Results 1 to 40 of 77
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    DSG how to stop the fart sound!!!
    There has to be some type of mod or silencer to stop this farting sound when under hard load and shifting. Right??? Where is the noise coming from, is it the left over boost being dumped into the exhaust?? All I know is I want to alter that sound since it sounds horrible IMO.
    Veteran Member Three Rings DATZ's Avatar
    Oct 17 2010
    Northern NJ
    Simple mod - trade your car in for a 6mt.
    2015 S4 - Sepang Blue - 6mt - Black/Silver Nappa - Sports Diff - Black Optics - B&O - Tech Package - Carbon Atlas
    Bilstein PSS10 - Milltek non res - Eurocode sways/links/AluKreuz/STS - StopTech Trophy 380mm BBK - APR intake
    Registered User Three Rings
    Sep 07 2011
    California
    That's the best part of DSG! Why would you wanna get rid of it?
    Mar 14 2010
    Around
    Or get a Milltek exhaust and fall in love with it.
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    I made my car make that fart 2x under hard shifting... Wish it did it more often lol but I wont give up the 3rd pedal
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by DATZ View Post
    THIS IS THE ONLY WAY! Unless you want to experiment with putting a few tablets of BEANO in the gas tank. No exhaust mod will make it go away.
    Veteran Member Three Rings motionneon's Avatar
    Feb 09 2011
    Honda Odyssey Turbo S
    St. Petersburg, Florida
    With miltek non-res exhaust the fart has become a mean-assed burble. Actually sounds cool now.
    Veteran Member Three Rings dawei213's Avatar
    Oct 05 2011
    Philadelphia, PA
    Quote Originally Posted by RevoTechnik-GM View Post
    Agree! I love that sound. Then again, I love farts!
    2012 S4 | REVO - Stage 1 | AWE Resonated Exhaust | BILSTEIN PSS10 | Eurocode Alu Kreuz | ALU FELGEN SF-71 HB 19x9.5 | H&R Spacers 15/20 | 20% Tint
    Senior Member Two Rings misc720's Avatar
    May 04 2009
    socal
    Learn to love the fart.
    Established Member Two Rings SierraBravo's Avatar
    Jan 23 2012
    Greenville, SC
    Gives the car personality. Why U B hatin?
    2014 Phantom Black S6, Eurocode Sways, End-Links And Alu Kreuz, Milltek Cat-Back Exhaust
    Previous - 2012 Monsoon Gray S4
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Quote Originally Posted by misc720 View Post
    heh, I can see the marketing campaign now..."Audi: Learn to love the fart!"
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Quote Originally Posted by Traveler View Post
    Hey, will that work for me too
    Veteran Member Four Rings Chestlock's Avatar
    May 30 2010
    Victoria, BC
    My car's really taken a shine to Gas-X, but that's only a band-aid solution. Now, if only I could remove the clutches and throw in a torque converter....
    Veteran Member Three Rings audisarecool's Avatar
    '11 S4
    this
    Current: 2014 Phantom Black RS5 - Stock for now
    Gone: 2011 Quartz Grey S4 // Stasis V2 // VMR V710 // H&R OE Springs // 034 Adj CA's // Alu Kreuz // APR Stg 1&2 Intake // 12.44 @ 112
    May 30 2005
    fl
    wow not the responses i was looking for. that there was a was to move that noise to silence it.
    Veteran Member Four Rings Akrion's Avatar
    Dec 24 2010
    Not a fan of the fart. I am getting AWE soon with resonated downpipes and I hope my DSG wont fart too much ...
    May 30 2005
    fl
    What causes this, boost being dumped into the exhaust or just a timing thing causing the exhaust to make a fart noise?
    Boy would this car be fast if it didn't need to drop timing in between shifts
    Sep 30 2009
    b
    I like it here.
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by brad65ford View Post
    Boost dumped into the exhaust? That's not even possible without a ton of changes to the car, and no reason for a supercharger to do this. Do a little research on DSG, it shifts faster than any human can, *because( of the timing pull between shifts, to allow perfect rev matched shifting. Check the logs for the V-box pulls and look at the accel lines where there is a long pause for shifting in 6MT's compared to the DSG with the smooth curve and zero notable drop in accel during shifts. The timing drops is what gets the engine to spin down fast enough to get into the next gear without clutch slippage.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings IanVr6's Avatar
    Jan 07 2010
    New Orleans
    2015 BMW M4
    2014 Jeep Grand Cherokee SRT
    2012 Audi S4 - totaled
    2008 VW R32 - sold
    2000 VW Jetta VR6 - sold
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by Akrion View Post
    Hate to break this to you, but I have heard the AWE exhaust with the DSG and the fart is still there. Might even be accentuated.
    Dec 24 2010
    Quote Originally Posted by Dr GP View Post
    Well it is what it is ...
