Results 1 to 40 of 41
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    :: EuropaParts.com :: Ross-Tech's VCDS Vag-Com and Accessories
    If you own an Audi, Volkswagen, Seat, Skoda, or Bentley you need a powerful tool that will help keep your vehicle on the road. Ross-Tech VCDS® (VAG-COM Diagnostic Software) helps diagnose real problems instead of swapping out costly parts. With features found only on dealer level factory tools, VCDS surpasses the performance of aftermarket diagnostic tools and rivals factory tools for a fraction of the cost. Always know exactly how your vehicle is running instead of paying someone else to diagnose the problems, usually leaving you with a huge repair bill.
    WITH ROSS-TECH VCDS YOU CAN:
    • Gain factory level access to all systems in most VW, Audi, Seat, Skoda and Bentley models from 1990 through the current model year
    • Scan for and clear DTCs with 19,000+ fault codes decoded into plain text
    • Alter settings through module coding accessible only by factory level tools
    • Perform various country-specific modifications to your car (remove seat belt chime, enable gauge test/needle sweep, enable lap timer, operate windows and sunroof with remote, and much more)
    • View and log live data
    • Reset service reminder
    • Perform built in tests and calibrations normally reserved for factory level tools
    • Diagnose real failures instead of swapping parts!
    WHICH VAG-COM PRODUCT WILL WORK WITH MY CAR?
    VCDS HEX-NET Professional Kit - WiFi or USB connection, works on most models 1990-current, unlimited cars
    VCDS HEX-NET Professional - WiFi or USB connection, works on most models 1990-current, unlimited cars
    VCDS HEX-NET Enthusiast - WiFi or USB connection, works on most models 1990-current, limited to 10 cars
    VCDS HEX-V2 Enthusiast (USB, 10 VINs) - USB connection, works on most models 1990-current, limited to 10 cars
    VCDS HEX-V2 Enthusiast (USB, 3 VINs) - USB connection, works on most models 1990-current, limited to 3 cars
    THINGS YOU MUST HAVE TO RUN VCDS:
    • A computer with a USB port running Microsoft Windows (VCDS also works fine on Apple and Linux computers running Windows in a virtualized environment)
    • The Ross-Tech VCDS (VAG-COM Diagnostic Software) (free download from Ross-Tech)
    • Any of the Genuine Ross-Tech VCDS Interfaces sold below
    THINGS YOU MIGHT WANT WITH YOUR VCDS:
    • A copy of the VCDS manual to get you started (PDF format)
    • If you purchase a HEX-NET interface, a copy of the HEX-NET FAQ (HTML format)
    • An OBDII right angle extension cable if you want your diagnostic tool connected and away from the driver's feet and legs
    • A USB extension cable to extend the reach of a VCDS interface from the computer to the vehicle
    • For pre-1995 cars, a 2x2 adapter to connect between the 2x2 port in older vehicles to the OBDII connector used for current generation diagnostic tools
    • A Bentley repair manual which has a list of the diagnostic, troubleshooting codes and the recommended repair procedure
    • Europa Parts is an authorized stocking distributor of Genuine Ross-Tech VCDS (VAG-COM Diagnostic Systems) for Audi, Volkswagen, Seat, Skoda, and Bentley vehicles. Don't be fooled by cheap fakes, knock-offs and imitators as those can damage your car. This is the real deal, manufactured by the world's leading diagnostics solutions company.
    All of our Ross-Tech VCDS systems are always in stock and never drop-shipped. Order before 3pm ET and have it shipped the same day. Please contact us with ANY questions you might have about these widely acclaimed diagnostic systems. We'd be happy to help.
    Ross-Tech, VCDS, VCDS-Mobile, VCDS-Cloud and HEX-NET are registered trademarks of Ross-Tech, LLC, USA. Authorized use of these has been granted to Europa Parts LLC.
