Results 1 to 37 of 37
    Veteran Member Three Rings AK47's Avatar
    Dec 18 2007
    1970 Datsun 240Z
    Sierra Madre, CA
    Fuel Rail/System Pressure Too Low
    Background: 2011, 10k miles, APR II, Milltek exhaust, EC HFC, EC HFIP/hoses
    As I was on the freeway, I punched it to get around a car, and all of a sudden, the car just bogs down like it ran out of gas. I couldn't get it to rev past 3k, whether I was moving or at a standstill. No CEL, btw. After I scanned it, I got the following fault:
    2838 - Fuel Rail/System Pressure
    P0087 00 [101] - Too Low
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 16474 km
    Date: 2012.03.31
    Time: 07:55:01
    So just as quickly as it appeared, the problem went away. But after reading some postings in other forums, there's a good chance of it reoccurring. There seems to be a couple ways that people have fixed this issue: either by replacing the (2) fuel pressure sensors or by upgrading to a HPFP.
    What's interesting is that some of the people who had this issue had very similar mods, so wondering if there's some correlation. I'd like to be proactive, and try to prevent this from happening again, but don't want to plop down any cash unnecessarily if I don't have to, esp for a fuel pump.
    Anyone experience this, or have any insight as to what could be causing it? Thanks!
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    last year i got a fuel pressure too high error
    Established Member Two Rings vitchie's Avatar
    Nov 14 2010
    2011 Ibis White A4 2.0T
    South Africa
    Quote Originally Posted by AK47 View Post
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 16474 km
    Date: 2012.03.31
    Time: 07:55:01
    There is no upgraded HPFP for our cars, the ones at there are for the older 2.0T FSI engines and not the new ones with the roller cam follower on the exhaust cam. Those upgraded pumps are for B7 A4's, MKV Golf and S3.
    2011 Ibis White A4 2.0T / Xenon / Bluetooth / Exterior Aluminium Trim /
    Mods: FRC Stage 2 Software / 3" ALB Downpipe / EuroCode HFIC Pipe / 19" R8 Reps / H&R OE Sport Springs / RS5 Rear Swaybar / Reverse Camera & iPhone GPS on OEM Screen (XCarLink) / Number Plate LED's / Chrome Exhaust Tips /
    Vag-Com Mods: Needle Sweep / Lap Timer / Ambiance Lighting / Phone Voice Control / Battery Level in MMI / ADS Switch /
    Jul 07 2009
    Lebanon
    Is the car running or does she turn off as soon as you turn it on?
    Most likely your fuel pump is failing and will ultimately fail very soon. Happened to me about 2 weeks ago, had it checked, fixed, and now its running fine.
    SOLD: 2010 A5
    Senior Member Three Rings EuroEclipse's Avatar
    Dec 30 2009
    2012 Evolution X GSR / 2012 Volkswagen GTI
    Germany/Colorado Currently
    Quote Originally Posted by vitchie View Post
    Have you tried replicating the error?
    That would tell you 1 of 2 things... Fuel cut or bad fuel pump. Either that or you had a clog and should run a fuel system cleaner.
    2012 Evolution X GSR - Loud Noises!
    Dec 18 2007
    1970 Datsun 240Z
    Sierra Madre, CA
    I guess I wasn't clear in my original posting, but the problem actually went away after limping along for about 10 miles after it first appeared, and hasn't returned (knock on wood).
    I also wondered if there was an HPFP for the B8s, so guess there isn't, which basically leaves me with only one option of replacing the sensors, assuming the problem comes back.
    One thing I'm gonna do though, as soon as I get a chance to, is measure the fuel/rail pressure, and hoping that someone on here can do the same so I can compare values/results. Thanks!
    Here's the procedure:
    Checking Fuel Pressure
    Prerequisites:
    Ignition ON
    Engine ON (Idle)
    System voltage at least 11.0 V.
    Coolant Temperature at least 80 °C
    [Select]
    [01 - Engine]
    [Meas. Blocks - 08]
    Group 103
    [Go!]
    Field 1: Fuel Pressure (Low), Specification: 2800...7200 mbar
    Field 2: Fuel Pump Adaptation, Specification: -1000...+1000 %
    Group 140
    [Go!]
    Field 3: Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
    Increase the Engine Speed while checking this value, the Pressure has to rise with the Engine Speed.
