Results 1 to 26 of 26
    Account Terminated Four Rings
    Feb 16 2009
    Ithaca New York
    Misfire under load detected today.
    00 S4 GIAC 93 TIP
    While doing some friendly pulls with my buddies B7 A4 and some random S4 that spotted us today on the highway my cars CEL started blinking and i noticed that car started bogging between shifts. I pulled over and restarted the car. CEL stopped blinking and we went driving.
    No issues between 5-13psi but as soon as car does 13-20psi thats when it starts misfiring and hesitating. If felt like as if car was choking.
    I have new plugs with .28 gap and im pretty sure i have no boost leak since my gauge reads full 20psi. Could it be that my DVs need a stronger spring? I will put red one in tomorrow and see if that changes anything. Also afteri scanning for coded i got knock sensor code and P0303 <**** IIRC (misfires in bank 3). Will swap coils tomorrow as well and see if problem follows.
    Other then what I listed what else can cause this issue?
    Clogged cat?
    MAF?
    O2?
    Any help would be appreciated.
    Thanks
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    IIRC Blinking CEL = bad coil(s)
    At least in my 02 1.8t that's what it meant.
    Haven't had any issue's in my S with my coils.. knock on wood.
    2017 Audi S3//Navarra Blue//Black Optic//SuperSports//Tech//Dynamic//B&O//Injen Evo CAI//CTS Inlet//APR Coils
    May 20 2004
    More cars
    Never Land Ranch
    I almost bought a stage 3 car that had a similar issue of getting into boost it would bogg and cel would flash. Let of the gas and drive normal and cel would go away.
    Sorry my post is no help, the guy I was gunna buy it from wouldn't let my shop find out the issue...
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Feb 16 2009
    Ithaca New York
    Yeah these issues can be as simple as coils and as PITA as injectors and valve cover seals from what i heard. I have a $100 gift card from advanced auto so hoping its coil lol
    May 13 2011
    2015 BMW F30
    I agree with your guesses.
    Veteran Member Four Rings RedB5S4's Avatar
    Dec 06 2010
    BfiveSfour
    I'd like to keep my car.
    My bet would be plugs or coils. What kind of plugs are you running and how 'new' are they? Ideally, they should be replaced every 10-15k miles on tuned cars. Your gap sounds fine, although you could probably go down to even .025 if you wanted to. Report back once you've swapped coils because then it should be pretty obvious where your problem is.
    Stg. III+ K24 CaS4
    Jan 09 2009
    FL
    swap icm to see if it follows the other bank, besides that replace coils.
    Feb 16 2009
    Ithaca New York
    Both ICM were replaced less then 20k ago.
    Plugs are ACDelco Copper or Irridium I cant remember now. I wanted Bosch sidefire ones but they didnt have them. So i went with pregapped ones.
    Im about to go out and replace SAP so while at it i will swap coil and take out plug to see what it looks like
    These are the ones i took out to swap few months back and i know i didnt gap them but they looked like they are touching. Can plugs to that ? 0_o
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    that does NOT look good. I can tell from your pic that those are not gapped right. even at .028 there is a discernable gap.
    those look distorted and crushed, the ground strap should not be squished like that. looks like those had way too wide of a gap to begin with and they got smashed.
    re-gap your plugs using feeler gauges or a wire gap gauge.
    and those plugs look to be in good shape, other than being mangled. you changed them?
    what did you gap your new plugs to?
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    My wife complains about misfire under load from me as well.
    -Darrick
    Feb 16 2009
    Ithaca New York
    New plugs came gapped at .28 i checked with a tool to make sure.
    My question tho if i didnt gap previous plugs why are they so crushed?
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    no clue how those denso plugs got smashed. those were pk20tt's correct? they would have came pre-gapped at .032 i think, the car ran with those in it?
    the delcos come pre-gapped at .028 which is nice for chipped cars.
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Quote Originally Posted by Capt. Obvious View Post
    LOL!
    Feb 16 2009
    Ithaca New York
    Little update... I replaced both ICMs and reset the CEL. Drove a little until engine warmed up and then pressed on the pedal. After 10psi my whole car shakes still and will not accelerate. Car idles good no issues with it. I unplugged MAF to see if car dies or not. Car hesitated for a second and then stabilized. I drove with unplugged MAF and same thing would happen. CEL came one with P0102 since MAF was unplugged. As I mentioned before plugs were replaced about 1k ago and coils were functioning 100%. I have not gotten blinking CEL yet and no misfire codes yet. Not really sure what to look for anymore. Will scan it with VAG on tuesday but meanwhile want to see what you all think. Bad EGT? MAF?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    This may sound odd but check your map. They rarely go out, but my rs4 map shit the bed a month ago. Would hesitate under load bad.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Feb 16 2009
    Ithaca New York
    How do you check if MAP good or bad?
    Feb 23 2010
    Emmaus Pa
    you can log to see what pressure its reading, or swap it out with someone else's. If you just unplug it you will most likely go into limp mode and your car will run extremely choppy
    B9 S4- EPL/AWE
    Feb 16 2009
    Ithaca New York
    When my car kicks into limp mode and stays only at 5psi everything is good. Car accelerates well and no bogging but it wont go past 5psi
    Feb 23 2010
    Emmaus Pa
    Well were you in limp mode after this happened? If you went into limp mode a year ago and it ran fine, that doesn't mean anything considering this is a new problem. What if any codes are you throwing? EGTs will cause hesitation, but if the whole car shakes that sounds like a misfire, a/f problem.
    B9 S4- EPL/AWE
    Feb 16 2009
    Ithaca New York
    I guess ill wait til scan on tuesday and upload logs and scan resulta
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by 00SantorinS4 View Post
    It means misfire
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Feb 16 2009
    Ithaca New York
    I think i figured out what might be causing the issue. I got P1127 and P1129 codes today meaning MAF finally kicked the bucket. Idles poorly now. Car idles fine then jerks down 200-300 RPM then back to normal every 15-30 seconds.
    Feb 16 2009
    Ithaca New York
    Finally got my issues fixed today. It had bad coild #3 and #1 was in its way out so i replaced both. Car runs like new again. Did some pulls tonight and it performed great. 19spike 15-16 hold
    Senior Member Three Rings epyx's Avatar
    Jul 08 2008
    B5
    Salisbury, MD
    Thanks for posting an update. Still chasing down similar daemons in my S.
    Feb 16 2009
    Ithaca New York
    Quote Originally Posted by epyx View Post
    My issue was that coil was not bad but going bad and it wouldnt trigger CEL unless i was stomping on it. As day went car started running worse and worse until yesterday I almost stalled with overheated cats. I remember pulling P0303 and P0301 codes basically meaning that my cylinder 1 and 3 were misfiring. I replaced ICMs because 1 and 3 are located on the same bank thinking that would fix the issue but it didnt. Tried swapping MAF but that didnt work ether so then i went and replaced 3 and 1 coils which took care of it. I will be replacing rest 4 coils pretty soon just to get that out of the way.
    I went completely backwards in troubleshooting process but at the end i found out the issue.
    Whats going on with your car?
    Feb 24 2007
    Nicosia,Cyprus
    +1