    FREE SAME DAY SHIPPING ON ALL ROSS TECH DIAGNOSTIC CABLES
    VCDS (VAG-COM) HEX-NET PROFESSIONAL KIT (WIFI/USB, UNLIMITED VINS)
    VCDS (VAG-COM) HEX-NET PROFESSIONAL (WIFI/USB, UNLIMITED VINS)
    VCDS (VAG-COM) HEX-NET ENTHUSIAST (WIFI/USB, 10 VINS)
    VCDS (VAG-COM) HEX-V2 ENTHUSIAST (USB, 10 VINS)
    VCDS (VAG-COM) HEX-V2 ENTHUSIAST (USB, 3 VINS)
    Senior Member Two Rings isleepsober's Avatar
    Dec 24 2007
    RIP 98 A4 1.8T Quattro
    PA
    are you offering zine special pricing on these?
    EX- BetaAlphaTau member #38
    Soon to be Stage II 01 Allroad 2.7t 6mt
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by isleepsober View Post
    Ross-Tech does not allow anyone to sell their product under retail.
    Veteran Member Three Rings Protection's Avatar
    Feb 24 2011
    Alfa Romeo Giulia Quadrifoglio, MK7 Golf R, B5 S4, B6 A4, B7 RS4
    Long Island NY
    Best $350 I ever spent. It paid for itself in the first year. No trip to the dealer was required to find out my speed sensor was bad. My dealer charges $100 just for a scan. Every VW Audi owner should have one of these.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Protection View Post
    I couldn't agree more. They SHOULD be included with the car at purchase.
    Nov 24 2012
    Anchorage, AK
    Newbie
    Did you buy one of the models advertised by the OP?
    Does it reset CEL?
    Does it do everything you need for the allroad?
    DO ANY OF THEM WORK ON A MAC?
    Thanks
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by ArcticRider View Post
    Yes... I am assuming the Hex Can at the price mentioned
    Does it reset CEL?
    Yes, it resets check engine lights and tells you what caused the check engine light.
    Yes, you can do mods and have access to the entire computer.
    You can run Vag-Com on a Mac using parallels or boot camp. CLICK HERE FOR MORE INFORMATION.
    Thanks
    Answered...
    Mar 03 2004
    Hi there,
    looking to get the diagnostic cable that is compatible for my 2014 A4 (B8) and my wife's 2011 VW Jetta TDI (Mk6) ... Canadian models (if it matters)
    just to confirm its the HEX-USB+Can for $349? is that correct??
    Also curious about shipping costs to Canada. Please PM me.
    Thanks
    EDIT:
    Nevermind.. I just did a fake order and did a request a shipping quote....
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by drx604 View Post
    Hi there,
    Thanks
    EDIT:
    Hello, yes the Hex-Can is the cable you would want, it works on almost every Audi/VW and will work on both of your vehicles.
    Aug 04 2009
    Glen Ellyn, IL
    It's high time I bought one of these instead of tracking down others that have one. Hugh, or anyone else, could you point me to where I can read up on some VCDS for beginners in plain English? I've fiddled with it a bit and been to the Ross Tech site, but it's all pretty foreign to me.
    I'll order one when I order my new spider hose next week from you guys.
    (p.s. thanks for the decals with my last order, I've been looking for something to put in my 3/4 windows)
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by 4rings2turbos View Post
    Are you looking to do mods on the C5?
    Aug 04 2009
    Glen Ellyn, IL
    Yes, I have two allroads that are 402'd. The suspension modules are the main reason I want to upgrade to a genuine cable. I can follow the step by step instructions for all the mods, but I would like a deeper understanding of the ins and outs.
    @fourings | Build
    Aug 22 2010
    Piscataway, NJ
    Shoot me an email at [email protected] and I'll see what I can dig up.
    Mar 03 2004
    Do you know where the cable is made? I should be receiving my vcds cable I ordered from you last week ... Getting it shipped to a US postal outlet and will be bringing back to Canada.. Just trying to see if I would have to pay customs duty on the item
    2014 A4 Technik / Phantom Black / S-Line / Black Optics
    Aug 22 2010
    Piscataway, NJ
    It looks like all Ross-Tech products are assembled in the US.
