Results 1 to 40 of 57
    Feb 12 2012
    nh
    engine just randomly died. now wont start and no cranking over. help!
    Hey guys, was just driving down the rd right down the street from my house. Not beating on it or anything and the car just died. Still have juice in the battery and everything but the engine wont turn over at all and it won't popstart either. Right before it died it kind of sounded like maybe a hose popped off? But nothing that I can see. And there isn't any oil laying around on the ground or anything so I don't think I threw a whole in the block. Any ideas?!
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by xcsp800 View Post
    The popping noise was probably a fuse blowing. Check all your fuses and go from there.
    Jan 24 2010
    Paramus,NJ USA
    try jump starting it??does it crank?? but no start??could be a faulty alternator not charging,could of popped the timing belt,could of fried the ecu,or a fuel pump could bethe culprit.
    Jan 21 2012
    Atlanta
    Mine did that today on I-75/85 in the middle of downtown Atlanta rush hour traffic....had it towed home. Ruined my day lol
    Feb 12 2012
    nh
    Jump start dosnt do anything. No matter what I do I can't get the engine to crank over. Think it could be a tbelt?
    Veteran Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    Stage 2 C7 A6, Tahoe for the kiddos
    SLC, UT
    The only thing that comes to mind is something Electrical. If it was something like a humongous boost leak, or even an un-timed engine (such as a TB issue) the car would still turn over. Unless the engine seized, which I haven't heard that happen very often. Have you been inside the ECM box recently? I'd check your fuses as well, I believe there are 3 for the ECM in the left dash panel.
    Jun 23 2010
    Athens, PA
    So your car just died? Did electrical things start to turn off one by one? If that's the case, then you have an alternator issue. When my friend's alternator went in his 2.8 though he was able to wait over night and got the car to turn over and drive again, but only for about 5 miles before it died again.
    Feb 12 2012
    nh
    No nothing really that I noticed being wierd electrical except when I got to lock car now, the horn won't beep. And also the interior lights are wierd ocasionally when I open door or stuff like that. But nothing crazy wierd?
    Oct 18 2010
    SLC, UT
    You say your battery is "fine". Did you check the ground and power cables physically? Trace the ground and make sure it's tight.
    Feb 12 2012
    nh
    Yep, everything is good there. And also when I tried to pop start it, it wouldnt work either. So frustrating. Could this be a tbelt issue? Would this cause engine to not crank over? I have a few people saying it would make it not turn over and some say it still would
    Feb 12 2012
    nh
    Bump
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    Vid of trying to start it please.
    Aug 24 2008
    san carlos ca 94070
    Head gasket-Hydro locked ,Take out all of the spark plugs and turn it over,look for water.
    Feb 12 2012
    nh
    S4rich you really think thats what it is
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Check fuses and grounds first. Could be engine speed sensor. If the car won't crank that shouldn't have anything to do with the timing belt.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Aug 24 2008
    san carlos ca 94070
    When my head gasket went three years ago; Yes it sounds about the same! (look for water out of the plug holes when cranking it over)
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    If you're literally not able to crank the motor over it could be a t-belt. I doubt it's something electrical, pull the plugs and take a peak inside. A head gasket would throw some white smoke before hydrolocking... That sound pretty extreme, I've never heard of that until now.. A t-belt issue may cause the engine to not turn over depending on if there is some internal damage as a result of it breaking... If it were something electrical it would have to be pretty major (interfere with starter motor as well as ignition some how) You're ems would have to have fried up or something... If you're getting a clicking noise and the lights flicker it is electrical though. If it's not clicking it's got to be something physically preventing the motor from turning. Best of luck, I know it'd be heart-wrenching for me...
    Feb 12 2012
    nh
    It makes one click and dims the lights and all of that but just dosnt turn the motor over.
    Feb 12 2012
    nh
    Just took a quick car in the day light, looks like a may be leaking hydrolic fluid? But would that cause me to not be ablr to crank car over. And its not a crazy fast leak or anything. But Idk where it is from. Drivers side of engine is all I know hah
    Oct 27 2011
    TOYS
    Philly Suburbs
    What color is the fluid... and have you checked your starter/fuse? If the fuse is good try juicing 12V right to the starter contact... maybe your starter crapped out...
