This is for anyone who is having the 01539, 01534, and 01535 error codes when switching over to Depo headlights that re-use our range adjusting motor.
The white wire on the headlight motor harness is in the WRONG pin hole. Pull the pin out carefully, and swap it over to the open pin on the other end. Easy as pie! Sorry no pics.
Harness should look like this:
1- Open
2- Brown
3- Black
4- Blue
5- White
Depo wired it like this
1- White
2- Brown
3- Black
4- Blue
5- Open
After the wire is swapped over, clear the codes in your 55 control module. You will still have code 01539 (adjust headlights).
Check to make sure your motors work, which they should since the code is no longer there.
Then procede with the adjustment section in Vag-Com per:
http://www.a4mods.com/index.php?page...tml&category=6
MONEY SHOT!!!
