Results 1 to 11 of 11
    Sep 14 2006
    Cone seat nuts on ball seat wheel
    I know that using a ball seat nut on a cone seat wheel is not recommended because it doesn't make proper contact.
    During my search for some 12x1.5 ball seat r13 nuts, a reputable company informed me: I have cone seat nuts which can work with ball seat style sockets **** it just doesn't work well the OTHER way around. (Cone socket and ball nut)
    Is this true? If it's correct, it still doesn't make sense to me. What do you guys think?
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Jun 14 2005
    Anaheim, CA
    I would not put cone seat lug lugs on ball seat wheels, or vice versa. You will not get a good amount of contact with either setup. Ball seat lugs for ball seat wheels, tapered seat lugs for tapered seat wheels.
    There are washers though that can 'convert' one bolt/nut style to the other.
    Brandon @ VMR Wheels
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Quote Originally Posted by VMRWheels View Post
    I had no idea...go figure. Kind of a head slap moment. :) I wonder if these would exist for the fellow hoping to run R12 lug nuts on OEM wheels?
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Oct 02 2006
    Wadsworth,OH
    +1 on what VMR said. Always use the correct style lugs! Not worth the risk of them backing out and loosing a wheel!
    Jason
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by VroomVroom View Post
    http://www.prestigewheel.com/Image5481.asp#Conversion Washer
    http://vwparts.aircooled.net/Ball-Se...ion-washer.htm
    There might be some that exist like you're describing though!
    Jason
    Sep 14 2006
    What about using R12 ball seat nuts on an OEM wheel?
    -Thomas
    Current: /S3
    Jun 14 2005
    Anaheim, CA
    To my knowledge, R12 should work.
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    Little bit off topic, do any of you know what lugs should i use for Rotiform? cone or ball seat?
    I looked at the wheels closely, it seems like it needs cone but people told me i should use ball.
    I need to confirm since i am going to longer lugs and want to get the right ones.
    IG:@steadysupreme
    Pics&Detail
    Jun 14 2005
    Anaheim, CA
    You should contact Rotiform and double check. Wouldn't want the wrong lugs, otherwise your wheels could come off!
    Active Member Two Rings Zathrax's Avatar
    Jan 15 2012
    Sogndal / Norway
    From my supplyer in norway I got cone lugs, but my mechanic is sure its ball seat lugs, and the inside felt realy round, so i went with ball seat- driven around 1000km now and all good, is it then a problem? tightened around 130nm with a torquewrench..
    Edit: Read two seperate threads and both different answers... so wondering :D
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Don't do it. OEM is R13 or 26mm ball. R12 is 2mm smaller diameter and makes poor contact on an OEM wheel.
