Results 1 to 17 of 17
Thread: Oil, Why 5W-40
    Mar 05 2012
    Coventry,CT
    Oil, Why 5W-40
    Ok so i know this comes up a lot but ive never found the answer I'm looking for while searching the forums. I've been changing my oil in my B6 S4 with Mobil 1
    0W-30 because that is the weight that the owners manuel calls for. Now i see just about everyone putting 5w-40 into there B6 and B7. I have 120k on my car im getting ready to do my next oil change, so my question is why the switch? Should i put in the 5w-40, will it be better on my car i care so dearly about loll. If it will help her run better for longer i have no problem with it i just want to know why it changed.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Personally I wouldn't put 0w-30 in a motor that has 120k on the clock... waaaaay too lite imho...
    any of these will work...
    • Lubro Moly Synthoil Premium 5W40 Engine Oil
    • Pento High Performance II 5W40 Engine Oil
    • Total Quartz 9000 Energy 5W40 Engine Oil
    • Motul 8100 X-cess 5W40 Engine Oil (5 Liter)
    • Motul Specific 505.01 502.00 505.00 5W40 Engine Oil
    Oil Change Kit (4.2L)
    Order everything required to perform the highest-quality oil change in your Audi / VW 4.2L engine. Please scroll down for the applicable Audi / VW models.
    The oil in this kit is Audi / VW certified and parts are OEM (or better) quality and TüV/ISO 9001 certified. Our professionals carefully selected and tested every component of this kit to ensure the perfect fit and quality. Your satisfaction is 100% guaranteed.
    You can customize this Audi / VW oil change kit to fit your specific needs. Just use the check boxes and radio buttons to select/deselect the desired kit components.
    All components in this kit are 5-10% off their regular prices. Order this complete oil change kit and save now!
    Mar 05 2012
    Coventry,CT
    I was litterly just looking at the kit It seems like lubro moly 5w-40 is liked by many on this forum i think im gonna go ahead and order this kits from you guys. Thank you =)
    Senior Member Two Rings nadatia's Avatar
    Jul 20 2011
    Calgary, AB
    0w40 for the win
    02 B6 A4 1.8TQM - DG
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    You can largely ignore what's printed on the bottle. For something to qualify as a 0w40, there's a range of kinematic viscosities it can have. So it is entirely possible for there to be a "thin 0w40" and a "thick 0w40". There are some 5w30s that are so thick they're only 5% thinner than some 5w40s, for example. It's a sliding scale.
    The reason I say you can ignore what's on the bottle is that the HTHSV (high temp high shear viscosity, sometimes shown as just HTHS) is the true "operational viscosity" of an oil. HTHS is basically the oil's kinematic viscosity at 150 C, a temperature you will see in the bearings and other high-stress areas. Judge an oil's viscosity by the HTHS value, not the printed viscosity on the label. The VW 502/505 (and ACEA A3/B3 spec upon which it is based) calls for HTHS to be at least 3.5. You will see a whole host of oils right around there: 0w30s, 5w30s, 0w40s, and 5w40s.
    Here's a good example: Castrol Syntec 0w30 and Liqui-Moly Synthoil Energy 0w40 both have HTHSV of 3.6. This means that for all intents and purposes, these two oils will have the same viscosity during normal operation. This is despite one appearing to be thinner! Another good example: Red Line 5w30 and Mobil 1 0w40 both have HTHSV of 3.8. Again, both of those oils will have the same viscosity during normal operation....yet one is 5w30 and the other 0w40!
    Here's another doosy that will really illustrate it well: Motul 300V 5w40 offers HTHSV of 4.51. Castrol Syntec 5w50 offers HTHSV of 4.3...so which oil is thicker? The Motul is, despite being labeled as a 5w40 and appearing to be thinner.
    One more in case you still aren't getting it: Red Line 5w20 has HTHSV of 3.3. Pennzoil Ultra 5w30 has HTHSV of 3.1...so the Pennzoil is thicker because it's a 5w30, right? Wrong, the Red Line is thicker since it has a higher HTSV.
    Where people get into trouble is assuming that all 0w30s, for example, are the same viscosity. They aren't. Mobil 1 Advanced Fuel Economy 0w30 has an HTHSV of only 3.0 -- it is considerably thinner than Castrol Syntec 0w30 (3.6). The M1 would be some 17% thinner in operation despite being labeled as the same viscosity! Certain boutique oils for racing/high-performance apps, like Red Line and Motul 300V, have abnormally high HTHSV for their grade. Red Line's 5w30, as I said above, is as thick as many 5w40/0w40s! This is a result of the special group V basestocks they use.