    Group 230
    [Go!]
    Field 1: Specified Fuel Rail Pressure (High)
    Field 2: Actual Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
    Field 3: Deviation between specified and actual fuel pressure, Specification: max. 5.0 bar
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Dec 30 2009
    I'll do it when I get home and I'll upload my results.
    Dec 30 2009
    I can't click meas. block-8. It's grey.
    Established Member Two Rings bennydub's Avatar
    May 22 2011
    2011 Ibis White Audi A4
    Vancouver, BC, Canada
    i had my fuel pump module replaced at 11,000 km about a month ago. similar symptoms too.
    Current Mods:
    APR Stage 1 93 Oct Mode, CTS Turbo FMIC kit (won in contest ), Awe quad tip exhaust w/ res. downpipe, Alu Kreuz DTS Bar, Hotchkis f+r sway bars, KW V2 coilovers, BC Forged rims, OSIR rear valence, PODI gauge+pod, Blackvue dash cam, Escort Passport 9500ix, Rhoplate plate relocator,
    Past Cars:
    1992 Acura Integra, 1992 Dark Blue 380 AWHP Nissan Skyline GT-R, 2002 Toyota Celica GT-S, 2000 Phoenix Yellow JDM front end Integra Type R, 1991 Nissan 240sx, 1993 civic si
    Dec 18 2007
    1970 Datsun 240Z
    Sierra Madre, CA
    Quote Originally Posted by EuroEclipse View Post
    Had the same problem...thanks for trying though. I checked a couple of the other modules, and they weren't greyed out - only the engine module for some reason. Oh well...
    Senior Member Three Rings dame drizzo's Avatar
    Sep 15 2009
    1995 Audi URS6
    Had this problem with fuel pump with car not starting, then waiting 15 minutes and it starts back up.was told no fuel is reaching fuel rail. Anyone ever had this issue or am I alone? Know of one company that was making a hpfp for b8 a4 but everytime I ask for progress (since December) I am told its still at the machinist. Will contact today to see if anything changes. Only down side to this car is we are basically stuck with stock fueling and my car needs more fuel so i can finally boost my Turbo over 22 psi!
    Dec 18 2007
    1970 Datsun 240Z
    Sierra Madre, CA
    Quote Originally Posted by bennydub View Post
    Thanks for the info.
    I'm hoping I won't have to replace anything because I'm afraid to take it into the dealer due to all the TD1 buzz recently.
    Jul 23 2012
    Brooklyn
    am having the same exact problem it happens on and off scine giac upgrade my ecu the car do not rev over 4k driving or stand still
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Sorry to bring up and old thread. But how did everyone resolve this issue? Did they bring the car in? Is it difficult to change the pump? It's happening to me at 33k miles...STaSIS tune and HFC with roc euro spacer. Thanks!
    Apr 05 2011
    Pacific Northwest
    Hey Guys,
    This is what is happening to me and a few others as well. I replaced basically everything in the fueling system and made no improvements. It is only an issue when I am on APR Stage I, II, K04. We reflashed my car to stock and it is helping for the time being until we resolve the issue.
    Highlander's Build Thread
    Aug 27 2012
    Earth
    Yeah, I flashed my car back to stock. The issues has not been around since...Very strange. I have/had a STaSIS tune.
    Jan 24 2012
    Tucson AZ
    I'm getting the fuel pressure too high code
    2837- Fuel rail/system pressure
    P0088 00 [096] – Too High
    Intremittent – Not confirmed – Tested since Memory Clear
    Freeze Frame:
    7644 – EVAP Leak Detection Pump Control Circuit
    P2400 00 [237] – Malfunction
    MIL ON – Confirmed – Tested since memory clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Any ideas?
    Aug 28 2013
    belleville nj
    Me too
    Aug 28 2013
    belleville nj
    Fuel rail pressure too high code and did logging the car requests for 4.00 what the actual is 8.00 fluctuating to 10.00
    Jan 24 2012
    Tucson AZ
    vinnys3, could you elaborate on your stage status? Elaborate on any (if at all) symptoms?
    Thanks.
    Jan 24 2012
    Tucson AZ
    Sorry, for me I am no symptoms; flashed to Stg 2+ Beta one mth ago.
