Results 1 to 40 of 62
    Veteran Member Three Rings betyouaint's Avatar
    Mar 31 2010
    2016 Chevy Silverado Z71
    Wherever I lay my hat...
    Deformed Oil Filter
    When I change the oil on my 2.0T, the filter looks like it's had the life sucked out of it. It's quite deformed and not the same shape as when it was fitted. Is this normal?
    I'll try to post a picture later...
    2006 Audi A4 2.0T Quattro Tiptronic - Now over 240k but still ticking along...
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    What kind of filter are you using?
    New Build, 2010 Tiguan. Details to com
    Mar 31 2010
    Mobil 1 Extended Performance... it seems I have 2 different kinds. I suspect the odd one out is an OEM filter and that looks a bit battered too...
    Sep 06 2011
    Harrisburg, Pa
    None of those are from the dealer. I've seen aftermarket ones do that a lot. I'd go with Genuine Audi or MANN. Only time I've ever seen them do that is after being left in for 15k or longer. But to answer your question it is not normal
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    It looks like the filter is too long and gets crushed a little when tightening the filter housing. They don't look compromised but I wouldn't take a chance on this. Go buy the OEM filter and install it. Then remove it to see if it's deformed. If not use the OEM filters and don't worry about this again. If it's crushed you have another problem to deal with.
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    soggy, oil filled paper filter, im guessing it only gets deformed on the initial twist to unscrew the filter ??
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Established Member Two Rings 2006Scorpion's Avatar
    Oct 07 2011
    Utah
    I changed my oil about 1,000 miles ago and I had the Mobil 1 filter in there and it looked the same as yours. I switched over to the more expensive Bosch filter.
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Looks like they are too "tall" and are being crushed when the cannister is tightened down. I've always run the OEM filters, never had a problem.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Veteran Member Three Rings Homer's Avatar
    Jan 27 2010
    2006 A4 6MT Quattro, 1990 Volvo 240 Turbo
    Bay Area
    Quote Originally Posted by Stewy View Post
    That. Hengst, Mann or Genuine Audi only.
    -Jacob
    1990 Volvo 240 Turbo-Project Car
    2017 Audi allroad prestige
    Oct 16 2012
    Baltimore MD
    Had a friends mobile one filter do this. It even gave him a low oil pressure light after about 400 miles. He switched to oem and hasnt had a problem. Reason being is you can get a deal for around $35 for oil and filter at your local auto store. But the mobile filter is just garbage.
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    My OEM filter looked like that after a 10K kms OCI, i wouldn't be too worried.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    Quote Originally Posted by Jay-Bee View Post
    OCI? Sorry....my brain isn't working today!
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Senior Member Three Rings adamc514's Avatar
    Sep 01 2009
    Nissan Murano
    TN
    OCI = oil change interval
    Rip on it...
    Veteran Member Three Rings gdlkn84as's Avatar
    Apr 25 2012
    2006 B7 A4 S-line 2.0T (Sold) - 2008 PT Bruiser (Long Story) - 2003 Kawasaki Z1000
    Greenwood, IN
    Re: Deformed Oil Filter
    I just changed my oil at 90k miles, my Mobil 1 filter looked like that. They never did previously. I'm thinking it happened when I unscrewed the filter housing. Eventually ill be getting the aluminium one from ECS or Europarts
    2006 B7 A4 S-Line 2.0T - SOLD
    -Making my return to the 'Zine-
    2016 B8.5 Allroad
    PP+, Sport Interior, DS, VAG'd
    2003 Kawasaki Z1000
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    Use OEM filters only. Although Mobil advertises it fits our cars, I bet it's a bit longer than OEM size, which makes the filter to squeeze inside the filter housing.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Never had that problem with the MANN. Seems like the others are simply not made for our cars and crush.
    Oil Filter (2.0T)
    Jun 27 2011
    The filter I pulled out of my b7 a few weeks back looked totally normal. I assume it was OEM, but I didn't install it so I dont know. You guys are making me nervous about the crappy FRAM filter I put in (shut up, its just what I had at the time!). Good thing I'm changing the oil again this weekend since I just replaced the cam a week after I did the oil change a month ago. Got a stash of OEM filters to toss in.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 08 2010
    tucson
    danbury
    doesn;t look crushed, it looks twisted, can;t be sure because i don't live inside an oil filter, but i would imagine givin the twisty nature of the filters, that it looks like this happens when you unscrew the housing, combined with the fact that oil has been soaking the filter for 4-6 months paper tends to get soggy and easily manipulated.
    if it was crushed it would look more wavy and not all in unison
    [CENTER]Scott
    2011 S4
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Always use Mann or OEM. My used filters never look crushed or twisted. Probably due to certain other brands being slightly longer and after soaking in oil, being twisted upon removal of housing as pointed out above.
    Unless they look like they've fallen apart or completely deteriorated, I can't see why it would matter though.
    Mar 31 2012
    Savannah. GA. USA. TO. ON. CAN
    It's not normal to have deformed oil filter. Try to use OE VAG or OEM Hengst filters. I only use HQ Hengst filters.
    The filter on the right it looks like a Hengst filter
    //S POWER
    Oct 16 2012
    Baltimore MD
    So I have gone through 3 Mann oil filters in three months. I'm running stage 3 with gt2871r and Im being told that my turbo is causing my oil filters to be sucked in and crushed causing the oil pressure light to come on. Is this true? In the 3rd post in the photo My Mann oil filter looks just like the middle mobile one filter or worse.
