Believe me, I know what you're thinking. Yes I did a search, yes there have been similar threads over the years, but while i have similar symptoms, i don't have the multitudes of symptoms everyone else has had. I'm really scratching my head on this one.
It started 2 days ago out of the blue. Started the car cold, rpm went up to 1100 then shut off immediately no CELs, same thing happened a couple of times after, then i decided to give it some gas, and the same thing happened and still no CELs. Then I gave it just about half throttle, and it started up and ran fine.
After a warm start, it goes to it's normal 8-900 rpm, then shuts off immediately again no CELs, and again i have to give it about half throttle and it starts up fine no problem.
The major difference here, from all the other similar situations is that once it starts it's completely normal. I'm not throwing any CELs, and my VAGCOM is reading nothing.
I've narrowed it down to a number of things, and most have disproof.
Immobilizer/key needs reprogramming - I considered this, but if the immobilizer is failing I shouldn't be able to start it fine with gas and run no issues.
Fuel Pump bad - I've detected no unusual noise when it primes, and I have never stalled out while idling. Drove 200 miles yesterday never stalled at idle in neutral.
Fuel Injectors bad - Again while driving, no misfires, no stuttering during acceleration or anything is, everything seems normal.
Boost Leak/Vacuum leak - I checked all my hoses running from my FMIC to the intake mani, as well as vacuum hoses on my DV as well. No Leaks
MAF issues - Unplugged it, same thing happens at start-up.
Fuel Filter - This is the only thing I haven't gotten around to replacing, but I honestly don't see this as the issue here.
Feels like I'm starting up my old 69' carbureted Charger back in highschool >.<
Thanks in advance!
