Results 1 to 33 of 33
    Established Member Two Rings wrclaguna's Avatar
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    Anyone have B8 with LANE ASSIST ? I need coding/adaptation to retrofit.
    I want retrofit lane assist to my B8. I have installed camera, windshield heater, steering wheel switch but no 4-spoke wheel only.
    Can someone with lane assist installed could give me coding from module 5C- LAIN MANTAIN (I need value from this module)
    Does anyone knows Lane Assist is dependent on ACC and suspension ?
    Below is coding which I do it for now:
    5C- LAIN MANTAIN.--->Coding 07 ---> 0002001 --->Do It !
    07 Control Head ---> Adaptation 10---> channel 01---> value + 16382---> Do It! Restart MMI
    16 Steering whell--->Coding 07 --->Long Coding Helper--->Byte 2 Bit 7 change 0 to 1
    17-Instuments --->Coding 07--->Long Coding Helper --->Byte 4 Bit 6 change 0 to 1
    I know must do it calibration in dealer. How to make adaptation?
    Chipped 203HP/419NM / MMI 3G+ SIM / Q5 BREMBO 345/330 / Double Exhaust 3.0 TDI/SIDE ASSIST/ LANE ASSIST/ACC RADAR/HIGH BEAM ASSIST
    MY AUDI A4 B8 S LINE EXTERIEUR
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    I found just such an encoding of the Q7, and probably will be the same in A4 B8
    Coding lane keeping assistant control unit
    Structure of the coding value (7 positions): 7654321
    Position 1 and 2 (xxxxxXX):
    xxxxx01 A Audi Q7 (PR number 1CN)
    Position 3 (xxxxXxx):
    Country version
    I xxxx0xx = Country variant 1: A Rest of the World with Canada
    I xxxx1xx = Country variant 2: A only USA
    I xxxx2xx = Country variant 3: A only Great Britain
    I xxxx3xx = Country variant 4: A only Japan
    Position 4 (xxxXxxx):
    Optional extra
    I xxx0xxx = without adaptive suspension (PR number: 1BA, 1BV, 1BW), without adaptive cruise control (PR number: 8T1, 8T0)
    I xxx1xxx = with adaptive suspension (PR number: 1BK), without adaptive cruise control (PR number: 8T1, 8T0)
    I xxx2xxx = without adaptive suspension (PR number: 1BA, 1BV, 1BW), with adaptive cruise control (PR number: 8T4)
    I xxx3xxx = with adaptive suspension (PR number: 1BK), with adaptive cruise control (PR number: 8T4)
    Position 5 (xxXxxxx):
    Optional extra
    I xxx0xxx = without fingerprint (PR number: 4K4, 4K7, 4F2, 4K2), without Japan navigation system, vehicle without navigation or with a different navigation system from Japan navigation (PR number: 7Q0, 7Q2, 7T4)
    I xxx1xxx = with fingerprint (PR number: 4K5, 4K6), without Japan navigation system, vehicle without navigation or with a different navigation system from Japan navigation (PR number: 7Q0, 7Q2, 7T4)
    I xxx2xxx = without fingerprint (PR number: 4K4, 4K7, 4F2, 4K2), with Japan navigation system (PR number: 7Q6)
    I xxx3xxx = with fingerprint (PR number: 4K5, 4K6), with Japan navigation system (PR number: 7Q6)
    Position 6 and 7 (XXxxxxx):
    I For the Audi Q7 positions 6 and 7 are always coded 00 (00xxxxx).
    Veteran Member Three Rings Demandred's Avatar
    Jul 24 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    I have lane assist but waiting on cable before I can help ya
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    Hello 5F coding needs you have.
    Additionally, what you write and the suspension (1BA, 1BE 1BV) and you have the ACC.
    What is the Security Access Code?
    Now I'm coding 0000001 and I have only one error
    Junior Member Two Rings
    Apr 12 2011
    Montreal
    Does the lane assist, actually steer the car left and right "changes a lane to another" ?
    Don't you need to retrofit a part that goes on the steering axle, that will steer the car using an electrical motor ?
    I am going to retrofit this option in my A6 2012.
    Jul 24 2011
    Lane assist on mine is lights on the wing mirrors that flash at you if it detects a car in the lane you are looking to move into, different flashing speeds depending on how close the car is.
    There is also the option of it to give vibrations in the steering wheel to advise you there is a car there (not sure why as the lights are hard to miss and having a car that feels like you are driving over cats-eyes is annoying)
    I certainly don't think there is a lane assist option that does the actual changing on the lanes for you ( there was the VW auto parallel park feature) but these are different
    Apr 12 2011
    Montreal
    Thanks for pointing that out. :) Does lane assist use the same mirror led of side assist?