    May 11 2010
    2011 S4
    You can learn to drive it reduced a bit... I pretty much have mine down to where I can make it fart or keep it kind of subtle. If I had my radio on (not blasting) and someone else were in the car, they could not really tell. It is all about the little pedal.
    May 30 2005
    fl
    wow not the responses i was looking for. Thought there was a was to move that noise to silence it, like a different dump valve etc...
    You can hear it clearly in the AWE exhaust video. around .42 and .48 seconds. http://www.youtube.com/watch?feature...&v=r-tSCeTA3jU
    Boy so sexy, I'd rather have a ricer blow off valve sound instead of a whoopie cushion sounds. How the hell can I be the only one that wants to get rid of that type of sound just make now sense to me.
    Jan 07 2010
    New Orleans
    I agree with you, I really hate the DSG exhaust fart.
    2015 BMW M4
    2008 VW R32 - sold
    May 30 2005
    fl
    Thanks IV6 at least someone agrees with me. Thought there would be a simple mod to redirect to boost by now, guess not. Does anyone know where the boost bypass valve is located, I'm assuming its not an easy mod if no one has done it yet...
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    My tiptronic A6 doesn't fart. Want to trade?
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    ...Thought there would be a simple mod to redirect to boost by now...
    It's not boost being dumped that's causing the sound.
    Ya know, it's a shame that you didn't actually drive the car before buying (??) one.
    Established Member Two Rings Philthy's Avatar
    Nov 10 2010
    Wildwood Mo
    It does it because it's rev matching the shift. There isnt going to be a mod to "fix" it because there is no fix. What mod would want to intentionally hurt shift performance?
    May 30 2005
    fl
    Quote Originally Posted by Philthy View Post
    So the noise we are hearing is not extra boost being dumped? Is there a boost bypass valve on our cars?
    May 30 2010
    Victoria, BC
    Definitely my next mod - I'm putting in a CVT transmission!!!!!!!
    Jan 15 2012
    MA
    According to this PDF on the S4 engine, there is a boost bypass with information on page 21.
    In the 3.0l V6 TFSI engine, the control valve control module J808 is used to regulate the charge pressure. It is integrated in the supercharger module and connects the pressure side to the intake side. By opening a bypass
    valve, a portion of the air fl ow is recirculated through the open bypass to the intake side of the Roots blower. The bypass valve works in much the same way as a wastegate on an exhaust turbocharged gasoline engine.
    Nov 10 2010
    Wildwood Mo
    I don't know the technical aspects of what exactly the noise is, but something to the effect that the ECU pulls timing, which causes a bit of fuel dump. Think about it, basically you are keeping your foot planted while it does the shifting. There is some speculation that if there was no cat you might shoot flames, ala WRX style, but no proof of that ive seen so far.
    As far as the bypass valve, pretty much every boosted VAG car uses a recirculating system, ie; diverter valve, so I would assume yes, but you aren't dumping boost...well you are but that's not what you are hearing.
    Well shit...posted while I was typing...lol...what he said about te bypass.
    May 30 2005
    fl
    Bingo nice find handruin! I know on the 03 Cobra's there was a boost by pass valve mod, not that I want to mess with this electrical thingy since everything is now controlled with electronics. But it would be interested to know if this is the cause/area where the farting sound is coming from.
    Tasks of the control valve control module J808:
    – Regulation of the charge pressure defi ned by the
    engine control module
    – Limitation of maximum charge pressure to 1.9 bar
    (absolute)
    May 30 2005
    fl
    So its all from timing causing this fart sound?
    Jan 15 2012
    MA
    Do other vehicles that have dual clutch gear boxes also have this fart sound? I've watched numerous videos of the nissan GT-R and I've not heard a signature fart sound come out of its back end. Maybe it's there and I just haven't noticed? Is it just how Audi decided to deal with matching the revs and is there alternative ways of dealing with this for a clean shift?
    Nov 10 2010
    Wildwood Mo
    Most dual clutch cars will to some extent. My GLI, DSG 2.0t, did it as well. Im sure its how zee Germans decided to deal with it. I shouldn't say so unequivocally that you can't get rid of it, but im assuming it would be more work than it's worth in the end. On the tuners side though
    It seems to be a pretty complex group of things going on, fuel cut, timing retard, back pressure change, then back on the fuel.
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    I think it sounds bad ass. The sound of high tech. Now if you fart a lot and on top of that you buy a car that also farts than your wife/GF might look at it as a trend...
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Top Gear mentions this at the beginning of the video:
    audi-rs-5-part-2-series-16-episode-5
    "Jeremy decides to put the M3 up against the new Audi RS5. The RS5 is 4-wheel drive and has a Lamborghini derived 4.2L V8 – which curiously has a device which fires a drop of petrol into the exhaust when you change gear."
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Intentionally pumping fuel with no spark seems like a bad idea. I'm skeptical that's what it is.
