Results 1 to 18 of 18
    Veteran Member Four Rings victimdumper's Avatar
    Dec 20 2011
    Boston / South Shore
    DIY sun visor clip fix!
    ok so i know im probably the only audi owner to ever break a sun visor clip.....
    but it was driving me crazy, so i finally decided to find a way to fix it without paying $60 at dealer or 46 + shipping at ECS.
    its not perfect and may not be stylish, but will work for me,and maybe someone else will use it or improve upon it.
    (Also excuse the camera phone pictures, i really was gonna feel lame dragging out the dslr for this lol)
    so you probably have something like this: (i already took out the clip by this pic)
    and the clip taken off looks like this:
    to start just grabbed some 12g copper wire, it needs to be sturdy enough to hold and keep pressure on the visor so its not rattling around
    (a thicker top hook part of a coat hanger "might" work, but idk if its strong enough or bendable enough)
    i used this wire, and here is some heat shrink next to it:
    (this heat shrink is thinner than the one i actually ended up using)
    then cut a decent size lenght of this because I wasnt sure what size to use, I also stripped it because the only 12g wire
    i had lying around was bright pink and I dont know alot about matching colors, but I'm pretty sure it wouldn't fit with the black/gray interior.
    i stripped the wire and put a piece of heat shrink on it so it was black,
    and then bent it in the middle of the heatshrink to start making a hook shape
    eventually i got a good enough shape to work with (dont worry too much as you can bend it when fitting later)
    something like this top one but strip the wire first and ignore the bottom one, that was just a first attemp:
    then take a drill press to it, you need to make a base for the bottom of the clip, i drilled at the inside edge of the raised rectangle on the back
    I would suggest not trying to hand drilling a little piece like this,
    it was a pain with the press and I'd assume it would be alot harder with a hand drill.
    Use a small bit to drill a pilot and worked up to a bigger bit
    (i finnaly stopped at 11/64". who the hell normally uses these weird sizes?)
    this was just big enough to stuff the end two pieces of wire through.
    also if you look on the back of the broken clip you can see a raised rectangle on the surface,
    i made this flush with the base of the plastic to make room for the ends that will be there
    looks something like this after the hole:
    then with the wire like this:
    then take out the wire, trim the ends to a much smaller size
    now your going to want to bang the ends of them till they are more or less flat, but will still fit through the hole you drilled.
    push it through to the right spot (test fit this with your sun visor, but you want the fit to be too tight rather than too big because you can bend it out a bit later)
    once you find the right height, bend over the tabs. i used an L shape to try and support both the left/right slide and the front/back slide
    do a final test fit and everything should hold tight, i then just added a tiny bit of hot glue to try to keep anything from moving
    (you shouldn't need this if everything was tight, i just did it as an added precaution not to support the wire, just to keep it there)
    and bam, snap everything back into the ceiling and you wont have to worry about your visor sitting low and wobbling around while you drive =D
    ..oh ya and you saved 60 bucks
    and the final product looks something like this:
    Last edited by victimdumper; 11-17-2013 at 01:30 PM. Reason: one of the hosted pics got deleted
    2005.5 B7 A4 Avant
    Established Member Two Rings builditup's Avatar
    Feb 24 2011
    VA (757)
    I like it. Only thing i would say that may help the look would be to take a larger size heat shrink and go over both wires together to make it look like one, instead of two wires. Just me though. Good DIY
    1996 A4 v6 fwd 5spd 165k (sold)
    2000 A4 v6 Quattro auto 122k (sold)
    2002 A6 wagon v6 Quattro auto 141k(sold)
    2004.5 Duramax 4dr 51k (straight axle, chip.....ect)
    2008 Colorado ext cab 98k I4 (work/dd)
    AUDIless for now....
    Veteran Member Four Rings airjordan223's Avatar
    May 04 2009
    Ohio
    ^along the same lines, you could just use plastidip to get a nice even cover. not the spray can, but the actual dip.
