Please post up MPG figures instead of miles per tank. Miles/Km per tank isn't really helpful in comparing anything. No one drives their car until they run out of gas, so this figure is not accurate.
Here are my actuals:
2011 Audi A4 quattro sedan
6 speed manual transmission
Current mileage: 10k
Average of 27.7 miles per gallon or 44.5 km/gallon. (1 US gallon = 3.8 liters)
This data was compiled from my last 11 fill-ups. This was from a combination of city and highway driving. I expect this figure to decrease as the weather gets warmer and I start using the A/C more. The past 11 fill-ups were during the fall/winter months. I would classify my driving style as conservative.
In comparison, my last car (2002 VW GTI 1.8T 6-speed manual) averaged about 27 MPG as well, but that car was nearly 700lbs lighter and FWD, which is a significant difference. It should be noted though that I drive much more conservatively now than a few years ago. Overall, I’m very pleased with these numbers. I think the better fuel economy is attributable to a combination of improved engine technology (direct injection, better turbo efficiency) and much longer transmission gearing. The GTI was way more fun to drive though.
How to get accurate fuel economy readings:
1. When you get fuel, always fill-up (as oppossed to buying a dollar amount i.e. $20 worth of fuel). This will give you a consistent marker of how much fuel you just added. Avoid topping off your tank with additional fuel after the auto stop, as this will throw off your consistancy.
2. Write everything down, especially your current mileage and amount of fuel you just bought (gallons/liters). I write down the total purchase price too so I can get an idea of how much I spend on fuel and cry about it later.
3. Your real-world fuel economy for the last tank of fuel you drove on = (Current mileage minus mileage at last fil up) / Gallons you just purchased.
For example, if I just drove 347 miles on my last tank, and just filled up with 13.339 gallons, my actual MPG is 26.01.
Tip: Reset your trip odometer every time you fill up so you can skip the subtraction portion.
Interesting fact: My fuel economy reduced by about 4 MPG when I borrowed my friend's V1 radar detector for 2 months.
