I recently posted about an AWM engine that needed pulled because of a broken connecting rod. I got a used long block and the head had a bitched up intake cam bearing surface. I decided to pull the head and found out the used long block head also had a single bent intake valve. I pulled the head off of the original motor(with the broken rod) and it too had a bent intake valve and the piston looks like it may have barely contacted both exhause valves. They appear to be seated properly under valve spring pressure.
Now I have two long blocks and only 1 head is useable. My problem is that I need to replace an intake valve and possibly 2 exhaust valves. I just ordered the tool to remove the valves and it will be here Tuesday and I can get into pulling the valves.
What are some of your thoughts on using used good valves out of the head with the bad bearing surface? Is it blasphemy to not replace the guides? I am kind of on a budget at this point. This rebuild is adding up quickly.
