FYI in case its not PERFECTLY clear from the other thread:
The login number is different than the coding number, but you need to make sure you're logging in with the same settings as the coding you are wanting to recode to.
So, referencing this page:
LINK
My current car is the 1.8t manual so my current coding is: 04275
If I upgrade to the B6/7 S4 brakes and I want to recode my ABS module, my login is: 09275
I would then change the coding to: 04575
I would then recalibrate the steering angle sensor (I've done this before and was successful using the login code but I'm not sure if that is required in this case, I would think it is). Then close the module. Turn the car off, remove the key to be safe, wait 30 seconds to a minute. Turn car back on and the coding should be accepted.
