 24 2005
    Pennsylvania
    what would be my 2nd choice of material to use for plugs then if i only want to switch them out every 30k?
    every 5k miles for new plugs isn't something i want to spend my time/money on, especially for such little performance difference.
    --beejohn
    2001 A4 1.8TQMS
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Copper is the best plug to use on a turbo charged car. If the car is well tuned you can run them for more then 5k miles, just need to keep an eye on them.
    Veteran Member Four Rings Hassmeister's Avatar
    Feb 12 2004
    2015 GOLF R APR Stage 2
    Audi recommended for my '98.5 is 30K for the stock plug.
    I have a K04 and other mods and change my plugs every 5K.
    Click here for AMSOIL - Superior Protection!
    Wholesale pricing and delivery to your door - ask me how!
