Results 1 to 17 of 17
    Apr 18 2007
    ny
    Do I really need the cam chain tensioner tool?
    I'm getting ready to pull the cams and tensioner so I can replace the necessary seals. Reading some of the DIY's and watching a few videos I see people using the special tool to compress the tensioner. My question is do I really need that tool if I'm goona pull the tensioner, cams, and chain together as one unit? I've spent enough money on one time use tools already for my build and would hate to buy and wait for another. Thanks guys.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Why pull the entire cam just to replace the seals? That would require you to take the timing belt off also, which you would need the cam bar. There is a reason they make the tool, and it's fairly inexpensive. I've done the tensioner seals a few times and I wouldn't do it without the tool.
    Apr 18 2007
    ny
    Well the motor is out of the car and I'm changing everything possible. Timing belt and sprockets are off already so I would like to get the seals done today and not wait for the tool to be delivered. My main reason for wanting to pull everything out as one is to keep the cam sprockets lined up, I don't want to mess anything up with the timing.
    SOLD
    Greg
    C5UNION
    Jun 30 2008
    Erie, Pennsylvania
    It can be done without the tool, but it is a serious pain. I wouldn't do it without it.
    I loan this tool out to AZ members, just cover the shipping. I usually send it first class mail, so it takes a few days but it's just 2 bucks each way.
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    I second this. Just get the tool.
    Apr 18 2007
    ny
    Thanks guys, walkyalky pm me your paypal info.
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Good man!
    I did the seals on my V8 without the tool. It wasn't that bad. But the only reason I did it that way, is because I didn't know any better. I remember using a small set of picks and working tediously to get to the seal, and put the new ones in. It is doable without it.. But I am sure the tool makes for a much easier (plus peace of mind) job.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 29 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    Get the tool. There's a reason they make it. It makes me cringe every time I see people not take the cams out to do the half moon seals. Anyone who has done them before knows that dirt hides in that groove they sit in and if you don't clean it out it's gonna leak again soon.
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
    Apr 18 2007
    ny
    Quote Originally Posted by The_Auto_Tech View Post
    I was under the impression that the tool was only made for compressing the cct in order to remove it without pulling the cams, I don't see what the need for it is if the cams, chain and cct are coming out at the same time.
    SOLD
    Greg
    C5UNION
    Nov 29 2010
    Des Moines, IA
    Quote Originally Posted by A62TURBO View Post
    I don't see how you could ever get the cam chain tensioner out without pulling the cams. It fits tightly in there even with pulling the cams out with it. Just get the damn tool and stop trying to work around it.
    - Cody T.
    Established Member Two Rings AUDI_S4_ATL's Avatar
    Jan 08 2010
    2000 Audi A4 1.8t PAST
    GR MI
    I did it without and had zero issues. Removed the bolts that hold it down and put steady pressure on the cct until it went down. If your engine has been sitting there should be minimal resistance while pushing it down. I've read many bad stories about using the tool and it breaking so I skipped using it all together. Since your engine is out, cleaning the mating surfaces should be no problem.
    Established Member Two Rings JETSPEED333's Avatar
    Dec 19 2007
    2004 S4 (rip), 1999 1.8T QM(rip), 2000 s4 stage iii (rs6r), 2004 A4 1.8 6sp stgii, 2004 A4 Avant 1.8
    NorCal
    use the tool..you can buy one on ebay for 10 bux.... and if your changing the cam seals , yes, you will need to take off the timing belt....which you will need the cam bar(i've done this part with out the bar but don't recomend it...)
    if life passes you by..... DownSHIFT!
    Apr 18 2007
    ny
    I see how the tool might make it a bit easier but they still came out like butter without it.
    SOLD
    Greg
    C5UNION
    Established Member Two Rings DNB01A64.2's Avatar
    Apr 03 2012
    Baltimore, MD
    Quote Originally Posted by AUDI_S4_ATL View Post
    How did you do it? PM sent
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Get the tool.
    I do not recall ever pulling a cam for a half moon gasket replacement. It can be installed with cams installed. The tool is used to replace the tensioner gasket most specifically.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    This^^
    Im sure there are ways to hammerphuk them together without the tool, but you dont want to do that.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Apr 18 2007
    ny
    I pulled the cams and tensioner all at once, the tool is only required if you only need to pull the tensioner by itself or change seals. If you don't want to pull the cams, use the tool.
    SOLD
    Greg
    C5UNION