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    Electronic Imaging
    Black and white image captured by image capture sensor is then processed by image processing software. First, the picture looks for lane boundary lines. If they are recognized on both sides, is given the width and curvature of the lane.
    As further parameters the software calculates the location of the car on the lane, so the distance the car from the left or right boundary line and the angle at which the car approaches the line. Image processing software analyzes the quality of lane departure warning.
    Based on these calculated values ​​and the known dimensions of the vehicle is determined to send a warning point. Depending on the setting point of sending a warning in the MMI system is used to calculate the various courses of action. You will be also asked to determine whether the function has been temporarily disabled due to the geometry of the lane, or not.
    Assistant to the stability program is integrated into the lever direction. Press the button to enable or disable the system. The current state of the system is shown in the instrument cluster with warning light. If the pilot light is lit, it means that the system is turned on. If the light is not lit, the system is turned off.
    Current state of incorporation shall be recorded and assigned to a car key. This means that when the ignition is switched off at the last inspection assistant was on the track, it will also be incorporated at the next turning on the ignition. The condition here is that the use must be the same as the ignition key at the last ride.
    The possible states control lamp in the instrument cluster
    Green light: the system is turned on and ready to work
    Yellow light: Although the system is turned on, but due to current circumstances is not ready to work
    The reasons for the yellow warning light in the instrument cluster may be as follows:
    There is only one limiting line or no line
    Boundary lines are not recognized (eg, due to snow, mud, moisture, reflections of light).
    There are more than two lines of limiting its own lane (eg. White and yellow markings in areas where road works are carried out).
    Speed ​​is lower than the switching threshold of the system - about 65 km / h
    Lane is narrower than about 2.5 m or wider than 5 m
    Corner is too small (radius less than about 250 m).
    Pilot light off: the system is off. To activate the system, press assistant track and control the direction lever.
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    [url=http://postimage.org/]
    There is no input code to do it ACCESS SECURITY ADAPTATIONS
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    I've had the parts to do this mod for almost 2 years but can't buy a windshield here :(
    Found this code for a 2009 Avant if it helps 0001001
    Not sure if it relates but here is coding from 2 Passat CC's 0030002
    When I dig my camera out I'll see if I can hook it up on a canbus and read it's coding.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    www.audienthusiasts.com
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    Encoding is OK with me that is 00000001 and the problem lies in the adaptation of 10. No active channels, only have 28-32
    On my VCDS is no hint of code SECUTITY ACCESS.
    Nov 06 2009
    What shows when you do an adaptation scan of the module? How many channels are locked and are any available?
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    I only have these four channels active in the adaptation of 28,29,30,31. Wartośi in these channels show zero. Tomorrow paste screna with VCDS
    O one more thing I did not write, of course, do I need to calibrate the system dealer. Maybe here's the problem
    With me in Poland is one for the instrument on which they must wait for months (this is kinda sick )
    Established Member Two Rings darecy's Avatar
    Jan 10 2012
    poland
    Can you do it calibration board by your self if you know the size and layout (is only a board with the circles)
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    Well ...... you just have to wait 2 months and the dealer
    Nov 12 2010
    italia
    Quote Originally Posted by darecy View Post
    Hello Darecy. With the instruction of members of audi4ever i have calibrate ACC with self made calibration board, using output test. All ok with this mode.
    But to start calibration for lane assist you need code for security access and start basic setting....do you have security access for module 5C? It would be wonderful!
    Guido
    Nov 12 2010
    italia
    Quote Originally Posted by DavidB8 View Post
    hello David...i haven't done an adaptation scan...what is this?
    Jan 10 2012
    poland
    @205guidorosso
    could you help me with the calibration board layout and sizes, please.
    I will find out security access for the module 5C... I hope...
    At the moment I have all stuff in place and connected...
    Nov 12 2010
    italia
    Hello Darecy, i am searching like you sizes of calibration board and security access for 5C.
    I don't have understand if the calibration is possible with Vagcom, like i made with acc..............
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    Unfortunately, the only calibration will help me
    Nov 12 2010
    italia
    Quote Originally Posted by wrclaguna View Post
    This is self made calibration board and camera on the windscreen without change it:
    http://forum.audirsclub.it/showthrea...-VAS6430/page3
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    So everything will agree engulfed in the ASO
    Sep 22 2013
    Norway
    Hi all, did anyone get this to work?
    I have a A7 with ACC, and would like to activate line assist, I do not have the side assist modules, but belive that line assist is only using the ACC. camera?