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    Not normal. Never seen one look like that. I use hengst.
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    recently changed my oil and filter came out looking like this. first time this has happened and i've been running mobil 1 filters from the start. maybe it was just a lemon.
    Oct 16 2012
    Baltimore MD
    Well I've been using mobile one and Mann and it stinks up causing low oil pressure sensor. This will start a month after I change the filter so I have to change the, every two or three months to just be safe. I will try the hengst filter and will post results
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    always used the fram filter with mobil 1, no problem.
    Veteran Member Three Rings schizzy's Avatar
    Jun 29 2009
    2008 SRT4
    New Jersey
    Only used Mann filter in my car
    Ocean Blue b7 a4: -Revo stage II -apr/BB exhaust w/ tp -eibach/kw coil overs -19" sportec mono 10 -forge dv -rs4 swaybar -rs style grill -euro jet pcv fix -apr snub mount -custom intake -m3 spoiler -35% tints...... TOTALED BY DUMP TRUCK
    Current: 1990 vw
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    My last MANN filter looked goofy as hell. If it does it again, I'll get a picture.
    -Dan
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Jun 27 2011
    Deformed Oil Filter
    Quote Originally Posted by Lemon123411 View Post
    Ummmmm or you have low oil pressure... Might want to figure that out before you engine grenades itself...
    -CP
    2017 Q7 3.0t
    Mar 31 2012
    ...... Mann and it stinks up causing low oil pressure sensor....I will try the hengst filter and will post results
    Never had low oil pressure problems with HQ Hengst filters what so ever. Hengst is the best OEM filters
    //S POWER
    Oct 04 2011
    Rochester, NY
    I had a similar situation with a Bosch filter. replaced it with a Mobil 1 but now I'm not expecting better results. bought an OEM the other day.
    But I wouldn't say its from being too long, it looks like the middle got sucked in, no other twisting or squishing. and I change my oil every 3k if not sooner.
    Established Member Two Rings seco007's Avatar
    Jan 06 2013
    Omaha, Nebraska
    I had the same experience with a mobil 1 filter....I switched to MANN and hopefully it wont happen again.
    Oct 16 2012
    Baltimore MD
    I'm sure it's the oil filter because every time I change it even after a month the filter is sucked in to death
    Oct 16 2012
    Baltimore MD
    Quote Originally Posted by seco007 View Post
    I wish my filters looked this good. Mine are worse then this. I will be taking a picture as soon as I can get on a lift.
    Oct 07 2011
    Utah
    I was having this problem with the Mobil 1 filters and ever since I switched to the Bosch Filter my filter has yet to come out thrashed and crushed looking and or twisted. This tells me it's not the car but something to do with the filters. Just changed my oil on Saturday and I was running the Bosch filter and it came out looking mint (minus the black and dirty part)
    Apr 25 2012
    Greenwood, IN
    So here is my old filter, I believe it is a Mobil1 filter
    Heres the new stuff, Motul w/ Mann filter
    Will see if this filter gets warped in 5k miles!
    2016 B8.5 Allroad
    2003 Kawasaki Z1000
    Senior Member Two Rings CharlesP2009's Avatar
    Sep 22 2012
    2009 Audi A4, 2009 BMW 335i Convertible
    The Copper State
    I just pulled a K&N PS-7010 Oil Filter from my car after 5,000 miles and it was deformed into the shape of a corset. Something like eyesolution's photo above. Not nearly as bad as those horror photos of the other Mobil 1's!
    I wish we could get some controlled testing of oil flow and filtration efficiency with these various filters. I'm willing to bet Mobil 1 wouldn't score so well; still, people buy their products en masse thanks to the marketing. I likely won't buy the K&N filter again. I want to get my oil change interval up to 9,000 miles but I don't like the idea of a massively deformed filter being in there for so many miles. I wish I had taken note of what I pulled from my car after the last dealership oil change. It was in excellent condition after 5,000 miles. I'm going to use a Mann for my next service.
    Mar 31 2012
    Quote Originally Posted by B7Joe
    Always use Mann or OEM.....
    Quote Originally Posted by Homer
    OEM = Bosch, Hengst, Mann, Knecht-Mahle etc.
    OE = Genuine OOOO Audi
    Quote Originally Posted by Charles.Waite
    I assume it was OEM, but I didn't install it so I dont know. You guys are making me nervous about the crappy FRAM filter I put in (shut up, its just what I had at the time!).......
    When in doubt ask
    //S POWER
    Mar 31 2010
    Did another change yesterday and the Mobil1 filter had the worst deformation I've seen yet. Definitely not crushed or twisted as I fully fitted and removed the new filter to check. I've written to Mobil1 to ask them what the deal is. Either the structural rigidity of the product is insufficient from the get-go or, as the filter pours block over time the filter is simply crushed by the increasing hydraulic pressure differential.
    There is no rupture of the element that can be seen and the seals at either end maintain the barrier. I'm less worried about oil bypassing the filter and more worried about the risk of oil starvation... but then, like most cars, I assume that these engines have an oil filter pressure relief valve to bypass the filter?
    I'm gonna check this one in 5,000 miles and see if that make s a difference. I've read threads on other forums that suggest this only happens between 5,000 and 10,000 miles. Odd really as Mobil states they are good up to 15,000.
    I'll let you know what kind of reply I get from Mobil... if any.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Why bother? Just switch to Mann or OEM already like people suggesting
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by BenMTL View Post
    this...