    Feb 12 2012
    nh
    It's hydrolic fluid. And where is the starter fuse?
    Senior Member Two Rings MCsquared's Avatar
    Dec 04 2011
    Check the amperage going to the starter, if it's really high then you have mechanical resistance ie something messed up internally
    Make sure the starter actually gets power first of all, but if you can't even pop start it then you have a bigger issue. Scan for faults and pull the plugs to see what's in the cyls
    Registered Audi Technician
    ASE Master Tech
    1999 A4 1.8qtm
    2001.5 S4
    Poverty is owning a race car
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Is it a 6speed? Maybe your clutch slave broke and you can't press the clutch in to start the car?
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by Timtheguru View Post
    The car would lurch forward if it was in 1st gear with no clutch. When my clutch fork broke on my 3000gt I started it in first gear in order to drive the last 5 miles home. Clutchless shifting FTW!
    Dec 30 2009
    He doesn't necessarily have the car in gear when trying to start it, I keep it in neutral when starting my car.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    This says battery or alternator the fact that it wont pop start leans it more towards being the alternator. The lights dimming is because you do not have enough power try to jump it. If it starts and then you take the jumpers off and it dies it is the alternator.
    Oct 27 2011
    TOYS
    Philly Suburbs
    ^good point, if you were trying to jump the car with small gauge wires and a completely dead battery due to a bad alternator... it probably wouldn't crank over... get a multimeter and start checking stuff instead of guessing.
    Feb 12 2012
    nh
    So get this. I just go back out to the car look around, pull a couple plugs to check stuff and it looks fine. Go to start car and now it clicks over like it wants to start. Just makes the clicking noise. Hmm wierd
    Jan 09 2009
    FL
    alternator/battery.
    Obviously change the battery first.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    sounds like timing belt snapped and locked up the motor.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Three Rings car's Avatar
    Feb 03 2009
    16 S6 93 SLC 91 GTI
    Harrisburg, PA
    Did the engine turn over when you tried to bump start it? Or did the tires lock up and skid to a stop?
    16 S6 Prestige - Daytona Gray Pearl - Sport Package - Drivers Assistance - B&O - Black Optic - Comfort Seats - Cold Weather Package - Alcantara Headliner - Cargo Net
    Aug 26 2008
    Minnesota
    I imagine you have a CEL, pull and provide the codes.
    Feb 12 2012
    nh
    No cel. Still just my misfire code at idle. That's it. And no tires didn't lock up or anything like that.
    Feb 03 2009
    16 S6 93 SLC 91 GTI
    Harrisburg, PA
    Then the engine turned over when trying to bump start it. So the engine is not seized or locked up. Not ruling out a broken timing belt. Just trying to help collect info.
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Is your serpentine belt still there or did it shread? This may be the sound you heard and you just need to put a new one on.
    Feb 12 2012
    nh
    Serp belt is fine
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Can you put socket on crank bolt and turn?
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Jan 24 2010
    Paramus,NJ USA
    Sounds like a battery to me as well as a alternator.Especially if it dimms the lights.The battery can have 12v and have 2 amps and it will be a shot battery.Amps crank over the engine and the battery has to have 12v.But just because theres 12v at the battery doesnt mean it has the amps to turn over the starter.Our batteries typically have 380A IIRC.check your battery or try charging it.Then report.Or as mentioned the starter crapped out.but seeing as your were driving the car when it died id assume, the alternator went and the battery was drained because it wasnt being charged.
    Feb 12 2012
    nh
    Okay but it also won't pop start or jump start so I don't think its bat related
    Feb 28 2007
    chicagoland
    Quote Originally Posted by EuroxS4 View Post
    he wouldve noticed the battery light being on if he had half a brain.
    lights would dim if the motor was locked the starters drawing way more power than it should it would definitely dim the lights.
    Nogaro 01 s4
    620whp 93octane
