Results 1 to 40 of 65
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Hyper Silver wheel paint
    I have been running a set of RS6 reps in Hyper silver for several years. The finish is starting to show a little age and I would like to refinish them without having to deal with de-mounting the tires and powder coating to get a Hyper Silver color. I am not at all adverse to rattle can spraying the wheels if I can find the right paint.
    Has anyone stumbled across a Silver that is either in a rattle can or spray gun that is close to Hyper Silver? Everything I can find requires de-mounting the tires and applying a powder coat and baked top coat. I only have $350 in the wheels to begin with so that much work really isn’t an option.
    Right now I’m leaning toward the Wurth or 1Z Einszett wheel restoration kit Clicky click but it really isn’t as bright as I would prefer.
    Anything else available that you may know about?
    Established Member Two Rings juki's Avatar
    Dec 31 2011
    not sure of what matches.
    I rattle canned wheels on one of my old cars in silver. See if this color matches
    The paint is Duplicolor wheel paint: http://www.duplicolor.com/products/wheelCoating/
    And here is what the color turned out like:
    Dec 28 2006
    Western Maryland
    Thanks for the pic. Wheels look nice! I considered the Dupli-Color silver and that is still an option but it isn't as bright as the Hyper silver. I'm beginning to think it will not be possible without a multiple coat process.
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    Subscribed! Will be planning to do this too!
    And if it helps, I read somewhere before that hyper silver is the end product of powdercoating the wheel gloss black at first then coating it with a metallic bright silver.
    It may sound dumb but thats what I read somewhere when I was looking for a touch up paint for my hyper silver v708s
    Sep 16 2010
    Central Wash
    I read something on a VW forum a while ago that involved mixing some of the fake chrome paint with a silver metallic and spraying it on with a little gun. But I've never heard of anyone getting the hyper silver paint code. It's listed on some websites- Paintscratch or something may even list it. But never tried it.
    One thing I looked into a little while ago was "real chrome paint" . Just google it. Not cheap but I've seen the results vary anywhere from hyper silver to VERY close to actual chrome depending on the effort you put into it.
    Dec 19 2007
    York, PA
    i have used the duplicolor silver and it isnt as bright as the oem sports. they are a nice bright silver, couldnt you get the paint code for them and have a shop mix some cans up for you?
    Veteran Member Four Rings vhstejskal's Avatar
    Feb 01 2011
    UT
    I purchased some pain cans from ECS that were a pretty good match. It came in two cans one the base coat and one clear coat. I ended up fixing a small patch of curb rash on my sport wheels but unfortunately I can't find any pics.
    -Vic
    Aug 28 2008
    2008 RS4, 2013 Allroad
    East Bay, CA
    As far as I know, the hyper silver color is a 3 stage process. Base coat, top coat, clear. I had my RS4 rims powder coated in hyper silver last year.
    Dec 28 2006
    Western Maryland
    Audi_nightrider / GinobeS4: I came across the same thing on several different sites. Black powdercoat base /baked on silver and topcoat.
    Rollerton: I actually discussed this with Dupli-Color about using the Dupli-Color chrome and follow it up with a clear top coat to mute the chrome a little. They advised against it and said it would actually turn the chrome a dull gray color.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by vhstejskal View Post
    Thanks! I'll check the ECS site and see if I can find it. I'm guessing it was Wurth silver and clear. It's a good match for the OEM wheel but not as bright as the Hyper silver.
    Veteran Member Three Rings Murph's Avatar
    Sep 07 2008
    Seacoast NH
    Quote Originally Posted by GinobeS4 View Post
    I believe it is black, then silver and clear. I don't think there's a hyper silver wheel paint you can buy in a rattle can. At least I couldn't find one. I have used Wurth Silver and Clear previously. I just ordered a kit on Amazon that has silver and a 2K clear coat. The 2K clear will give a more durable surface as I live in NH. That said you need to stay with kits as if you mix and match on your own you may experience undesireable chemistry issues with primer/ base or base/ clear interactions.
    Now: 2007 B7 A4 3.2L Auto. It's stock and staying that way. Then: Sold to another enthusiast: 2005 Dolphin B6 TQ 6 speed. GTRS Eliminator, Bosch 550 injectors, REVO SW, FMIC, APR TIP, High Flow Cat, Milltek Cat Back, Custom Interior Mods, Short Shift Kit, Suspension Goodies, S4 Recaro Seats
    Dec 28 2006
    Western Maryland
    Thanks Murph. I realize I can't get a true Hyper Silver straight out of a spray can. I just want to get as close as possible without a multistage process.