    2013 S4 | B&O | Sport Diff | Magma Red | DSG | LED Fogs| Stance SF03 | Michelin PSS | Gyeon Ceramic Coating | EPL Stage 1 | Maxton Design V2 | H&R OE Sport Springs | ECS Diffuser
    2002 A4 3.0 Quattro | 17" BBS RK | ST Coilovers | LED DRLs | Hardwired V1 | Alpine 12" Type R | Pioneer 800W Amp | eDead 80 | Dice iPod Integration | Power Slot Rotors | Hawk HPS Pads SOLD
    May 24 2007
    Southern California
    lol. why go through that hard work when you can just replace the part. can't be that much...
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Ha..I threw a zip tie on mine
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Jul 27 2010
    St. Louis
    Ghet-to!!
    Sorry, couldn't resist. That piece is a rip off so I can understand why you went this route.
    I just looked at genuine audi parts and its almost 30 bucks, plus shipping. I bought one about a year ago and it was about $20. I don't know how the hell Audi can justify that much of a price increase.
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    every part out i come across, i grab these.
    Dec 20 2011
    @ builditup, the first thing i actually though of doing was putting one piece of heat shrink over both of them, but i didn't know if it would make it better or worse
    hahaha and i totally admit it's ghetto-ness but i figured it was worth it to me, it honestly only took me 10 min to do,
    it would have taken me longer to driver to the dealer. but i also have this wire just hanging out in my house so i wanted to try something
    especially on a piece that's barely visible most of the time
    2005.5 B7 A4 Avant
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    I like it.
    For those playing the home game, get the black lead from a piece of 12 gauge Romex electrical wire. You'll never get coat hanger to bend like that.
    Senior Member Three Rings DaSkorpion's Avatar
    Apr 11 2009
    o4 Audi B6 1.8TQM - o2 MB CLK 55 AMG - o8 Kawasaki Ninja ZX-10R
    CT/NY/NJ/PA
    .....looks gangsta got a broken one as well that needs to be fixed !!!
    Senior Member Three Rings R3V3NANT's Avatar
    Apr 17 2010
    B6 A4 1.8TQ, B5.5 Passat 4M Variant,
    Dayton, OH
    I got mine from a part out. DIY looks good. I couldn't stand that thing being loose!
    Senior Member Two Rings nadatia's Avatar
    Jul 20 2011
    Calgary, AB
    This would likely be the next best thing to finding one on a part out/ junk yard.
    I wouldn't doubt that some VW one who fit as well...
    That being said, this is a good alternative. Nice DIY!
    02 B6 A4 1.8TQM - DG
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    so how do you take this clip off? i know it's real simple, but i'm paranoid as shit when it comes to possibly breaking things even more.
    it just pulls straight out?
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Established Member Two Rings BesI's Avatar
    Apr 22 2012
    S4
    South Carolina
    I just broke mine and I'm looking to buy one but that sucker it's kind of expensive for a piece of plastic
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by BesI View Post
    I'm pretty sure this is the official tagline for the entire Audi parts division.
    Nov 12 2010
    Stillwater, MN
    couldn't we just use one from a parts car? or are these visor clips a one-time-removal thing?
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Veteran Member Three Rings Toolaa's Avatar
    Aug 03 2013
    2004 A4 Quattro 1.8T
    Ellicott City, MD
    [QUOTE=victimdumper;7505437]
    /QUOTE]
    Nothing to be ashamed of IMO. Call me ghetto for keeping $70 in my pocket. I think your solution is good.
    I had the same problem and struggled to find a solution. I found them on EBAY for $7 but when I got I realized it was for the B5.
    I'm not sure why the B5's sell for less than $10 but the B6's sell for $50-70. Even right not at the time of this post.
    So I was pissed at first but eventually I just used two fat drywall anchors to press into the headliner holes. Then I used two short #10 sheet metal screws to hold the clip. It's been working for about 5 months now.
    Nov 12 2010
    Stillwater, MN
    lol $10. almost makes me wish i had a b5 again
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
