Results 1 to 32 of 32
    Veteran Member Three Rings TheChef's Avatar
    Aug 30 2010
    Houston TX
    The BBS CH-R Stainless Rim Guard is AWESOME!
    A bit over a week ago, my front driver side CH-R had a very brief but unfortunate meet up with a piece of rogue concrete on a local freeway here in Houston.
    The result was not pretty....sorry for the iPhone Camera shots....
    Damage by TheChef810, on Flickr
    The damaged area is about 1" long...and relatively minor cosmetically outside of looking at it from about 3 feet. But I knew it was there and it bugged the hell out of me.
    Repair? For years, we have seen this idea played upon with multipiece wheels where a lip could be replaced, rather than the entire wheel. This often left the rest of us, that liked single piece wheels no options outside of taking our wheels to a wheel repair shop....with varying levels of results. The BBS CH-R is designed with a pattended Stainless Steel Rim Guard - a replaceable part for a situation just like this one. The replacement part will run you 50-75 dollars or so....mine came directly from BBS in Braselton, GA. I was told, the wheel can stay on the rim and the rim mounted to the car. Alright, lets see how this works...
    Deep breath....and I took a large flat head screw driver and further seperated the guard from the wheel...minding the faceof the wheel, I pulled the out, and then with a slight pull along outside of the wheel, it pops right off.....
    OldGuard by TheChef810, on Flickr
    ...walla.
    That leaves us with the wheel, sans guard.....
    NoGuard by TheChef810, on Flickr
    You can see the area where the damage was around 11oclock on the wheel.
    This picture was after I used a bit of 400 grit paper to smooth down the area. I wasnt concerned about the cosmetic as the area would be covered by the new guard. I just wanted to ensure that the new guard could lay flat over the area. You will notice a slightly raised area on the outside of the wheel, this small, plateau style lip allows the concave stainless ring to pop perfectly in place, so no guessing is necessiary. This wheel is now ready, after I removed any excess residue from the old rim guard adhesive with goo gone.
    After removing the backing from the new rim guard (handle gently, it is thin and frail and you dont want it to bend!)...
    New by TheChef810, on Flickr
    Pretty awesome huh? One more, upclose, same photo as the first one depicting the original damage....
    New Upclose by TheChef810, on Flickr
    When many of us buy wheels for our cars we think of design, fit, finish, performance, weight, strength...but we dont think about repairing damage. Something we all will run into some day at some time, if your at fault, or not. I know when I decided upon the CH-R I didnt think much about it...but now, having seen the technology work first hand....its really impressive.
    Kudos to BBS for an awesome idea and design. This whole process took me 20 minutes, and 15 of that was cleaning the residue up from the old guard. Its amazing to know that a wheel can be back good as normal for less than 75 bucks or so in mere minutes. A great way to protect your investment.
    #ProjectS7 2013 & 2014 SEMA Feature car w/ HRE
    Glacier White. Quilted. Innovation. Carbon. LED. Big Red Brembos.
    Partner's: HRE Performance Wheels. Audi. APR. H&R. Michelin. TiKore. EVOKlass. Eurowise. Mothers.
    Veteran Member Four Rings teky929rr's Avatar
    Aug 13 2009
    LR3
    New Jersey
    Very nice write up and big thumbs up to BBS!
    Current | 2021 SQ8
    2017 - Q5 | 2015 - R8 |2010 - S5
    Veteran Member Four Rings wootek's Avatar
    Jan 10 2012
    Philadelphia, PA
    Sorry to hear about this whole thing. I have the exact same wheel in same finish, about couple weeks ago I scraped the hell out of my front passanger side on a curb and to me it was the whole world was coming to the end but to find out thanks to the rim guard it only scraped very little on the rim guard. I spoke to someone from BBS they said it cost about $58 or something I should order couple just to keep them handy.
    2010 A5 2.0T Ibis white | APR KO4 | RS5 Grille | BBS CI-R 20x10 DPE CS-16 20x10 (20" RS5 Rotor for winter) | H&R OE | Caractere spoiler | AWE Quad Exhaust | AWE Downpipe | AWE Boost Gauge | 2013 Refresh Tail lights | VAG-COM Mods | Rieger RS5 Style bumper | E-Codes | STaSIS Sway Bar | KMD Tuning Diverter Valve | Eurocode Goodies | Alu Kreuz | Rieger window spoiler | Brembo GT 6 Piston 380mm | BFI FMIC
    Sep 30 2009
    b
    Is there a cut in the tire to the upper right of the damage on the wheel?
    But I agree - BBS was thinking when they come up with this
    Aug 30 2010
    Houston TX
    ...it is, but lucky it wasnt a cut with any depth, it just right there on the surface, less than a mm deep, it just made a tiny flap...
