Had to revive this thread to get answers from you guys with experience with this.
So my A/C compressor on my 02 b6 1.8t is shot - not the compressor itself but the pulley and bearing (died at the end of fall, and I've been running a shorter accessory belt to bypass it all winter). I checked my ac expansion device and it's 100% clear and clean, so I know my compressor didnt' grenade itself, and my condensor/evaporator and lines should be clear.
I'm planning on ordering the
compressor kit from discountacparts.com which comes with a new compressor, dryer, expansion device, o-rings and pag oil for $335 shipped.
I was planning on doing all the work myself, but looking at their
warranty, they expect an ac flush. Fine, but I don't have any A/C repair equipment so I'd have to spend another $35 on the flush kit (canister with blow gun) + another $35 for the duraflush. Then I'd have to rent the vacuum pump from autozone, as well as the manifold guages. If they don't rent them I'd have to spend about another $200 at harbor freight. And I've also read that the r134 DIY cans from the auto parts stores/walmart can introduce moisture into the lines, so I'm worried going that route.
Now I'm considering doing the install myself but then taking it to a A/C shop to have them do the flush, vaccuum then re-charge. If I go this route, would it be OK to mount the new AC compressor with the correct amount of oil poured into it, and keep the AC lines to it disconnected (keep the protective caps on) and drive it to the shop (AC would be turned off of course)? I'd plan on driving there with the passenger headlight off so the drier is easy to reach and they can flush the lines, condensor and evaporator, then connect the new drier, new expansion device, connect the AC lines to the compressor, then perform the vacuum and finally the recharge.
Would that be the way to go? In other words, since the pulley drives the compressor all the time, is it safe to drive it as long as there's the correct amount of oil in the compressor? Or does the oil need to mix with the refrigerant for proper lubrication of the compressor? Am I better off driving to the shop with the compressor pulley bypassed and just swap out to the correct accessory belt when I get there?
