Results 1 to 33 of 33
    Veteran Member Three Rings ginch's Avatar
    Jun 30 2011
    calgary, alberta
    Reducing raspy exhaust
    So I have a set of Milltek downpipes and full Milltek exhaust with H pipe. Love the sound however hate the raspy sound it has. Will an X pipe reduce the raspiness of the exhaust and if so who sells just an X pipe connector? Thanks in advance!
    Derek
    2008 Avus silver RS4
    1996 993 C4S
    2017 Tacoma TRD Sport, Quadcab shorty, 6 speed, Wife's daily!
    Gone
    2016 Reflex silver Golf R, 6 speed
    2008 Phantom black RS4
    B7 S4 Avant
    1993 964 C2
    2004 Reflex silver .:R32
    Aug 27 2005
    Michigan
    Is the exhaust resonated or non resonated?
    Jun 30 2011
    calgary, alberta
    I should probably know how however I bought the car with the exhaust on it already. Where are the resonators located, before or after the H pipe connector?
    1996 993 C4S
    Gone
    B7 S4 Avant
    1993 964 C2
    Oct 03 2011
    2007 S46MT, 2011 S46MT,2009 R1
    Sacramento
    i would guess it is non resonated if it is raspy, take a listen to the exhaust compilations...
    in general resonators reduce rasp, mufflers reduce loudness, but each setup will be different..
    Aug 27 2005
    Michigan
    I'm assuming it's non resonated because you said it was raspy. The resonaters should be after the x/h pipe and before the mufflers.
    X/h pipe affect the overall sound, American muscle (h-pipe) and exotic (x-pipe).
    Jun 30 2011
    calgary, alberta
    Well I 99.9% sure its non resonated as I don't recall seeing resonators after the H pipe. So I'm looking to replace the H pipe with an X pipe. Being Milltek, I'm guessing its 2.25" in diameter. Where would I find an X pipe in that diameter?
    Thanks a lot for your help gents!
    Derek
    1996 993 C4S
    Gone
    B7 S4 Avant
    1993 964 C2
    Senior Member Four Rings
    Aug 11 2011
    Installing 2.5" catless dps this weekend, to go with my FI 12" res cat back. Hope it isnt too raspy...
    I mention this because resonators reduce rasp...a lot. I will let you know how the rasp is with the 12" I have on there now
    Aug 27 2005
    Michigan
    Just so you know.... The x-pipe isn't going to help the raspyness very much if at all. Just change the exhaust note to a more exotic sound, and will quiet down the sound a little bit. Your better off getting a exhaust shop to weld some resonaters on. Miltek might even sell you just the resonaters to install.
    Jun 30 2011
    calgary, alberta
    I just don't want to lose the level of noise as I like how loud it is (probably even a bit louder would be fine) so I'm worried resonators would make it quieter!
    1996 993 C4S
    Gone
    B7 S4 Avant
    1993 964 C2
    Aug 27 2005
    Michigan
    And as far as the FI exhaust. You won't get any raspyness with that setup. I have the same thing but with 14" resonaters and there's barely any if none.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Resonators will make it quieter, yes. Smaller resonators should REDUCE the rasp without making the system too quiet, but in the end the biggest resonators possible should remove rasp.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Aug 27 2005
    Michigan
    if you want the same loudness you should probably keep the h-pipe, or switch to the x-pipe and get some catless downpipes :)
    Resonators mainly affect the raspyness
    Jun 30 2011
    calgary, alberta
    I just want the exhaust noise to be smoother. So you are saying just resonators will do this with leaving the H pipe in place?
    1996 993 C4S
    Gone
    B7 S4 Avant
    1993 964 C2
    Aug 27 2005
    Michigan
    Yes, the resonators will clean up the exhaust tone. If you like the sound of the h-pipe then sure keep it, the resonators will get rid of the raspyness and quiet down the exhaust a slim amount, just because you are adding something slightly restrictive to the exhaust.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by blkaudi98 View Post
    The restriction is negligible as long as the inner diameter is consistent with the rest of the exhaust tubing.