    Established Member Two Rings txtaco1's Avatar
    May 30 2014
    Dallas, TX
    Hugh,
    Thanks again for your help on my last order of "stuff"... I have one (probably dumb) question and I believe I've answered it on my own in looking over this.
    Does the vagcom cable and software only work on VW's/Audi's? I want a diagnostic tool, but have a Toyota also and hoped to buy one unit.
    It looks like this one is specific to just our cars?
    Thanks,
    Jason
    Jason
    06' A4 2.0T FWD - Currently no mods (wifey's ride)
    01' Toyota Tacoma - 6" lift, 35x12.5 BFG's, and multiple other mods (daily driver)
    10' Harley Dyna Street Bob - only mod is pipes so far (new to me)
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by txtaco1 View Post
    Hugh,
    Thanks,
    Jason
    Hey Jason... no problem glad everything worked out. This tool only works for Audi/VW as the coding was only done for those vehicle.
    Mar 17 2014
    Suffolk NY
    does this laptop HP ELITEBOOK 6930p Laptop INTEL CORE 2 DUO 2.53 GHZ 4 GIGS OF RAM. 14.1" Screen. Wireless LAN. Bluetooth. Webcam. 160 GIG HARD DRIVE. DVD/CDRW. WIN 7 PRO work with the VAG-COM DIAGNOSTIC TOOL WITH HEX-USB+CAN INTERFACE? thanks.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by ToneB View Post
    As long as it has windows, WiFi, and a USB port you're good to go.
    Mar 17 2014
    Suffolk NY
    Quote Originally Posted by Hugh@EuropaParts View Post
    Established Member Two Rings norcal22's Avatar
    Dec 05 2012
    Nor*Cal
    Can You clear a cel and force readiness for smog? I'm in ca
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by norcal22 View Post
    You can certainly clear codes however I am not too sure about the readiness...
    Nov 27 2013
    Boardman, Ohio
    I have the single tech Pro kit, but didn't buy the laptop (notebook). Can I order the laptop separately? I just want to keep this at my shop to work on my cars only.
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    Quote Originally Posted by waterguy View Post
    You can buy any Windows machine and use it.
    Sent from my HTC One_M8
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Aug 22 2010
    Piscataway, NJ
    Unfortunately we don't carry just the laptop.
    Quote Originally Posted by Andrew149 View Post
    This is correct... we use a netbook here at the shop.
    Nov 27 2013
    Boardman, Ohio
    Thanks. I just want to keep something at the shop so the kids don't use it and load it up with video games!
    Aug 22 2010
    Piscataway, NJ
    those angry birds are everywhere!
    Active Member Two Rings UV_Blue's Avatar
    Mar 29 2015
    '78 Camaro, '78 K20 P/U, '94 C3500 P/U
    Midvale, Utah
    @txtaco1 - vcds will run global obdII, so it can do a little bit on your Toyota...pretty much just read and clear codes, but it's something
    @norcal22 - yes vcds will run readiness monitors
    @everyone - BUY ONE! I use this tool EXCLUSIVELY in my shop on VW/Audi, there is no reason not to own a tool that is better than the factory tool (VAS 5051/5052) and is community supported (wiki)
    Black '01 Allroad 2.7T Auto with 193K - Forge 008's, Arnott Gen II front bags/shocks, Nokian enTYRE's on stock 7 spoke wheels. Torque converter stuck off code and sometimes my combi valves don't open, recently this killed my SAI pump from moisture (I'd like to delete SAI), I just keep clearing and driving until I can do a 6MT.
    ASE Certified Master Technician with 10 years experience, 3 years specializing in European vehicles.
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    What is the benefit of having the VCDS software on CD-Rom?
    Also I have a 2000 Audi A6 2.8L 30v Avant, is this all I would need to purchase?
    http://www.europaparts.com/vag-com-d...ross-tech.html
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Arsenal2012 View Post
    That is all that you would need... there is no benefit of having a CD-Rom as the software is automatically downloaded and updated from the cable.
