Hey guys,
I've got sort of a weird issue. I'm losing lots of coolant into my crankcase. It goes down quickly. However, my coolant res is clean as a whistle... no oil residue to be found. It's mostly water at this time (because I've been adding so much) and it's 100%.
My question is this: what could cause coolant to leak into the case WITHOUT forcing oil out into the cooling lines? I thought that the oil pressure was much higher than the coolant pressure which would almost always lead to oily water.
Any ideas? Could a busted oil cooler cause this?
Pertinent info:
- Compression good across the board
- Engine doesn't overheat (as long as there is enough coolant), stays at ideal temps