    Junior Member Two Rings mjwkr's Avatar
    Apr 19 2011
    SE Michigan
    I have no experience with this but what about plasti-dip? It sounds like they can mix custom colors and with the different enhancers you may be able to get close? Worth a call/email?
    http://www.audizine.com/forum/showth...ight=Plastidip
    Feb 01 2011
    UT
    I'll check when I get home. I can't find it on the site but I'll check when I get home as I still have the two cans. I know when I was searching for wheel paint I would have gone with the Wurth Silber...
    -Vic
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by mjwkr View Post
    I'll shoot them an e-mail and see if it's possible.
    Feb 01 2011
    UT
    I found the two bottles I have... MFG PN# LLS0M6Z17 ECS still carries it Clicky Click but looks like on special order and I don't remember paying $29 so apparently inflation hit... I'm assuming the Avus Silver Wheel paint is the same as the sport; only thing I'm unsure of is the match to that of the USP, although looks OEM. The paint comes in 4oz aerosol bottles so it would take quite a few to do multiple wheels; which seems like Wurth is a more cost effective option.
    -Vic
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    here's a tip if you are not removing the tires: large index cards work great to mask off the tires, just stick them between the wheel and tire and go all the way around. no tape necessary.
    i actually purchased those same exact wheels from harttman today in 19", i've always like those wheels.
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Dec 28 2006
    Western Maryland
    I found the two bottles I have... MFG PN# LLS0M6Z17 ECS still carries it ] but looks like on special order and I don't remember paying $29 so apparently inflation hit... I'm assuming the Avus Silver Wheel paint is the same as the sport; only thing I'm unsure of is the match to that of the USP, although looks OEM. The paint comes in 4oz aerosol bottles so it would take quite a few to do multiple wheels; which seems like Wurth is a more cost effective option.
    Thanks for the info Vic! The Avus wheel color is an OEM Silver. The Hyper Silver on my aftermarket wheels are not an OEM color. That's where I'm running into difficulty trying to come close to the "hyper" color.
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    What's wrong with the finish on your wheels now? Scratched/chipped or just dull? If they're just dull, get out the polish. If they're scratched/chipped, it's worth it to get the tires removed and the wheels blasted and powdercoated. If you don't have a friend in the tire/wheel industry, make one. The friend price for this type of work is surprising.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by FORCE_FED_DUB View Post
    The finish is still bright. I guess the best way to describe the problem is that the powder coat is slowly wearing off leaving what appears to be sanding scratches under the finish. Currently you can only see them in direct sunlight but they are getting worse. I tried polishing compound but only succeeded in rubbing through the remaining powder coat As I mentioned earlier I only have $350 invested in the wheels. I'm really not interested in pulling the tires off and getting them refinished. If I can come up with something that can be a weekend project I will go for it. Otherwise I will just pick up another set of wheels when my tires need replacing and put these in the classifieds.
    Aug 10 2008
    Denver, Colorado
    If the finish is that thin/fragile, you should chemical strip them and polish them out and just throw a coat of clear on them. Talk about a bright silver finish...
    -Cam
    Dec 28 2006
    Western Maryland
    I don't disagree at all. I'm just too lazy to put that much effort into it. Hellava lot easier to just pick up another set of tires/wheels:-)
    Aug 10 2008
    Denver, Colorado
    old guy seems to be in a bit of a funk.
    -Cam
    Senior Member Three Rings on1wheel01's Avatar
    Mar 03 2012
    mooresville nc
    It does suck taking tires off to powder coat as I'm doing it right now to mine. Best of luck and like said flash cards work well to protect the tires.
    Senior Member Three Rings blackfc3s's Avatar
    Oct 15 2010
    Custom build 29er Mountain Bike
    Nebraska
    Im in the process of refinishing my 18" USP wheels. 31 dollars to remove and discard the destroyed tires I have.
    Next im going to habor freight and picking up a media blaster, probably there cheapest soda blaster.
    Mar 03 2012
    mooresville nc
    Quote Originally Posted by blackfc3s View Post
    One thing I recommend is get some air craft stripper it will save you a crap ton of time at the blaster. I do powder coating and hate spending forever at the blasting cabinet lol.
    Oct 15 2010
    Nebraska
    Chemical stripper did nothing to the rims.
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    I know you are looking at keeping the Hyper Silver, but I think if you color match the wheels to body color it would look even better then the Hyper silver and would be cheaper to boot.
