Results 1 to 15 of 15
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Replacing the teflon sealing ring on injectors when installing
    How many people replace the teflon sealing ring on injectors when you remove and replace an injector? Or if you buy used injectors out of the classifieds?
    They are supposed to be replaced each time, but I have not ever done this. If you do this, what tool do you use and where do you buy the rings?
    - Eric
    Epy
    Dec 15 2008
    stamford
    The tool is t10133 and the replacement teflon seal comes with a new injector install kit
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by okswerve16 View Post
    Yup. but has anybody found it necessary to replace them? I pulled all my injectors out when I did the carbon cleaning, and stuck them all back in without replacing the teflon sealing ring, and I didn't even put the metal retainers back in either. And the car runs awesome. No leaks, no issues. So, are new rings really necessary?
    - Eric
    Epy
    Jul 19 2011
    Northern Minneapolis, MN
    It's like a crush washer. It is good to replace but not always necessary.
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    I am leaning on replacing, but the f'ing tool is $240!!! WTF It would have been cheaper for me to just buy new ones in this case!
    - Eric
    Epy
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    See the last post, I'm curious if it's really possible to replace the Teflon seal without the t10133 tool
    http://forums.subdriven.com/showthre...133&p=72992228
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    I really don't know if you "have" to replace them. I pulled my stock injectors out 3-4 times now before I found out that you are supposed to do this, and my car runs great. ??
    - Eric
    Epy
    Jul 26 2009
    DMV Area
    ^ they probably need to be replaced if they're damaged ??
    found these
    http://www.apriliaforum.com/forums/s...%20replacement
    http://manuals.wotmeworry.org.uk/Apr...20seal%20H.wmv
    - Chip
    I never touched my injectors. For me if just wasn't worth the hassle or possible cost if I ended up having to replace them.
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    It is possible as I used a center punch with a taper and ever so slightly enlarged the teflon ring by sliding it up the tapered punch...
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings BlkS5's Avatar
    Nov 20 2009
    2017 Tesla S Loaded
    La Quinta, CA
    You must replace. They flatten out and compression from piston will cause blow by around injectors. You can buy the tool from Amazon for $38 and you must use tool. The ring stretches installing and then you compress it back using tool. ECS charges $149 for exact same tool and $40 for new seals that you can also get on Amazon for $19. They aren’t as bad as the dealers but they are also rip offs.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by BlkS5 View Post
    Your realize this is an old post??
    But to add...buy tool kit from Amazon, used, and return..
    Sent from my LM-V600 using Audizine Forum mobile app
    Feb 15 2016
    Cambridge,Ontario
    well i have to say when i rebuilt my B8 ... didn't bother , just put injectors back in and they have been fine for 5 years now.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 21 2018
    frackville, pa US
    Well, its a crap shoot.. Me, why risk it for a few bucks?
    Plus the b7 plastic clips always break, so ya want new install kits anyway.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Jayz691 View Post
    didn't have the tool at the time so just stuck em in. all worked out well
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
