Results 1 to 12 of 12
    Veteran Member Three Rings A4B7Quattro's Avatar
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    No power going to OBDII Port HELP PLEASE
    Hey guys,
    I went to get my emissions test done today at a small shop near my house and they said when they tried to connect their OBDII cord it does not register because there is no power going to the port, I also tried my cord with no luck. Has anyone else had this issue before? I spoke with my dealer and he said that he was not sure what it was and couldn't give me any ideas of what it could be without looking at the car. Has anyone had a similar issue and fixed it or has any idea what needs to be done to fix it? I would like to know what I am in for when I go to the dealer I would hate to have to pay the $200 dollar diagnosing fee and them come back to me and say its gonna be 4 grand to fix it lol.
    Thanks any input is appreciated!
    Veteran Member Three Rings ABreeden's Avatar
    Dec 20 2011
    Spokane WA
    It's probably a fuse. Pop the cover on the left side of the dash, and on the inside of that cover there is a diagram and I beleive it may be fuse #12 if I remember correctly. Hope this helps.
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Agreed on it probably being the DLC fuse
    New Build, 2010 Tiguan. Details to com
    Oct 14 2009
    Okinawa Japan
    X4 on the fuse...
    Ussually the cig Lighter is
    On the same fuse. But it easy enough to pull off the panel and do
    A
    Visual check with a flashlight
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    Thanks ill go check it now!
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    Looks like its not the fuse, fuse 12 is not blown it looks perfect
    Dec 20 2011
    Spokane WA
    Here's a pinout. Check to see that you have power and ground I guess.
    Sep 06 2011
    Harrisburg, Pa
    Do you have an aftermarket radio? or an ABS problem? I've seen both things take down the diagnostic data bus.
    Apr 04 2012
    gloucester ma
    got the same problem with my TT no communication failed emissions radio don't work cluster gauges freak out off and on.Was told to pull the radio fuse in the back maybe blown it's tied into the OBD connector?
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    Quote Originally Posted by bman005 View Post
    After doing a bit of research i found out that I do have the stock audi RNS-E nav but it is not the same model number as the one that left the factory so the previous owner must have gotten a new stock nav for some reason. So What would be the Fix if the radio is the problem??
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    bump
    Senior Member Two Rings rings65's Avatar
    Jan 14 2008
    '06 A4 S-Line
    Wheaton/Winfield, IL
    I'm running into a similar issue - failed emissions inspection in Illinois due to them being unable to communicate with the ECU. My little scanner plugs in okay and shows no codes, but don't know if that means anything or not. I checked fuses and everything seems okay there, and I don't have an aftermarket radio. I do have a driver's side airbag light on (had a rider in the back seat who I think hit the wires with their feet) - wonder if that could cause the communication issue?
    MTM Stage 1 Tune/ECS Snub Mount/RS4 Rear Sway Bar/Debadged/Smoked Front Corner Markers
