Results 1 to 40 of 56
    Mar 20 2012
    Australia
    Good idea to put trans into N when at lights?
    For those with DSG, do you put your car into Neutral for short term stops, eg at red stop lights? I read somewhere that to leave the car in gear with your foot on the brake while stationary can put undue pressure on the DSG clutchpacks.
    Apr 05 2012
    Earth
    What? No. It's fine to leave your car in drive with your foot on the brake.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    1. Leave it in gear, that's how it was designed to operate
    2. DSG transmissions don't have clutch packs.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    Quote Originally Posted by Vogz View Post
    Eh, i thought all dual clutch transmissions have clutch packs....
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Mar 20 2012
    Australia
    Wrong.
    From wikipedia:
    "N"
    N position of the floor-mounted shift lever means that the transmission is in "neutral". Similar to P above, both clutch packs and all gear-sets are fully disengaged, however the parking lock is disengaged. This position should be used when the motor vehicle is stationary for a period of time, such as at red traffic lights, or waiting in a queue of stationary traffic.[19] The DSG should not be held in any of the active gear modes while stationary using the footbrake for other than brief periods — due to the clutches being held on the bite point, as this can overheat the clutches and transmission fluid. This position also allows the engine to be restarted (in some cars needing the key to be partially disengaged) which cannot be done in any of the active modes.[19]
    Veteran Member Four Rings ilspazzaneve's Avatar
    Jul 18 2011
    Lol guys, on the DL501 (7-speed longitudinal S-tronic) each of the two shaft has a stack of alternating clutch plates and disks, sometimes called a multi-plate clutch, or a clutch pack. Wet or dry, it's still a pair of clutch packs. The DQ250 (6-speed transverse DSG on golfs and TTs) is similar. Only the lower-end DQ200 has single-plate clutches.
    I think some of you are thinking of the clutch packs in Auto trannys and thinking "oh no, my DSG doesn't have that!". Oh yes, it does. Two of them.
    And yes, I shift to neutral at red lights. Maybe it doesn't matter to some of you, but this car drags the clutches all the time when stopped, it absolutely gnaws at me whenever it'd doing this - it's just plain wrong. Plus I hate having to hold the brake unnecessarily on level ground (please don't give me a driver's ed lesson on this, I won't change and am always aware who is coming up behind me)
    Jan 15 2010
    North
    I am fairly certain that when in gear and fully stopped that my car (DSG) doesn't drag the clutch. In fact, the short pause of it actually taking out the clutch to get the car rolling bugs me when inching the car into the garage. Also on an incline, like in the driveway, I can feel the car roll back the instant the brake is let go and feel the brakes automatically applying to stop the roll back. Does your car behave differently?
    Quote Originally Posted by ilspazzaneve View Post
    Jul 18 2011
    Quote Originally Posted by compguy View Post
    Hmmm. lol I'm always in neutral when I make a full stop, so as much as I believe it's true, I can't tell you from recent experience. I CAN tell you both the F430 and a MP4-12C do not drag the clutch until you hit the gas....this is how the DSG should be set up.
    I get the incline rolling thing too, but that's only on a decent slope.
    I'll VAG it tomorrow and confirm, should be pretty easy to tell with engine load.
    Mar 20 2012
    Australia
    Coming from an M3 with DCT as my previous car, one of the reasons why I asked the questions was because the M3 would always shift to N automatically when at a stop, which is something I loved, as I too hate having to put my foot on the brake at stop lights. So I'm now getting into the habit of shifting into N whenever I stop.
    May 11 2010
    2011 S4
    I thought it was it neutral when you stop. You can feel it disengage and re-engage when you stop and go. It is linked to the brake pedal though, not the gas pedal - hence the delay when you take your foot off the brake before you coast away. I could be wrong, but it just seems funny to have to shift to neutral at lights or in stop and go on the highway. I think the big thing is to not let the car sit stationary on a slight incline with just the engine/tranny alone (i.e. - use the brake pedal when stopped on an incline). That is what is bad for the clutch packs.
    Mar 20 2012
    Australia
    I don't think the car goes into neutral when you stop, because the car creeps forward if you take your foot off the brake.
    Established Member Two Rings P_RsS4's Avatar
    Jan 29 2012
    Enterprise, AL
    Quote Originally Posted by blackswan View Post
    When you take your foot of the break there is about a second before you feel the clutches engage. I don't know if when you stop the transmission shifts in to N but I do know that the clutches disengage.
    2012 Phantom Black S4 Prestige|DSG|Sport Differential|APR stage 2+ V2.0 ECU|APR S/C Pulley|H&R OE sport spring|Supercharged badges|Stage 1 & 2 Carbonio Intake|35% tint front and rear sides|15% rear window.
    Future mods:APR's RSC Exhaust, Bilstein or Ohlins Coil-overs.
    2012 Brilliant Black Q5 Premium Plus, S-line plus.
    2013 Vivid Black Breakout/V&H Big Radius 2-into2 Black/SE Heavy Breather Air Cleaner
    Jul 18 2011
    Ok I'm sitting in the car, 100% certain the clutch drags when stopped in D.
