I'm sure I'm not the first person to install a fiberglass kit on my car so hopefully someone out there can help me out. I've tried the searches and theres nothing specific to my application, yes I know there is more work involved in getting the kits to fit compared to OEM body panels but I thought I would give it a try.
I bought the Duraflex AG-S 4 piece (front and rear bumpers + side skirts) bodykit off eBay. I am going to be completely repainting my car, so I thought I might as well get a whole new bodykit.
Here are the goodies:
I'm no bodyman, but I do know how to tweak the bumpers and stuff to try to get everything lined up as best as I can. I was outside today test fitting the front bumper and overall, its not too bad but I ran into a couple problems.
First, I started by removing the headlights and then followed with the whole front bumper. I then went on to seperate the rebar, which I want to re-use eventhough many people with aftermarket/fiberglass bumpers tent to remove, from the OEM bumper. There were several rivets, both aluminum and plastic, that had to be popped out in order to get them seperated. I put the re-bar back on and then test fitted the bumper on. It looked terrible...so after I took a few more brackets off the re-bar (for more clearance), it fit a bit better. It seems like I just can't get the bumper raised high enough to close the gap between the bumper and headlights/front grill. There's atleast an 1" of gap and eventhough I maxed out the stock bumper height adjustment. The only thing I can think of is to trim the re-bar which I am not a big fan of. I was thinking of using some expanding foam ontop of the re-bar and then shave it down so when I slide the bumper over the re-bar it will be kind of "stretched open" causing it to close up the gap. Another problem is that it is going to be very difficult to mount the bumper on the sides because the lip to mount screws through is quite small and I am afriad it might crack and break off if i was to try to drill it through.
Here are some pics of whats going on: (I havn't washed my car in a very long time so don't mind the mess and headlights are taped in place just for fitment...it's a work in progress)
As you can see there is quite the gap...I did notice that on the duraflex pictures for the bodykit the front bumper pretty much sits almost in the same place on their demo car. So is this actually how it's supposed to fit?
So if anyone has gone through something like this and can give me some points/direction that would be great! Thanks in advance.
