Things u will need
A replacement pump go with new or remanufactured, which ever has the best warranty
6mm hex head socket with 3/8 drive
3/8 drive flexible head
19 mm wrench
2 6 inch 3/8 drive ratchet extension
needlenose pliers
new clamps for hose connections
channel locks
22mm socket that can attach to a 3/8 drive
3/8 drive ratchet
2 liters of vw audi power steering fluid or pentosin chf 11s (2 liters should be enough for topping off reservoir post installation and do a lil bit of flushing of the system)
a jack that can get both front wheels off the ground
a friend on hand to assist for some of the diy u can do most by yourself
I highly recommend doing a power steering flush post installation and replacing all clamps and any bad hoses upon pump transfer
if u have already replaced ur pump dont forget to check to see if u have a manufacturers warranty i sent back both pumps i had replaced at a shop. and didnt pay a penny for my replacements other than shipping on one i ordered off the net now i have an xtra pump lol.
1. start by removing the cover over the power steering pump. Pull the rubber stripping off for a lil more space as shown in pic.Take your 6mm allen head(hex head) socket and attatch it to your 3/8 flexible attachment. Not to the ratchet for space is restricted. Then connect your six inch 3/8 extension so u should have a 3/8 extension with a flexible head with your 6mm allen head socket attached to the flexible head. Now loosen the three bolts connecting the p/s pump to its pulley with your homemade tool. You may have to turn over the engine for a second to get the last bolt to land in a place where u can loosen it , once again space is restricted.
2.Once u have removed the bolts for the pulley take your 19 mm wrench and press on the tensioner to release the tension on the drive belt . You will see a piece if you look to the right of your tensioner pulley,that is where the wrench goes.
3. Remove drive belt and pulley. Once belt and pulley are removed you can now start unbolting the pump bracket. You cannot remove the pump wthout removing the bracket with it. The bolt in the back of the pump is impossible to reach. All bolts are the same size as the pulley 6mm allen key head socket that hold the pump and bracket in. There are 6 bolts in all, 3 bolts holding the pump to the bracket, 2 in front, and the one in back of the pump. The other 3 hold the bracket to the car , 2 in front, and one in back. For the back bracket bolt stand over the pump and look down behind the pump and you will see the last bracket bolt. use your 2 6" 3/8 extensions connected to make a 12 inch extension and unbolt the last bolt holding the bracket in place using your 3/8 ratchet . The last bolt holding the pump to the bracket will come out after the pump and bracket are out.
4.Then with your 22mm socket connect it to the banjo bolt and with a channel lock hold the bolt behind the banjo while you use while you use your 22mm to a 3/8 ratchet to loosen the banjo bolt. Have rags on deck and a pan under your car. Im assuming you have your skid plates removed . Catch old fluid from under the car and wipe excess fluid away.