    Aug 20 2015
    Chicago
    Is there a list of changes/modifications that you can do with the vag-com?
    Like I read you can setup the windows to open with the unlock button
    and you can set the floor lights to come on when you turn on the headlights.
    Is there a list of things you can modify, just looking for the list not the how toos at this point.
    Aug 22 2010
    Piscataway, NJ
    You can either check Ross Techs site directly or do a quick google search with your car specs to find a full list of mods that can be done with the software.
    Junior Member Two Rings
    Sep 05 2015
    Boerne, TX
    I own a older C5 RS6 and want the wireless version but its hard to cough up 400 beans.
    Apr 03 2016
    Audi A6, Lexus GS300, Nissan Xterra
    Clarkston WA
    Will this scan tool work with other OBII vehicles? Specifically, I have an 05 Nissan that I would like to run diagnostics on also.
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by MrOzzie5183 View Post
    Unfortunately these will only work for vw/audi.
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    This is a must have essential for any Audi/VW enthusiast. I can't tell you the amount of time and aggravation VCDS has saved me (plus the cool little tweaks you can enable with it).
    EuropaParts is a solid vendor too and you can't beat the free shipping, so go ahead and pick one up.
    Current: 16 VW Tiguan R-Line, 15 VW GTI PP, 14 Audi S4
    Retired: 12 VW GTI, 10 Audi S4, 08 VW Jetta Wolfsburg, 04 VW Jetta, 04 Audi allroad 4.2, 03 Audi A4 3.0
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by A4_n00b View Post
    Thank you for the kind words... I actually had a CEL come on my car on Sunday. Got home, scanned the car and realized it was something small... cleared the code and it never came back. That alone is worth not having to go to a shop or dealership to find out what's wrong... literally done in 5 minutes while drinking a cold one.
    Aug 22 2010
    Piscataway, NJ
    All Hex Net Ross Tech Diagnostic tools qualify for FREE SHIPPING AND A FREE GIFT!
    Once you add a Hex Net Diagnostic Tool you can add a FREE GIFT to your order, the amount of the FREE GIFT should be deducted in your cart. (If the item is NOT deducted, it does not qualify).
    Please view the individual product's description for details. Limit of one (1) free offer per order. Cannot be combined with any other promotion.
    For instance,
    will qualify for the following free gifts, ON TOP of FREE SHIPPING!
    NEBO LARRY C LED WORK LIGHT
    By Nebo Tools
    The Larry is now BRIGHTER THAN EVER! Now, equipped with new COB LED technology, the LarryC outputs 170 lumens of intense light. The rotating magnetic clip gives you convenient hands-free lighting by attaching to virtually anything. The reinforced plastic body design is water and impact-resistant, making this light basically indestructible.
    LIGHT
    • High-power 170 lumen COB LED work light
    DESIGN
    • Water and impact-resistant
    • Ergonomic non-slip grip
    • 180º rotating magnetic clip
    • Protective LED housing
    OPERATION
    • Top-positioned, ON/OFF button
    BATTERIES
    • Powered by 3 AAA batteries (included)
    SPECS
    • Size:(H) 6.375” x (W) 0.55” x (D) 1.25”
    • 0.1870 lbs.
    NEBO WORKBRITE WORK LIGHT
    By Nebo Tools
    The NEBO WORKBRITE adapts to your work environment, making it the handiest of work lights. The WORKBRITE features three different ways to provide you with hands-free lighting for the task at hand: a hanging hook, a 200º pivoting stand and a magnetic base. Aside from being handy, the WORKBRITE is... well, BRIGHT! 200 lumens of pure white light are outputted by the 20 LED face, and for standard flashlight use, another 6 LEDs are located in the head, providing 60 lumens of brightness.
    For handheld use, the WORKBRITE features an ergonomic, non-slip grip. For added durability, the body is also completely impact and water-resistant. Whether you are under the hood, under the sink, or just out in the dark, the WORKBRITE works great for any application. WORKBRITE... It stands! It hooks! It sticks! It lights! It WORKS!