    Oct 25 2007
    Scottsdale AZ
    Did you just call BBS directly to order the replacement? How long did it take? I've been trying to get a replacement for mine but everyone says it's back-ordered with no ETA. I haven't yet tried contacting BBS directly.
    16 Glacier S6 - Sport, Black Optic, Layered alum, Bloze
    13 Orca Black Q7 - TDI Prestige - S-line - S-line Plus - Air Suspension - B&O - Tech - Towing
    16 Nardo Gray RS7 - GONE
    11 Ibis S4 - Prestige - Titanium - Sport Diff - APR Stage 2+ - 35% Huber Optik - Black BBS CH-R 19x9.5 - KW SC coils - E-codes - RS6 Air Shifter - AK and USS sway-bars and end-links, GONE
    08 GMG S5 - GONE
    01 Casa S4 - GONE
    Sep 30 2009
    b
    Quote Originally Posted by TheChef View Post
    good!
    Aug 05 2011
    LI, NY
    So sorry to hear of your unfortunate accident. But crap happens and lucky these wheels have those guards just for this reason.
    Actually your car and wheels were the inspiration for me getting my BBS CH-R's but in Bright Silver. I picked them up used but they look brand new with the exception of a small skuff on one tirm. Just have to get around to ordering one and replacing it. Didn't know they were held on with sticky tape.
    Have to also ask them if they have replacement valve stem covers, missing two. That and I can't wait till the tires that are on there now wear out as they're 255/35's and are very noisy tires. Going with the 275/30's like you have which give that little extra sidewall and beefier width.
    2019 RS5
    2013 Audi S5 Estoril Blue - SOLD
    Weekend Warriors - '97 Mitsubishi 3000GT VR4 / '96 Mitsubishi 3000GT VR4 Spyder
    Jan 10 2012
    Philadelphia, PA
    Quote Originally Posted by etvois View Post
    you can call them directly to speak with someone there and you can order it directly from them.
    http://www.bbs-usa.com/contact.cfm
    Senior Member Two Rings A42S4's Avatar
    Apr 09 2008
    BFE
    BBS FTW!
    2012 Phantom Black A5 | Premium Plus| St Pkg | Nav | B&O | Carbon Inlays | Adv Key | APR tuned | 20% tint
    Gone: 06 A4 ÜberS-Line/APR tuned/10% tint/19' BBS CK/HID Fogs 6K/Vag-Com/STaSIS exhaust/RS4 sway/Carbonio Intake/LED -licenseplate mod/CIM vent gauge/StopTech Stage II
    Aug 30 2010
    Houston TX
    I called BBS direct. In reading the back order issue, was that on the 19"? In my case with the 20", no issue.
    Aug 30 2010
    Houston TX
    Quote Originally Posted by oohnoo View Post
    They can supply the rim guard and valve caps- no issue. Good call on the 275s- love mine!!
    Enjoy them and thanks for the kind words!
    Jan 10 2012
    Philadelphia, PA
    I'm also on 255/35/20 is there any issue fitting 275/30's??
    Aug 30 2010
    Houston TX
    Quote Originally Posted by wootek View Post
    No issue. My CH-R is a 20x9 fitment on 275/30/20 Michelin Pilot Super Sport tires. I am also running a 5mm BBS spacer on the rears.
    I am on H&R coilovers with a one finger gap rear and 1/2 finger in the front.
    Oct 08 2010
    CA
    Awesome! Glad you benefited from their innovation! Close one!
    Previous
    2009 GT-R | 700HP
    2008 S5 | Ibis White
    2008 A5 | Matte Gray
    Aug 05 2011
    LI, NY
    You sure you're only running 5mm spacers and not 15mm? When looking at mine with no spacers right now they are way inboard compared to yours and the difference look way more than the 5mm. The guy that I bought mine from had 15mm spacers and from the pics he sent me look more in line with what you have.
    2019 RS5
    Aug 05 2011
    LI, NY
    If it's not to much trouble can I get a ride height for me, from ground to top of fender well. I also got a set of H&R coiloever's that I need to install and your ride stance is perfect, especially with the BBS wheels :)
    Also are you running any adjustable control arms up front? If not you have any issues with tire wear?
    2019 RS5
    Aug 30 2010
    Houston TX
    ...before my BBS with the stock wheels and 255 tires I was running 20mm Front an 25mm rear H&R DRA spacers.
    Now I have just a 5mm spacer on the rear.
    I am not running any special control arms- I am not seeing any abnormal camber wear or anything. In fact they are wearing very well and even.
    Wheel measurements from ground to top of the fender- Front: just shy of 26 1/4". Rear: 26".
