Results 1 to 6 of 6
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    How to test Wideband Sensor
    Hi all.
    Title says it all.
    Basicly what's going on is that my wide band died slowly down to 7.4 and stays there now.
    Change the sensor for a new one, did the new calibration procedure like the 10 seconds key on while it's unplug then 10 seconds off. Plug every thing and tried sensor calibration, but won't make it. It says heater open. Same with the old sensor. I've checked LC-1 module connections and grounds. I'm starting to think that my LC-1 module is dead.
    Now before jumping to this conclusion, I need to test both sensors heaters.
    Is there a way to check heater resistance on those 6 pin 5 wire wideband sensors like we can do on the OEM O2 by checking resistance between pin 1 and 2?
    I've search but kind of hard to find.
    Thanks
    Rombotis built and EPL tune 770r 3L = best
    Oct 14 2007
    Val-Belair
    Of course... sensor resistance would be great to have too.
    Oct 14 2007
    Val-Belair
    Ok I got something. The only thing That I need now is which pins to use to check this resistance.
    Nominal heater cold resistance at 20°C
    ambient temperature for new sensor,
    including cable and connector: 3.2 Ω
    Minimum heater cold resistance at -40°C: 2.1 Ω
    Oct 14 2007
    Val-Belair
    Here are the 5 wires assigment that I've found. From the sensor side connector.
    Pin6 (Red wire) = (I) pump
    Pin4 (White wire) = Heater-
    Pin1 (Black wire) = Voltage supply
    Pin3 (Gray wire) = Heater +
    Pin5 (Yellow wire)= Pump circuit ( that adds or remove oxygen from the O2 ) correct things...
    Pin2 is dead end at the other side of the connector. (used to loop the calibration resistor with pump)
    Source =http://www.megamanual.com/PWC/wire.htm
    Remember. Never put a multimeter probe at other pins then heaters. Heater check is the purpose of this thread.
    Hopefully that will help someone in the future.
    Last edited by Reich; 04-19-2012 at 12:36 PM. Reason: did several corrections on this page. It is now good.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Reich View Post
    Red = Heater+
    White = Heater-
    Black = Signal wire
    Gray = Signal ground
    Yellow = Pump circuit ( that adds or remove oxygen from the O2 ) correct things...
    Will you include the pin#?
    Oct 14 2007
    Val-Belair
    Quote Originally Posted by Max@034 View Post
    You're right. My bad. I'll do that.