    FEATURES
    • 20 LEDs (face) provide 200 lumens of white light
    • Bulbs rated for 110,000+ hours of life
    • 6 LEDs (head) provide 60 lumens of white light
    • 60 meters viewing distance with 200 lumen setting
    • Three convenient hands-free lighting options: hanging hook, 200º pivoting stand & a magnetic base
    • Impact-resistant / Water-resistant
    SPECIFICATIONS
    • Settings – 6 LEDs - 60 lumens / 20 LEDs - 260 lumens
    • Run Time – 6 LEDs - 40 hours of continuous illumination / 20 LEDs - 15 hours of continuous illumination
    • Size – 9.125" (H) x 1.75" (W) x 1" (D)
    • Weight – 0.3 lbs
    • Batteries – 4 AAA Batteries (Included)
    NEBO 14-IN-1 ULTRA SOCKET
    By Nebo Tools
    The NEBO 14-in-1 Ultra Socket comes with 7 screwdriver bits and 5 sockets conveniently stored inside the handle. The head of the Ultra Socket tilts a full 180º and locks at 0°, 45°, and 90°, working perfectly as a nut driver for those hard to reach places. The handle is ergonomically designed to add comfort and grip to improve performance. The Ultra Socket features a reversible ratchet mechanism making it easier to loosen or tighten any bolt. The 14-in-1 Ultra Socket meets and exceeds ANSI standards and is created to withstand more than the normal wear and tear.
    DESIGN
    • Head tilts and locks at 0º, 45º & 90º
    • Reversible ratchet mechanism
    • Ergonomic reinforced plastic handle
    • Socket adapter
    • Sockets and bits stored inside handle
    SOCKETS
    • SAE: 1/4”, 9/32”, 5/16”, 11/32”, 3/8” & Socket adapter
    BITS
    • Phillips: P1-P3, Slotted: 3/16” & 1/4”, Torx: T15 & T20
    SPECS
    • 8.25” (L) x 1.5” (W)
    • 0.75 lbs.
    NEBO ULTRA SOCKET COMBINATION KIT
    By Nebo Tools
    The NEBO Ultra Socket Combination Kit comes with 19 sockets conveniently stored in SAE and Metric trays. The base of the Ultra Socket unscrews to reveal the stored screwdriver bits and magnetic ¼" bit holder. The head of the Ultra Socket tilts and locks at 0°, 45°, and 90°, working perfectly as a nut driver for those hard to reach places. The industrial strength ergonomic rubber handle design adds comfort and grip to improve performance. The Ultra Socket features a reversible ratchet mechanism making it easier to loosen or tighten any bolt. The NEBO Ultra Socket meets and exceeds ANSI standards and is created to withstand more than the normal wear and tear. Ultra Socket and components are all conveniently stored in a 600D Polyester carrying pouch. View Ultra Socket Combination Kit Brochure
    SOCKET SIZES
    • SAE: 1/4", 5/16", 11/32", 3/8", 7/16", 1/2", and 9/16"
    • Metric: 6mm, 8mm, 9mm, 10mm, 11mm, 13mm, and 14mm
    SCREWDRIVER BITS
    • Phillips: P1-P3
    • Slotted: 1/8", 3/16", ¼"
    • Hex: 1/8", 5/32", 7/32"
    • TORX: T15, T20, T25
    • Magnetic 1/4" bit holder
    FEATURES
    • Comes with 19 sockets, 12 screwdriver bits and ¼" magnetic bit adapter
    • Head tilts and locks at 0°, 45°, and 90°
    • Industrial strength ergonomic handle design
    • Exceeds ANSI standards
    • 600D Polyester carrying pouch
    SPECIFICATIONS
    • Length – 8"
    • Diameter – 1.375"
    • Weight – 1.6 lbs
    NEBO DUO 250+ LUMEN HEADLAMP
    By Nebo Tools
    The NEBO DUO Headlamp is an all-powerful, hands-free lighting solution. The push button on/off button allows you to easily cycle through the FOUR light modes: one white LED (250 Lumens), 2 COB strips (80 Lumens) or 2 RED COB strips in steady or beacon mode. The red LED is a low-signature light, which ensures stealth in the dark, enhances night vision and makes reading in little to no light possible. The light from the 250-lumen power LED has a spot beam distance of 122 meters. Its signature 2 strip COB design fully illuminates your immediate area with its wide flood beam. The DUO Headlamp is tough, reliable, lightweight and completely shock-proof.