    Aug 27 2005
    Michigan
    i stand corrected on that , thanks
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    X pipe will give a "smoother" sound as it allows the exhaust pulses to draw gas from the other bank more effectively. It reduces back-pressure and takes away some of the oscillation/choppiness of the exhaust note.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by b spot View Post
    Correct. H-pipes (or no joining at all) will let you hear the individual exhaust pulses a bit more, sort of like a muscle car. X-pipes allow the pulses to mix and sounds more refined.
    Jun 30 2011
    calgary, alberta
    So where might I be able to purchase this X pipe?
    1996 993 C4S
    Gone
    B7 S4 Avant
    1993 964 C2
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    Quote Originally Posted by M|R View Post
    Won't be raspy at all esp with the resonators. What size resonators did you go with? I have 14" on my car and it sounds great.
    Idk, from what I've witnessed this isn't completely true. All the cars I've heard with an H pipe have sounded very very raspy and tbh imo sound like shit. Having 2.25" exhaust doesn't help either because the exhaust doesn't flow as freely.
    Quote Originally Posted by ginch View Post
    Your best bet probably is to have someone make you one.
    A few mods here and there
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    I'd start with resonators, my experience is better sound with almost no volume/flow decrease. The resonator shouldnt be restrictive really, the ones I've seen are pretty much open chambers
    Deactivated Two Rings
    Nov 27 2011
    2004 S4
    Italy/US
    Quote Originally Posted by dparm View Post
    I'm running a true dual setup with no resonators, and I only have rasp when the exhaust is cold. I think with short resonators the OP should be good to go!
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    ^do you have cats still?
    Apr 24 2009
    Frisco, TX
    A lot of it has to do with how the exhaust was "tuned", if at all. That's why the more expensive exhausts have that more exotic note; research was done on the merge angles, resonator design and size, and mufflers to get that particular note people like.
    Rasp is indeed common with cold motors, even with stock exhausts. Some rental cars I've had sound awful until they're fully warmed up.
    Honda did something cool on my old S2000 to help. Look at the weird stub near the very back...it was put there to remove rasp. Very careful tuning and analysis was likely done to figure that out. Also, the S2000 had twin-loop mufflers from the factory which gave it very good flow but a smooth and quiet sound.
    Nov 27 2011
    2004 S4
    Italy/US
    http://www.amazon.com/s/ref=nb_sb_no...gnaflow+x+pipe
    Cheaper:
    http://www.amazon.com/s/ref=nb_sb_no...n+x+pipe&ajr=0
    Nov 27 2011
    2004 S4
    Italy/US
    Quote Originally Posted by beemercer View Post
    Yes, which is probably why I don't have rasp as well. I guess my point was that he shouldn't change his X/Y/TD pipe setup to get rid of rasp, but should consider resonators first.
    Jan 14 2009
    Audi's
    x-pipe = more rasp
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Quote Originally Posted by Mr. Corey View Post
    x-pipe = more rasp
    I have to disagree. H Pipe will have way more rasp than X.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Apr 24 2009
    Frisco, TX
    x-pipe = more rasp
    X-pipes will smooth out the flow and will allow the exhaust pulses to "line up" properly. It should keep rasp down.
    Jan 14 2009
    Audi's
    X-pipes do smooth out flow but if you take a look at any of the exhaust video clips x pipe is usually more raspy if your comparing to an H pipe..especially if its non res. I said Usually because their a many variables that can change the tone... resonators, non res, x pipe placement, cats, no cats, and if the x pipe actually intersects or just has the bend.
    But over the course of the 3 different exhaust setup I've had on my car x pipe was raspy over the H
    Quote Originally Posted by SuperAvant View Post
    take a look see
    H pipe
    http://www.youtube.com/watch?v=oSsvW...1DA8EDFFA0AA86
    X pipe
    http://www.youtube.com/watch?feature...&v=w_oUZfv8xtA
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Helmholz??
    Old Geezer, formerly known as Stud Muffin
    May 30 2007
    MA
    take a look see
    H pipe
    X pipe
    Ive had both on my car. H had way more rasp
    2014 R8 V10 - Gated
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by QIKRNU View Post
    Helmholz??
    Yes, it's called a Helmholtz resonator/chamber.
