Results 1 to 7 of 7
    Aug 06 2009
    01 B5 Audi A4 1.8T
    New York
    P0600 code what does this mean?
    i have the eurodyne tune and i did a regular read on my ecu and this code popped up. Anyone have any info on what i can do to fix it?
    Trouble code 1 ; P0600 Serial Communication Link
    And im running a base file they send me.
    2001 A4 1.8T Stage 3
    Aug 06 2009
    01 B5 Audi A4 1.8T
    New York
    bumpp
    Dec 05 2007
    Has something to do with your OBD II serial port. If everything is communicating, I would not be surprised if it is just something that came along with the tune. If you are that concerned, contact your tuner and ask him/her about it. No CEL, correct?
    Aug 06 2009
    01 B5 Audi A4 1.8T
    New York
    Nope no cel but i have a airbag light that i always had.
    Dec 05 2007
    Air bag lights are legit. Get it fixed. Vag Com may be able to tell you which components is the issue, because it does it when it comes to the ABS. Scan your car and see which components it says it causing the issue and get it fixed. More like likely a wiring issue (ie frayed wires, loose wire, or connector simply need to be cleaned with electrical parts cleaner).
    Aug 06 2009
    01 B5 Audi A4 1.8T
    New York
    Ok thanks alot!
    Active Member One Ring a4quattro3.2's Avatar
    Apr 14 2015
    Calexico California
    hello my friends, I have a problem with my 2006 audi A4 3.2L, a few days ago the check engine light comes on, then the abs and esp light, turn off the car and light it these last two are off, driving a few blocks and when brake pedal makes a sound when brake on the inside and then the abs and esp light comes on, I indicates two codes P2404 and P0600 on, I hope your help thanks