    I am also running H & R front and rear sway bars.
    Jan 10 2012
    Philadelphia, PA
    I'm running 15mm front and 20mm rear on my setup and I think it looks good.
    Aug 30 2010
    Houston TX
    20/25 looked great when I had a 19x8.5 higher ET wheel with 255 tires. Can't do it now...would rub.
    Veteran Member Three Rings B45H1R's Avatar
    Apr 15 2008
    Cozy Coupe (Beeyach)
    Houston, TX
    Houston roads suck. Seriously. Bunch of poorly maintained roads or pickups with things falling out.
    Things I've actually seen on the road (literally in the middle of a highway):
    1. Couch
    2. Mattress
    3. lots of 2x4's
    4. an airconditioner
    5. multiple bags of concrete
    6. a roll of sod so big it took up 2 1/2 lanes of a 3 lane highway
    7. a dead body...i thought it was a mannequin, but when i got home and checked the news...NOPE, real dead guy on 45.
    Feb 04 2010
    Jeddah, Saudi Arabia
    thats great!
    Instagram: @TheDapperDriver
    Aug 05 2011
    LI, NY
    Wondering if your BBS wheels have a different ET than ours. Remember what it is? Think mine are 32mm. I get confused with ET and offset. Either that or the 275/30 tires are the reason.
    2019 RS5
    Aug 30 2010
    Houston TX
    The BBS CH-R is ET32 I believe. The OE S5 wheel is ET43 I think. Not sure on an A5 wheel.
    Jun 21 2008
    NYC | ATX
    Hey chef, do you think it would be possible to run the rim guards on non BBS wheels?
    Aug 30 2010
    Houston TX
    Quote Originally Posted by NYSpeedRacer View Post
    Unfortunatly, no. As I mentioned in the original post and can be seen in the 3rd picture...for the rim guard to properly adhere itself to the wheel, it fits on top of a very small raised "plateau" lip (my words, not BBS') - the back of the stainless rim guard is hollow, with a gel type adhesive covered by double sided tape about 4-5mm deep within. Once you remove the tape, this allows you to perfectly lay the concave backing of the rim guard on to the specific raised portion around the permeter of the wheel - in other word, the wheel and rim guard are specifically desigened to work in unison.
    This technology and design is patended by BBS. Will some other aftermarket companies out there try to develop a guard with a flat bottom that you can apply to other manufacturers wheels? Not sure. Its a great design, and immitation is the most sincere form of flattery - so I am sure they will try. However, with out any specific new design element/idea not sure how long it would last in court against the copyright if BBS was to pursue.
    Dec 20 2011
    MD
    hmmm interesting
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    I just had the same amazing result....road rash on there rear passenger.
    Called the my guy to set a wheel repair before pulling off the wheel guard....called him right back and cancelled.
    $100 for the replacement strip though but sure saved the wheel.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Senior Member Three Rings Marshall_Placid's Avatar
    Aug 11 2012
    2013 RS5, 2012 A6, 2010 Q5 (SOLD!)
    Vancouver, BC
    Nice topic Chef.
    I have a question.
    I have BBS CX-Rs.... not CH-Rs.
    One of the wheels have a long 3 inch gash on it.
    Do you think the lip guard can fit on the 20'' CX-Rs? And, would it hide the gash?
    Thank you!
    Of course, I'll contact BBS as well.
    2013 RS5 - Misano Red - 20'' x 10'' BBS CX-R w/ 275/30 P-Zero Run-flats, B & O, Driver Assist, Navigation
    2012 A6 3.0T - Ibis White - S-line - 20'' x 9'' Stock 7 Rotor Wheels, P-Zero, Bose, Driver Assist, Navigation
    Apr 18 2011
    NoVA
    Any chance they will color match the rim guard to the wheel? I really want to pick up a set of Satin Black CH-Rs, and while I love the idea of the rim guard, the fact that it is chrome kinda turns me off.
    '12 Audi A5 Prestige S-Line | Ibis White | TI Sport Package | 6MT
    APR Stage 1 | AWE Dual Outlet Exhaust | H&R Coilovers | Eurocode Meisterwerk ASTS | H&R Spacers (15mm Front / 20mm Rear) | 35% Tint
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Old thread but I just bought a couple of these. Called TireRack first since i bought the wheels from them, they didn't have them but looked into them and called me back within an hour - $54. ea. Figured I'd call BBS in GA just to see how much TireRack was gouging me...$54. direct from BBS too! Kudos to TireRack and these guards are awesome, so easy to change out and looks perfect afterwards.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by LeadToRome View Post
    Great feature for sure. I've pulled them from two sets actually.
