Originally Posted by
cosworthsti
I have to ask and I'm not being an idiot about this but why do RS4s have such trouble making power with the SC kits? I haven't seen one kit break 600whp. Let me give you an example. My SL55 right now has a pulley, ec tune, he, ic pump, intake, headers and is making 562whp and 612wtq on the dyno. Remember these are wheel figures. Now all this cost me under $5000. yes the 5.4 in the SL is larger than the 4.2 in the RS4 however I'm running a stock blower which while efficient is quite small. Now I could, on the stock blower, make over 630whp if I add cooling, ported heads, injectors and fuel rail and all this with a 1.85l blower. Why aren't there any SVT Cobra style whipples for the RS4 like a 4.0, those guys are pushing 700whp and their engines are 4.6s. I love the RS4 but even with the top SC kit right now its way underpowered and its a shame since with the awd it would be a beast if it pushed 700whp or more. If im wrong then correct me as maybe I dont know about all the kit that exist. by the way im on stock internals in my sl as are most 55k tuned cars since our internals are very very sturdy so i assume the rs4s are too since its a quality brand.
i could see a good kit being a 4.7 stroker, massive top mount whipple style SC with integrated cooling and looped fuel rail and from there you would take care of the internals of course etc etc but it would surely make alot of power.
Couple things from what I understand.
1. There is not much room to put a blower, apparently AMD has a TVS2300 in the works, so perhaps that can do enough power, but I am not sure you would be able to fit enough cooling under the hood to max the blower.
2. You are likely going to be limited by the fuel injectors/pumps at that point. This is a direct injection motor, so there isn't really a easy upgrade to be had. Perhaps you could run auxiliary injectors in the manifold, but that would be pretty damn excessive.
3. Stroker kit probably isn't possible on this motor, it is already such high piston speeds, that a stroker kit would cause major problems, you can't bore it out, because you have about 5mm between cylinders.
This isn't the car to try and make big power out of. Respect it for what it is, it's a high revving, lightweight, small displacement V8, not some big Chevy or Ford motor that revs to 6200rpm. There is something special about the car, the motor, and the feel of 8300RPM. Not to mention, the car was designed for road course type handling, not high HP drag. 700WHP is more than anybody would need in a car like this, even 500whp is likely more than needed.
With boltons, you can get to about 370whp, with a blower, likely 550whp, maybe more. Nobody has maxed one of these motors yet as far as I know. I guess in my opinion, trying to make 700whp out of this car is stupid. It won't be reliable, will cost a ton, and will defeat the point. If somebody wants to do it, I will be quite impressed.