    Pick an oil with HTHSV 3.5-4.0. Anything higher than 4.0 is unnecessary in most of our cars and will just sap power and generate more heat (and change oil pressure slightly). Anything under 3.5 is a gamble that would result in more power/better fuel economy but provide considerably less protection.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Apr 24 2009
    Frisco, TX
    I'll add something since I'm sure people are wondering why the labeled viscosity can be so misleading: it's because the "5w40" is derived from its performance at two temperature points that the engine spends almost no time at. The HTHSV is measured at 150C which is absolutely seen for extended periods in the valvetrain, among other places.
    It bugs me that the system is so confusing but it isn't helped by the European car companies generating big oil lists and building their own ultra-tight oil requirements. The domestic and Asian companies have their own requirements but they're quite relaxed. My parents' Infinitis (both VQ35 high-output V6s) can run on any 5w30.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by catsonacid View Post
    Anytime!
    Veteran Member Three Rings madkimchi's Avatar
    Sep 09 2009
    Bicycle and roller blade.
    Kent, WA
    my regular dealer use M1 5w40 for v8 s4 so i been using that since. well i only go to one dealer for all my work/maintenance. working well so far.
    Jan 25 2007
    Junk
    San Francisco
    Quote Originally Posted by madkimchi View Post
    thats an epic failure, as M1 5W40 does not meet any 502.00 specs.
    If its a dealership, they should be using Castrol 5W40
    2018 RS3 STG II
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    Quote Originally Posted by dparm View Post
    Where can you find the HTSV of an oil? Many threads on Shell Rotella T6 5w40; what's your opinion on it?
    '17 SQ5-034 Stage 2 ecu/tcu-JHM 187mm CP-034 inlet, RSB, sub frame inserts-Eurocode trans/diff mounts-Alu Kreuz-B8/H&R-Neuspeed RSf72 20x9.5 et25-Magnaflow 11385-OEM airbox mod-aFe 11-10121
    Mk7 GTI-034 Stage 1 ecu/tcu-H&R springs/B8-Neuspeed rse11r
    Triumph Street Triple R-Full Arrow and tune
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by zxsuxr View Post
    It meets MB 229.51 which is almost identical to VW 502/505. M1 ESP Formula M meets ACEA A3/B3 and has HTHS 3.8. It'll be fine. Wouldn't be my first choice though.
    The other M1 5w40 variety is Turbo Diesel Truck (TDT). HTHS 3.8 and meets some strict diesel engine specs; safe to use too though I think that oil is in desperate need of an update.
    There are some other diesel engine-specific 5w40s from Mobil but that's outside the scope of what we're talkinga bout here.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by miggity02 View Post
    Manufacturer's website might list it on the product data sheet/technical data sheet. You may have to email and ask. Pretty much any 5w40 is going to be above 3.5 -- I've never seen one that wasn't.
    If the oil is ACEA A3/B3/B4, then we know it's at least 3.5.
    T6 5w40 has HTHSV about 4.0-4.2. Good budget oil that has worked for a lot of people. Typically runs about $23/gallon, which is around $5.50/qt.
    Senior Member Three Rings 04 S4's Avatar
    Nov 01 2011
    2005 Ford E250 Work van
    Bonney Lake, WA
    dparm...you are a reason that rep systems were created...wish I could give you some. Thank you for making that so much simpler!!!
    2004 S4 (Tip) - Dolphin Grey metalic Traded 4/3/13
    2009 Q7 Prestige S-line - Daytona Grey
    Apr 24 2009
    Frisco, TX
    Ha, thanks man. It's a community and I want to make sure everyone can enjoy their car for many years to come. Pay it forward.
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    Thanks for the response! I've been running t6 for a while now in both cars and my dads mk5 and I've been happy. I do notice a slightly higher operating temp though. ( I think)
    Apr 24 2009
    Frisco, TX
    Engine temperature shouldn't be affected. These are not air cooled engines -- the thermostat will regulate everything pretty much regardless of the oil you run.
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Quote Originally Posted by 04 S4 View Post
    2nd that!!
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