    LIGHT
    • High-power 250 lumen LED spot light
    • 80 lumen COB flood light
    • Red 10 lumen COB flood light
    • Red beacon light
    LIGHT MODES
    • Spot Light (250 lumens) - 3.5 hours / 122 meters
    • COB Flood Light (80 lumens) - 7 hours / 13 meters
    • Red COB (10 lumens) - 8 hours / 4 meters
    • Red beacon light - 48 hours / visible over 1 mile
    DESIGN
    • Fully dimmable
    • Water and impact-resistant durable housing
    • Power memory setting
    • Direct-to-red feature
    OPERATION
    ACCESSORIES
    • Dual adjustable head strap
    BATTERIES
    SPECS
    • 0.2 lbs.
    • One size fits all
    will qualify for all of the gifts above, and the following... ON TOP of FREE SHIPPING!
    NEBO SLYDE
    By Nebo Tools
    Combining the best that NEBO has to offer, the SLYDE features a powerful LED flashlight and COB work light all in one. At first glance, the SLYDE appears to be a simple, strong flashlight, emitting 250 lumens of intense white light... and it is! However, you will see the SLYDE is much more. The body of the SLYDE conceals a powerful 190 lumen work light. To reveal the COB work light, just SLYDE to open!
    LIGHT
    • High-power 250 lumen LED flashlight
    • High-power 190 lumen COB work light
    LIGHT MODES
    • Flashlight: 250 Lumens - 2 Hours / 230 Meters
    • Work Light: 190 Lumens - 3.5 Hours / 18.5 Meters
    DESIGN
    • Anodized aircraft-grade aluminum; water and impact-resistant
    • Work light is concealed inside the flashlight body; just SLYDE to reveal
    • Powerful magnetic base
    OPERATION
    • Side-positioned ON/OFF button with Soft Touch Technology
    BATTERIES
    • Powered by 4 AAA batteries (included)
    SPECS
    • Length: 6.5” (compacted) / 9” (extended)
    • Diameter: Barrel – 1.3125” / Head – 1.625”
    U.S. PATENT PENDING
    NEBO TEMPRA IR THERMOMETER & SPOT LIGHT
    By Nebo Tools
    Not just for the professional, the TEMPRA can help save time and money at work, around the house or in the car. Use the laser-guided infrared thermometer to make sure your car engine is firing on all cylinders. Check your HVAC to ensure your home is cooling and heating efficiently. The TEMPRA, just one more way NEBO helps get the job done.
    LIGHT
    • High-power 1340 LUX LED spot light
    LASER
    • Red laser guide for accurate temperature scanning
    TEMPERATURE RANGE
    • -4ºF - 716ºF
    DESIGN
    • 4x adjustable zoom
    • Infrared lens
    • Laser pointer
    • Backlit LCD
    • Adjustable emissivity for different surface materials
    • Fahrenheit/Celsius conversion
    • Ergonomic handle
    • Low battery indicator
    • Data hold function
    OPERATION
    • Back-positioned ON/OFF button for spot light
    • Trigger for laser and temperature scan
    BATTERIES
    • Powered by 4 AA batteries (included)
    SPECS
    • 0.7 lbs.
    • (H) 7.625” x (W) 2” x (D) 4.25”
    Aug 22 2010
    Piscataway, NJ
    The perfect Holiday gift...
    Aug 22 2010
    Piscataway, NJ