    Mar 03 2012
    mooresville nc
    Well did u use air craft brand the one with a plane on the front thats the only one that does anything. Trust me I powder coat as a business and It's what I use. Almost fully stripped my wheels after 2 coats
    Veteran Member Four Rings airjordan223's Avatar
    May 04 2009
    Ohio
    I tried to get a silver using plasti-dip. The black base with silver metalizer was a gunmetal, so I was told white base with silver metalizer would be a light silver. I'll let you be the judge...
    they're pretty white
    2013 S4 | B&O | Sport Diff | Magma Red | DSG | LED Fogs| Stance SF03 | Michelin PSS | Gyeon Ceramic Coating | EPL Stage 1 | Maxton Design V2 | H&R OE Sport Springs | ECS Diffuser
    2002 A4 3.0 Quattro | 17" BBS RK | ST Coilovers | LED DRLs | Hardwired V1 | Alpine 12" Type R | Pioneer 800W Amp | eDead 80 | Dice iPod Integration | Power Slot Rotors | Hawk HPS Pads SOLD
    Mar 03 2012
    mooresville nc
    White as hell bro. But looks damn good imo
    Oct 08 2009
    12 more rings
    Northridge, CA
    Quote Originally Posted by on1wheel01 View Post
    lol X2
    its white and I don't see silver at all
    I'm still waiting for old guy to find a good solution to this =)
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Active Member Two Rings HalfAudio's Avatar
    Sep 24 2011
    A4 1.8 1996
    UK/Staffordshire
    Lightbulb Seeker
    I have replica rs4 18" wheels on my car.
    I have the same colour wheels like these in the picture but they are in a bad condition so i need to respray them for tip top condition.
    This is what i would like to get! doesnt mater how as long as i can do it whit aerosol paint.
    bright silver aerosol paint cant be found..
    i was thinking maybe a White Primer would help it bright up a litle the usual silver paints?
    Wurth White-Grey Rust stop Primer + Wurth German Alloy Wheel Silver + Wurth High Gloss Clear Lacquer Or some matte lacquer would work better? or bouth of the mixt up.
    Moving forward
    Audi 90 2.3E (1989)
    Audi A4 1.8 (1995)
    Audi A4 1.8 (1996)
    Audi a4 b6 avant 1.9Tdi (2003/2004)
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    dupli color makes a spray can of Audi/volkswagon hyper silver. I just picked some up for my Avus wheeels. I also picked up some spray cans of Dolphin grey from audi and it was black so I have to send that back.
    Sep 16 2010
    Central Wash
    Here's a thought that just occurred to me-- a few years back I had to refinish an old gas tank in my old SWb Porsche 912. I Bought some stuff to clean it all out and used POR15's gas tank sealer.
    When you mix it up right this stuff comes out very bright shiny silver and it has the consistency of plasti-dip. I actually used the bit I had left over to paint the spokes on a steering wheel. Like POR15 it levels VERY well, I used a brush to apply it and the brush strokes disappear. The steering wheel looked like it was powdercoated bright-aluminum, and I never cleared over it.
    Anyway, that was a few years back, but...it's a thought. if you were brave enough to try and spray it, it would be an awesome finish.
    Here:
    http://www.por15.com/US-STANDARD-TAN...oductinfo/TSG/
    But:
    Quote Originally Posted by MNAudi101 View Post
    Let us know how that stuff turns out too, I'd be very interested in the results!
    Feb 01 2011
    UT
    I used that sutff for my USP lower valence...
    Clicky Click
    -Vic
    Dec 28 2006
    Western Maryland
    I would be very interested to see how this turns out. I have been in contact with Duplicolor and they have a bright Silver but it isn't the Hyper Silver that I am looking for. My RS6 wheels are aftermarket and the finish is definitely brighter than the OEM wheels.
    Quote Originally Posted by rollerton View Post
    I see where I can purchase an 8 oz sample of the sealer. I think I will pick it up to play with and see if it will work.
    Senior Member Three Rings bedes's Avatar
    Mar 19 2010
    Alameda, Ca
    link or part # please.
    Veteran Member Three Rings vteckiller2000's Avatar
    Jan 22 2011
    2008 ZX6R
    Iowa City
    Fletch I think the chrome would be the closest to the original, I experimented with it once and it turned out an almost perfect match to the original BBS hyper silver on my WRX.
    2012 F150 Ecoboost
    2008 Kawasaki ZX6R
    Dec 19 2007
    York, PA
    FWIW Fletch, heres my OEM Sports i sprayed using Duplicolors wheel paint products.