    Jan 10 2012
    poland
    Quote Originally Posted by Soft View Post
    Line assists uses the front radar, different speedos, and steering switches. You have to check also central electric module if it compatible with the ACC mode...
    Sep 22 2013
    Norway
    Ok, how can the radars see the lines in the road?, anyway, I do understand that it uses different modules, what I was trying to say is that I believe that if u have ACC, you have the needed modules.
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
    Sep 22 2013
    Norway
    I did some further digging:
    The control units necessary for the Audi active lane assist function:
    Camera control unit J852:
    · Registers the area in front of the vehicle and transfers the images to the image processing control unit J851
    · Searches for lane boundary lines in the images, determines their exact position and geometry, and transfers this infor- mation to the control unit J851
    Image processing control unit J851:
    · The function software of Audi active lane assist is integrated in this unit
    · Transmits the required system steering moment to the control unit for power steering J500 and, if required, requests a vibration alarm
    · Asks the control unit in dash panel insert J285 to display the current system state and, if required, to display messages and warnings
    · Transfers the current system state to the control unit for windscreen projection J898 and asks it, if required, to display warnings
    · Saves the settings for Audi active lane assist made via the MMI. The stored values are assigned to the vehicle key in use.
    Power steering control unit J500:
    · Activates the motor for electromechanical steering accor- ding to the specifications of the control unit J851 (generation of the required system steering moment and output of a vibration warning)
    · Reads in the sensor for steering moment G269 and forwards the steering moment to the control unit J851
    Optional control units that can be used if fitted:
    Adaptive cruise control unit J428 and control unit 2 for adaptive cruise control J850:
    • If the vehicle has the optional extra ACC, its measured variables are used for the two functions "Deliberate lane change without set turn indicator" and "System characteris- tics with obstacles detected on the neighbouring lane"
    Park assist steering control unit J791:
    • If the vehicle has the optional extra front / rear parking aid, its measured variables are used for the function "System characteristics with obstacles detected on the neighbouring lane"
    Data bus diagnostic interface J533:
    • The interface of the various data bus systems
    Steering column electronics control unit J527:
    • Reads in the button for switching the Audi active lane assist on and off and places the information on the CAN bus
    Control unit in dash panel insert J285:
    • Displays the current system state of Audi active lane assist • Issues messages of Audi active lane assist
    Control unit 1 for information electronics J794:
    • Settings for Audi active lane assist can be made via the control unit J794
    Control unit for windscreen projection J898:
    • If the vehicle has a head-up display, the current system state and warnings from Audi active lane assist can be displayed there
    Then I went through my VCDS scan and I have:
    J851
    J500
    J852
    J428
    J533
    J285
    J527
    J898
    J794
    I do have all the needed modules (ex step the stalk)
    Audi will not code it for me!
    Need to figure out if the car actually needs software, or if it is a matter of enabling things.
    I know it will request some adaption/calibration befor it will work, but assuming that the camera is calibrated, so I could go next, next on this.
    Jun 02 2011
    Raleigh, NC
    I'm very interested in retrofitting Adaptive Cruise Control (ACC) and Active Lane Assist on my Audi A5 (B8) or my soon-to-be purchased Audi S5 (B8.5). Has anyone successfully implemented both systems on their B8 or B8.5? Really sucks that we don't have this on our US cars, even though its been available on the Euro and Aussie versions for a few years!
    Jul 16 2008
    Finland
    ACC is not too bad if you already have another assistant system in the car, like highbeam assist, lane assists, etc. If not, then you also need to change the CAN gateway.
    Parts needed:
    Front radar sensor, very expensive new (1500-2000EUR), 200-500EUR used on ebay.de
    New bumper grille with cut-out for the radar & hardware to attach it, don't have the part numbers on hand ATM
    Wiring loom, Kufatec sell a pre-fabricated loom, which I will use for my project
    Cruise control stalk with ACC buttons
    Compatible Steering Collumn Control Module (SCCM)
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Jun 02 2011
    Raleigh, NC
    Quote Originally Posted by TDIaholic View Post
    Parts needed:
    Thanks for the insight. Can you reference any part numbers?
    Jul 16 2008
    Finland
    Partsbase.org you can find the part numbers and exploded diagrams here.
    Jun 02 2011
    Raleigh, NC
    Quote Originally Posted by headcase View Post
    So just to follow up, has ANYONE successfully retrofitted Active Lane Assist on their B8 or B8.5 here in the US? Really curious to see if this has been accomplished on a US car.
    Junior Member One Ring Mrclopec's Avatar
    Jan 11 2012
    Nipomo, CA
    http://www.audiworld.com/forums/q5-s.../#post24705727
