Results 1 to 18 of 18
    Veteran Member Four Rings TofuShop's Avatar
    Aug 24 2010
    Anyone running 255/40/19 tires?
    Hi all,
    Was wondering if anyone on here was running 255/40/19 sized tires. I checked Miata.net's tire calculator and confirmed it is only 3.9% off from stock and will make the speedo 2.3 mph off. HOWEVER, it will make the sidewall 0.5 inch thicker providing more protection and getting rid of a little bit of wheel gap. It's barely more expensive than 255/35/19 tires so i figured why not. I don't want to risk damaging my new wheels so i figured the little extra bit of rubber may do some good.
    Thoughts?
    Mar 04 2012
    Laguna Niguel, CA
    Im wondering the same thing. With a mild drop would it ever rub?
    Aug 24 2010
    rubbing would depend on width and offset of your wheels
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Would be too tall IMHO.
    You could try 245/40/19.
    On of the s4 guys did it for winter and it didn't look great.
    He had bbs wheels too.
    I run 245/35/19 and it's been good for NYC roads....
    -cW
    2023 X3 M40i Alpine White
    Aug 24 2010
    do u know which S4 guy? all the threads i could find were for B7s. it didn't look too bad, imo. this will be on a 10" wide wheel so i didn't want to get 245s.
    Mar 02 2007
    Fresno, CA
    I've always been advised to stay within 3% of OEM tire diameter, so 3.9% would get the from me. Properly inflated 255/35/19 tires have always protected my wheels nicely.
    Mar 04 2010
    Vancouver
    ^whats your wheel/tire specs anyways blake?
    Modifications: Parents ran out of money so they bought me tires that were way too small for my wheels.
    PART-OUT THREAD: CLICK HERE
    http://instagram.com/crisostomoz : most up to date upgrades to the car, as well as random things.
    Aug 24 2010
    he's running 255/35/19 Proxes 4
    the roads by me are pretty bad in certain areas. potholes that would make your bumper scrape if you fell into one. the increased sidewall would also reduce my wheel gap a tiny bit
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Here you go man....
    Forum member DATZ ride with 245/40/19.
    Seems to have more wheel gap then on standard 255/35/19 tires.
    Must be the fact the car sits higher with those tires....
    255/40/19 would be even higher than this...
    Not looking great IMHO. You'd achieve the same look with 18's and 245/40/18... :)
    -cW
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Here you go man....
    -cW
    Looks seriously out of proportion, not being lowered enhances effect IMO.
    Add that will negatively impact actual mileage reading - wouldn't do it.
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Aug 24 2010
    wow, at stock height and those tires, the car sits so high. the wheel/tire ratio looks more proportional with the 40 series tire to me, though.
    i'll need to think about this some more. those pics definitely helped though. thanks for digging them up
    Mar 04 2010
    Vancouver
    In just worried you can't fit the 40 profile on your super sport springs
    Mar 15 2009
    These are 255x30x20 w/stasis suspension. Rubbing will be determined by lots of factors. current suspension height (stock/OE sport/aftermarket sport/stasis in my case/ etc). planed suspension height. How much junk including people you tend to carry. Rim back spacing and width.
    2009 A4 Black 6MT STaSIS Touring #130
    -STaSIS ECU, cat-back Exhaust, STaSIS rear-sway bar (22mm), STaSIS lowering springs, STaSIS braided brake lines, STaSIS / Carbontech AX6 brake pads (front), STaSIS Monolite wheel (19x9)
    -AWE Tuning Sport Pedal Covers (silver)
    -Black Gloss Grille and Black Gloss US License Panel
    -A4L fog surrounds
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by kngfisher View Post
    Maybe I'm slow, but what does your post have to do with his proposed tire size?
    Apr 07 2007
    Mountain View, CA
    Random posting?
    Mar 30 2012
    Denver
    This set-up does look like it would dominate in the snow though! I live on CO and ski almost every weekend and was considering this same set-up for my B8 A4 with stock suspension (looks like you could fit monster truck tires under there with the stock suspension). Probably doing coilovers in the summer because car looks not so good with stock suspension and 19's. But as far as winter goes I thought a little extra tire to handle huge pot holes and everything else mountain driving includes would be a good thing. Will this really effect the ABS and other sensors enough to cause a noticeable problem?
    Here you go man....
    -cW
    Mar 15 2009
    If dealing with frequent snow do yourself a favor and don't drop it. I run stasis springs and had to replace underbelly due to ice and snow
    -A4L fog surrounds
    Veteran Member Three Rings Limey's Avatar
    Nov 27 2010
    2004 srt4
    Edmonton,Alberta
    That's why I run coilovers now.
    2009 A4/Brilliant Black/6MT//Usual Vag-Com mods//A5 5 spoke "y" rims with Michelin 255/35/19 super sports//bilstein pss10's//rs4 grill//rs4 grills//S-Line side blades//Ecode halogen to bi xenon conversion//LED bulb interior swap//AWE quad tip exhaust//Eurocode Short Throw Shifter/inlet pipe/sways/end links/alu kruz//S5 front brakes//APR carbonio intake//SPM Test & downpipe//APR stage 2 flash