    Jul 18 2011
    Simple way for everyone to see this is to watch the mileage display go from 2.0 L/hr in D, to 1.2 in N. load is on the motor to drag those clutches.
    Mar 20 2010
    2010 B8 S4 red with red inter, 77 Trans Am (orignal owner); 2005 Subaru Impreza RS
    MD
    I have a DSG 2010; Daily driver in Washington, DC area traffic.
    Hi, I don't put the car in neutral at stop lights. Maybe I should? I asked Audi specifically this question and they told me that " when the car is at a stop there is no engagement of the clutches." He stated to me that "if you are at an incline - even very small - keep your foot on the brake so that this will not wear the transmission."
    When I let go of the brake pedal I "feel" that this is when the clutch becomes engaged and allows take-off.
    I get a slight roll back when I take my foot off the brake and press the gas. I changed my driving style so on slight inclines or on hills (or racing someone) I keep left foot on brake and as I am sliding it off hit the gas.
    Jan 29 2012
    Enterprise, AL
    Thats weird. I know my clutches disengage. At first I thought there was something wrong with my transmission. I then did research and found that the clutches do in-fact disengage when you press the breaks and the car is stopped. There is a slight incline in my driveway, when I stop on it then release the break the car rolls slightly back before the clutches engage. It happens every time..
    Mar 20 2012
    Australia
    Going back to my original post, in the M3 the DCT tranny always goes into N at a stop - once you stop the car, you can take your foot off the brake. In the DSG, you cannot do this - so therefore the car must still be in gear at a stop. That's why I will have to get used to shifting into N.
    Edit: arguments for and against this - can an Audi tech chime in? Would love to know the answer to this.
    Junior Member Two Rings
    Apr 20 2008
    Sacramento
    I'm not sure if this is proper, but I just pull the ebrake button and it seems to disengage the trans even in D. discovered it the other day on my 2012 S4 when i was bored waiting for a friend.
    Active Member Two Rings blackphantom's Avatar
    Mar 20 2011
    uk
    ihave the hill hold assist option fitted,when you come to a stop {on level ground or on an incline} the electromechanical brake is automatically applied then as soon as you touch the gas pedal its released.its a cheap option that audi should have included as standard with the dsg transmission
    Established Member Two Rings Eggplant Wizard's Avatar
    Jan 15 2010
    Little Rock, AR
    Hill hold is standard in the US.
    Mar 20 2011
    uk
    Quote Originally Posted by Eggplant Wizard View Post
    just looked on audi usa it lists {Electronic stabilization control [ESC] and Anti-lock Brake System [ABS] with Electronic Brake-pressure Distribution [EBD]; Electromechanical parking brake } as standard could not see hill hold mentioned anywhere.
    Veteran Member Four Rings svander's Avatar
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    Yeah, doubt you're going to find that in the Audi site as a feature listed. It's in your manual though...
    Clutches do disengage at a stop. They re engage automatically (after about half a second delay) the second you remove your foot off the brake pedal.
    All VW/Audi DSG operates like this.
    Established Member Two Rings jc522's Avatar
    Mar 08 2012
    Illinois
    I have a friend who teaches transmissions, has owned several Audis, and has been to school on the s-tronic. According to him it does disengage the clutch when at a stop with the brake applied. Papers he gave me from the class also show this. Have you ever slipped from brake to accel very quickly and felt the bump as the clutch engages? The bump is still there in Comfort mode, but for some reason it seems to happen less often. Also, if you've ever tried to drive the car up a set of ramps to change the oil you know that the dropping into N makes it a real PITA to slowly crawl up a ramp if you stop on the way up.
    Jan 03 2011
    FYI, i go to manual mode in bumper to bumper traffic so the tranny doesn't "overshift" and cause unnecessary wear & tear on the clutchpacks. Just a habit coming from a lightly modified Evo with a Getrag dual clutch tranny that was hitting the torque limits of the tranny where the clutchws would slip and didn't want to push it much more.
    On a side note, here's some VW Clutchpacks which are good for 500whp
    http://www.sspperformance.com/produc...-package---vw/
    Old cars:
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    No, it's a seperate button in front of the parking brake trigger. It's standard on VW's not the S4 (at least not currently), also missing in the US are power folding mirrors, underseat storage, headlamp washers and several other small cost cutting measures.
    You can code the VCDS to release the brake when forward motion is applied, and use the parking brake for hill hold, which is essentially what the button for it does anyway.
    Quote Originally Posted by svander View Post
    Exactly correct.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Jun 08 2010
    philly metro
    Quote Originally Posted by NWS4Guy View Post
    Exactly correct.
    I thought that pressing the brake in a little harder on an incline/decline would automatically engage the brake for hill holding..... It seems to work that way on my 2011
    Jan 15 2010
    Little Rock, AR
    My car absolutely holds the brakes until the accelerator is depressed after releasing the brake pedal on an incline. It doesn't require any extra buttons to be pressed, it's automatic. Hill Hold. I did not pay extra for this.
    Edit: and you can see in my avatar that my driveway is quite sloped, so I use this feature often.