    Aug 28 2013
    belleville nj
    Stage 2 apr v1 still and lots of hiccups during idle only
    Oct 10 2012
    Zionsville and Saint John IN
    I got a different code but I think it's related to having stage II APR and fuel delivery. The gas light was on so I'm sure that had something to do with it. I cleared it and hadn't came back for 300 miles. When I get my laptop back I'll use my rosstech cable.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Clearly these problems are related to the APR tune, my guess is the fuel pressure request is being exceeded so the ecu try's to save the pump.
    Aug 28 2013
    belleville nj
    Yea but i have been stage2 for over a year this code just pops up now??
    Apr 05 2011
    Pacific Northwest
    Quote Originally Posted by Highlander1010 View Post
    Hey Guys,
    Mine turned out to be a bad ECU. It was replaced by Audi at no cost to me under warranty.
    Aug 28 2013
    belleville nj
    Just got back from mechanic turned out to be a bad fuel rail pressure regulator sensor
    Aug 28 2013
    belleville nj
    Issue came back!
    Jan 24 2012
    Tucson AZ
    vinnys3, are you still under warranty? I've been told to have APR flash back to stock and take to dealer. My problem is the dealer is 1.5 hrs away and I won't have time this month to make the trip.
    My mechanic thought that without symptoms no need to worry currently until I get it checked out, but who knows? Best of luck.
    Aug 28 2013
    belleville nj
    Not under warranty i have 69k but thats my next thing im going to the stealer
    Aug 28 2013
    belleville nj
    So drive auto works is trying the fuel pressure regulator mechanism itself right now ..will keep posting
    Jan 24 2012
    Tucson AZ
    Vinny, mine ended up being an emissions fault which will require replacement of PCV valve and leak detection pump. Hope you got everything on yours sorted out
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    All:
    Still running the APR Stage 2+ BETA file. The stumbling that are mentioned in other threads has now returned again. I have an appointment with the local APR tuner in the morning.
    Cleared my codes, and I am wondering was this issue identified with others?
    The stumbling only occurs under load from 2700-3000 RPM. I looked for the other thread with the owners having similar issues but couldn't find it. I am running a BB exhaust, K&N Pleated filter and APR Beta Stage2+ R8 Coils, Gen 3 PCV valve and the recommended plugs. Some other owners thought there might be detonation occurring. I am quite baffled.
    I am going to do some logs on the way home in the afternoon and see if Arin comment. Here are my faults as of this evening:
    3 Faults Found:
    2837 - Fuel Rail/System Pressure
    P0088 00 [096] - Too High
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 92147 km
    Date: 2016.02.10
    Time: 17:45:38
    5671 - Boost Pressure Regulation
    P0299 00 [236] - Control Range Not Reached
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 93139 km
    Date: 2016.02.23
    Time: 10:14:26
    7663 - Boost Pressure Control Valve (N249)
    P2261 00 [108] - Mechanical Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 254
    Mileage: 88511 km
    Date: 2016.01.06
    Time: 12:14:14
    Readiness: 0010 0001
    Veteran Member Three Rings SickAvant's Avatar
    Nov 12 2006
    FL350 Oddysey, Sick fun! Google it!
    Burbank, CA
    Hey guys, I am having an issue with my 12' Avant. I am getting a long crank when I got to start it. It does it cold start or warm and it has progressively ramped up and is doing it a lot more. I just replaced the injectors, carbon cleaning, and new spark plus. It is becoming very annoying because the car is still doing this, only other thing I can think of is HPFP, but I would hate to replace it and it not be that...
    Oh one last thing, when I go to start it it cranks and it won't start till I give it gas like a fl'n classic car... I shouldn't have to give it gas to start on this car..
    Please any suggestions would help..
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by SickAvant View Post
    You may want to start your own thread. Have you considered lpfp in the tank or fuel filter ?
    What about fuel pressure regulator valve ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 02 2019
    philadelphia, Pa
    Hey bud, I know this is an old thread, but trying to find any help I can out here, I'm getting a p0087 only after the car runs for 45 min, regardless of Idle or driving with hard acceleration. Was it an error that only occured after running for a while as the part would overheat?
    Junior Member Two Rings Maniaka's Avatar
    Mar 21 2019
    Rs6 C8
    Sweden
    Hello I want the same problem on my own Audi RS3 2017.I get a mistake P0087.I have Stage 1 with intercooler installed and intake.Some can help.I'm sorry for my bad English.
