Need help with this issue.
My A/C was working fine and then it slowly got warmer and warmer to eventually i had to blast it at full fan speed (Setting 12) to get the inside temp cool enough.
I Noticed that when i came to a complete stop, the A/C compressor started to make a noise (As if the clutch is having difficulty spinning). But as soon as i would start driving, then it would go back to normal.
Tonight, i made a mistake a recharged it with those advance auto parts bottles (Only because I needed this issue resolved quickly because i am leaving out of the country next week).
As i was charging it, the A/C compressor or something in that area got slightly louder, and then everything shut off, including the engine fan and A/C compressor.
Now it only blows air, not hot, nor cold.
These are the codes/errors i pulled:
Tuesday,26,July,2016,21:23:38:46545
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 5F: Information Electr. Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 8T1 035 664 C HW: 8T1 035 664 B
Component and/or Version: H-BN-NA H47 0116
Software Coding: 010200000006E1EF01000F0E000000030000
Work Shop Code: WSC 08213 444 50537
VCID: 387F4DCF8BE65AFE86-806C
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 199
Mileage: 233023 km
Time Indication: 0
Date: 2016.07.26
Time: 21:15:01
Freeze Frame:
Voltage: 12.30 V
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 199
Mileage: 233023 km
Time Indication: 0
Date: 2016.07.26
Time: 21:15:06
Freeze Frame:
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 00000000
Any help is appreciated.