    Jul 18 2011
    Seriously, for all you who still believe the clutches are disengaged at a stop, watch your mileage counter while stopped on the brakes.
    When you shift from N to D, you will plainly see the consumption go up because it is loading up the clutch pack, while stopped. If your car does NOT do this, I'd be very interested to know.
    You will likely see 1.2 L/hr in N, and 1.7-2.0 L/min in D. Idle speed is the same, there is no other source for the load.
    That is the reason to shift to neutral at a stop.
    Jan 15 2010
    Little Rock, AR
    I'm going to try it out of curiosity, but my feeling is that there are other reasons besides dragging clutches that could cause load on the engine to go up in D.
    Jul 18 2011
    Such as? Idle speed is the same. And there is a definite forward thrust, I don't even need to let go of the brakes fully to let the car creep on the clutch.
    Now I'm wondering if it's a software revision thing? But I don't think so. Audi programmed S-tronic to behave like a slushbox for the non-enthusiasts. That's why it does this.
    Oct 24 2011
    San Jose, CA
    The clutches may not be *fully* engaged at a stop, but they most definitely a partially engaged. DSG is not like R-tronic or SMG or E-Gear which are basically robotized traditional manual transmissions which fully disengage their clutches at a complete stop (and therefore offer no "creep"). Note that many versions of the automated manuals above actually should still be shifted into neutral -- just like a real manual transmission -- to avoid wear on the throwout bearing. Each SMG II and III at least will eventually change to "N" automatically after something like 30 seconds to prevent excessive wear, but there's still driver intervention involved at some level.
    Back to DSG… Listen to the load on your motor as you switch from "D" to "N" at a complete standstill. Hear the difference? Still don't believe it? Hook up your favorite OBD reader or VCDS and watch the engine load parameters and fuel delivery rates increase by a good 25% when in "D". You're definitely wearing out your clutches if you're sitting at red lights in "D" as if you had a slush box.
    2010 Audi S4, Meteor Gray/Black&Black, Prestige, S-Tronic, Sport Rear Differential.
    Mods: APR Stage I, H&R sway bars, Alu Kreuz, 2013 S4 flat-bottom steering wheel, VCDS, hardwired Escort 9500ix.
    Senior Member Two Rings Banan's Avatar
    Mar 28 2009
    B9 Avant 3.0TDI
    Sweden
    Now I don't have an S4 but an A4 allroad so there might be some software difference, but my car is clearly dragging it's clutch when standing still in a red light. I can clearly hear the engine sound changing when shifting between neutral and first. I always put the car in neutral when standing still. I haven't tried ilspazzaneve's way with the L/Hr showing but will do so next time.
    Veteran Member Three Rings audisarecool's Avatar
    '11 S4
    I highly doubt Audi designed the S4's dsg to require a shift into "N" at a stop.
    Current: 2014 Phantom Black RS5 - Stock for now
    Gone: 2011 Quartz Grey S4 // Stasis V2 // VMR V710 // H&R OE Springs // 034 Adj CA's // Alu Kreuz // APR Stg 1&2 Intake // 12.44 @ 112
    Oct 24 2011
    San Jose, CA
    Whether they "designed" the transmission to undergo the wear associated with being left in "D" when stopped isn't really the issue; it's just that it will create unnecessary wear on the transmission, more so than a traditional automatic. Warranty coverage won't be denied because you didn't shift the car into "N" at every traffic light. But that doesn't mean those who choose to just let the clutch slip every time they stop won't see more wear on the drivetrain.
    If you have DSG and plan on keeping the car for a long time (e.g., past its warranty), shift into neutral if you're sitting for more than a few seconds.
    Jan 15 2010
    Little Rock, AR
    Occam's Razor. DSG is designed to be driven in the same manner as any other automatic. Already have a DSG car with 80k miles still going strong. I'll shit a brick if the clutch packs wear out before the mechatronics shreds itself.
    Jan 29 2012
    Enterprise, AL
    I guess there has to be different softwear on the DSG. I just tried to let my car creep forward and can't get it to do it. I have to completely lift my foot of the break pedal and wait for about 1/2 second before I feel the car start to creep forward.
    Established Member Two Rings Lloyd_Christmas's Avatar
    Jun 02 2011
    As entertaining as this debate is, why doesn't someone (not it!) just open the owners manual and see if there is any language about shifting the DSG tranny to neutral when not in motion. If it is not in there, there clearly Audi didn't view the theorized wear as either a) existent or b) serious enough to warrant making mention of it.
    Mar 28 2009
    B9 Avant 3.0TDI
    Sweden
    @Lloyd: There are those who are more anal about the cars maintenance then what the manual recommend, my manual says I should wait up to 30.000km between oil-changes. I wouldn't even think of following that either...
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    Haha, i keep the clutch depressed, revvvvvv it nicely once or twice as the opposite
    traffic get yellow for that spectacular launch .....................
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by Lloyd_Christmas View Post
    I scanned the entire 8 pages of the manual into an HTM doc, but can't seem to find a way to post that document as an attachment in AZ. Meantime, here's a screen shot excerpt from the manual's S-Tronic section that may dispel any doubts ...
    [IMG][/IMG]
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
